arunan Posté(e) 19 mars 2010 Share Posté(e) 19 mars 2010 (modifié) VillainROM4.0 Beta2 – More Stable BUILD It is very important to note that after I return from my weekend away, I have a few speed tweaks to implement into this rom. The tweaks/changes will make a significant difference to the rom, but they are time consuming. Currently, the speed of Sense UI is not up to par with Villain 3.4, so don’t expect super fast transitions. See details below in the ‘Tweaks’ section on how you can improve its performance. Overview This BETA build is a port of a recent WWE 2.1 Legend dump. You'll be pleased to know that the speed of Rosie is double what it was before. This is a very solid build, which is incredibly stable. Features HTC Quietly Brilliant Bootscreen (Please feel free to create some bootanimation.zips! * Notification Trackball doesn't flash like mad * Eris Port speed from a FULLY functional legend build * Fully working market – all apps, protected or otherwise working * Apps2SD - Working * Busybox * Root * Video Working * Optimized PNGs & Zip Aligned apks * All Legend goodies – Wallpaper, Friendstream, new widget designs * Working Google Navigation * Working embedded webpages/ip (yey!) * Working 3D Gallery (May FC once on first boot) WHEN INSTALLING> Follow this process:~ 1. Nandroid Backup 2. FULL WIPE 3. Flash the ROM 4. Follow the setup wizard 5. When Sense has fully loaded, reboot. 6. Download Spare Parts from market and set transitions to FAST. 7. Restore/Install all apps, then reboot again> this should cache some of your apps, and speed up the system. 8. Test, Test, Test! Téléchargement : Easyshare Topic officiel : http://forum.xda-developers.com/showthread.php?t=649155 GRAPHICAL GLITCH FIX : http://forum.xda-developers.com/attachment.php?attachmentid=298388&d=1269445983 Modifié 24 mars 2010 par arunan Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
dorian73 Posté(e) 20 mars 2010 Share Posté(e) 20 mars 2010 je la test depuis hier soir ....super stable ! reste a voir la batterie , et si j'arrive a enfin avoir le fix gps sur une villain les contacts facebook ne se synchronisent pas pour moi ......snif .... autrement que du bonheur ( et encore plus de bonheur lundi avec le fix pour la rapidité de sense ) !!!! :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
dorian73 Posté(e) 20 mars 2010 Share Posté(e) 20 mars 2010 rectification , la synchro facebook marche ! :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Ast2001 Posté(e) 20 mars 2010 Share Posté(e) 20 mars 2010 Bon, c'est pas hyper rapide mais passer en 2.1, c'est presque avoir un nouveau téléphone... Je suis hyper content. Il ya quelques trucs qui merdouillent mais le fait d'avoir toutes ces nouvelles fonctions et toutes ces nouvelles applis, ça vait bien les efforts. Google map 4.1 et Google nav Goggles Les noms de rues sous Copilot FriendsStream Les nouvelles fonctions du navigateur Le nouveau copier / coller Le nouveau Market Les miniatures des sept écrans ... (j'éditerai au fur et à mlesure) Pour l'instant, le plus chiant c'est l'autonomie qui baisse d'un coup de façon spectaculuaire Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
DoNuTs Posté(e) 20 mars 2010 Share Posté(e) 20 mars 2010 alors soit je reste en behero soit je passe en villain 4.0 .. y'a une différence entre les deux ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Profete162 Posté(e) 20 mars 2010 Share Posté(e) 20 mars 2010 Sur la villain, le friendstream s'actualise bien? Sous BeHero, je me rappelle que c'était pas facile, quand on arrivait sur le widget il affichait des vieux statuts, puis mettait une ou 2 secondes à s'actualiser. ( et puis la synchro, fallait la faire manuellement, mais c'est moins grave ca!) Quen est-il chez Villain? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
DoNuTs Posté(e) 20 mars 2010 Share Posté(e) 20 mars 2010 j'suis en pleine install de la villain ... je te dirai ce qu'il en est de friendstream Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Ast2001 Posté(e) 20 mars 2010 Share Posté(e) 20 mars 2010 (modifié) Sur la villain, le friendstream s'actualise bien?Sous BeHero, je me rappelle que c'était pas facile, quand on arrivait sur le widget il affichait des vieux statuts, puis mettait une ou 2 secondes à s'actualiser. ( et puis la synchro, fallait la faire manuellement, mais c'est moins grave ca!) Quen est-il chez Villain? Le widget ne semble pas s'actualiser automatiquement (ou alors avec une périodicité que je ne connais pas et qui doit être assez longue). Il y a le bouton refresh dans sa zone inférieure. Par contre, il n'affiche pas de vieux statuts. Modifié 20 mars 2010 par Ast2001 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
U Guerrieru Posté(e) 20 mars 2010 Share Posté(e) 20 mars 2010 Pour l'instant, le plus chiant c'est l'autonomie qui baisse d'un coup de façon spectaculuaire Je pense que c'est un problème inhérent au flashage de ROM (ça me l'a fait sous behero et sous villain), à la première utilisation après le flash, la batterie en prends pour son grade. Et une fois ce problème passé tout semble plus ou moins rentrer dans l'ordre au niveau de l'autonomie (Je tiens environs un jour et demie sous behero, sans trop abuser du tel hein...) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
DoNuTs Posté(e) 20 mars 2010 Share Posté(e) 20 mars 2010 (modifié) bon premier bon point par rapport a behero, layar et pleins d'autres applications fonctionnent de nouveau :) par contre le bug des APN est toujours présent, FC et du coup obligation de télécharger l'appli APN backup & restore .. houlala par contre vivement le fix pour la rapidité car c'est