DevilDan Posté(e) 23 octobre 2011 Share Posté(e) 23 octobre 2011 (modifié) Bonjour Bonjour ! Je suis sur le portable d'un ami, il était en HBOOT 01.01.0002, Voici ce que j'ai fais : 1) Pour passer en 0001 J'ai fais sur cette page : http://forum.xda-dev...d.php?t=1145035 SEULEMENT ces étapes : S-OFFing the DeviceDowngrade to HTC Froyo WWE for AlphaRevX "now named: Revolutionary" (HBOOT 1.01.0001) It has been confirmed that AlphaRevX "Revolutionary" tool is not S-OFFing wildfire (buzz) 2.2.1, with HBOOT 1.01.0002! Therefore, downgrading the HBOOT to 1.01.0001 is must for the meantime, to get an efficient S-OFF. Lots of people seem to be having issues when trying to downgrade their Wildfire from a carrier-branded version (HBOOT 1.01.0002) to unbranded WWE (HBOOT 1.01.0001). So, here’s a small package to help you do this. click here. Extract this package somewhere you can find it, like your “Desktop” for example. Step 1: run step1.bat from the package. This will downgrade your MISC partition to allow for the RUU downgrade. At the end, GoldCardTool will start up, to allow you to create a goldcard which you will need before starting Step 2. How to deal with Gold-Card Tool: 1. Switch off your phone, remove your microSD card. 2. Insert the microSD card into your card reader, connect it to your computer and format the card to FAT32 file system. 3. Insert the card into your HTC Wildfire and power it on. 4. Make sure USB Debugging is enabled on your phone in Menu > Settings > Applications > Development. 5. Connect the phone to your computer via USB and set the mode to charge only. 6. Launch Gold-Card Tool on your computer and click ‘GetCID’. 7. Copy the CID code from the text box and click the link shown below that text box to open it in your browser window. 8. In the browser window, enter all the details required and submit that form. 9. You should now get an email from PSAS. Open it and download the ‘GoldCard.img’ attachment. 10. Now set your phone’s USB mode to Mass Storage. 11. In Gold-Card Tool, click ‘Refresh’. 12. Select your mounted SD card from the drop-down menu saying “HTC MMC:” 13. Click ‘Load Goldcard.img’ and select the file downloaded in Step 11. 14. Click ‘Patch MMC’ and your Gold Card will be created. You may exit Gold Card Tool once done. After you've made the goldcard, and patched it, continue with step 2. • Step 2: run step2.bat from the package. This will downgrade your ROM version to HTC WWE Froyo for Wildfire (unbranded). If you get a Customer ID error while doing this, your goldcard is not working! Create a new goldcard and re-run step2. 2) J'ai continuer sur cette page : http://forum.frandro...ot-wildfire-22/ J'ai fais ces étapes : 1) AlphaRev X1) Aller sur le site http://revolutionary.io/ 2) Mettez les information. (Serial Number : Sous la batterie ou Paramètres/A propos du téléphone/Identité/Numéro de serie) (Noubliez pas de copier votre beta key) 3) Activer Débogage USB (Parametres système/Applications/Développement) 4) Brancher votre téléphone en mode charger seulement 5) DéSINSTALLER HTC Sync et installer les drivers (http://www.multiupload.com/2OFYWZFCCR) 6) Dézipper le fichier téléchargé et lancer le programme (alpharevx) en mode administrateur 7) Rentrer la beta key qui vous a été donné Attendez, vous êtes S-OFF Il vous demande si vous voulez installer le recovery automatiquement choisissez Y (oui) ou N (non). Si vous choisissez N (non) installer le recovery manuellement : J'ai cliqué sur OUI et je pensais avoir fini puisque il y a écrit "Si vous choisissez N (non) ... :" Je suis passé à ce tuto sans faire les étapes 2 et 3 du tuto précédent : http://forum.frandro...-nightly101011/ Et quand je veux appliquer la cyanogen en ZIP ça marque aborted :/ Je suis donc revenu sur cette page : http://forum.frandro...ot-wildfire-22/ J'ai fais l'étape 3 du rootage (toujours pas fait l'étape 2) : 3) Rooter1) Télécharger http://api.viglink.c...1-ef-signed.zip et copier l'archive à la racine de votre carte SD 2) éteindre votre HTC et redémarrer en mode recovery : (volume bas + power puis sélectionner recovery) Pour sélectionner : Trackball Monter/Descendre : Touches volume Retour : Touche retour 3) Sélectionner "install zip from sdcard" 4) Puis "Choose zip from sdcard" 5) Puis "su-2.3.6.1-ef-signed.zip" 6) Puis "Yes - install su-2.3.6.1-ef-signed.zip" 7) Retourner en arrière et rebooter C'est fini, vous êtes enfin rooté Vous pouvez installer CM7 : TUTO : http://forum.frandro...ghtly-25042011/ ou une autre ROM. Puis j'ai ré-essayer d'installer la Cyanogen-mod toujours aborted :/ Pourquoi ? Que faire ? Je dois faire l'étape 2 aussi ? : 2) Installation de ClockworkRecoverySert a rooter votre téléphone et a installer une ROM custom. Il vous faut : - Le SDK Android : http://developer.and.../sdk/index.html - Le Fastboot HTC (fastboot.exe) : http://developer.htc.com/adp.html - Le ClockworkRecovery du HTC Wildfire : http://api.viglink.c...-j_r0dd_mod.zip 1) Installer le SDK (et faire les mises à jour) 2) Créer un dossier Android dans la racine de votre disque dur de votre PC (C:\Android) 3) Aller à C:\Program Files\Android\android-sdk\platform-tools. Copier dans C:/Android les fichiers adb.exe / AdbWinApi.dll / AdbWinUsbApi.dll 4) Dé-zipper Wildfire_recovery-clockwork-4.0.0.5-j_r0dd_mod.zip et copier-coller le fichier recovery-clockwork-4.0.0.5-j_r0dd_mod-buzz.img dans le dossier (C:/Android) 5) Copier-Coller le Fastboot HTC dans ce même dossier (C:/Android) 6) Renommer "recovery-clockwork-4.0.0.5-j_r0dd_mod-buzz.img" par "recovery.img" 7) Démarrer votre HTC sur le bootloader (Volume bas + Power) 8) Sélectionner "Fastboot" avec le bouton power 9) Brancher en USB 10) Ouvrer cmd 11) cd C :/Android entrée 12) fastboot flash recovery recovery.img entrée Vous devriez voir : sending 'recovery' ... OKAY writing 'recovery' ... OKAY Sélectionner 'Reboot' avec les touches volumes pour descendre/monter et power pour valider Votre HTC va redémarrer, vous pouver débrancher. Merci de m'aider =) Modifié 24 octobre 2011 par DevilDan Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Aryus Posté(e) 23 octobre 2011 Share Posté(e) 23 octobre 2011 (modifié) Si je comprend bien.. Tu as commencer par faire le debut du TUTO, puis la fin et enfin le milieu ? En gros 1,3 et 2.. Je ne connas pas la manipulation mais si tu suis un tutoriel dans le desordre.. Je te conseil de reessayer dans l'ordre : / ou d'attendre quelqu'un ayant fait et reussi cette manipulation. Tu as acces au recovery ? Modifié 23 octobre 2011 par Aryus Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
bbTGV Posté(e) 24 octobre 2011 Share Posté(e) 24 octobre 2011 Oui en effet ne pas suivre un tuto à la lettre ça peut être compliquer. Sinon tu as un message d'erreur quelque chose pour nous aiguiller ? Et une dernière question, c'est bien un Wildfire et pas un Wildfire S ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
DevilDan Posté(e) 24 octobre 2011 Auteur Share Posté(e) 24 octobre 2011 Bonjour j'y suis enfin arrivé en re-faisant toutes la manipulations avec ce tuto : http://forum.xda-developers.com/showthread.php?t=1145035 Merci beaucoup à tous ! J'ai eu quelques frayeur mais c'est résolu, par exemple le zip contenant la Cyanogen 7.1.0.1 était "(Bad)" mauvais, je l'ai re-téléchargé j'ai vu qu'ils n'avaient pas la même taille 66,3 Mo le mauvais à 79 Mo Le bon Zip ! J'ai perdu du temps à cause d'un fichier éroné presque 24 à refaire un tuto entier pour rien ! Si il y a installation aborted, je conseille de re-télécharger la rom =D Je suis donc en Cyanogen Mod 7.1.0.1 =D Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
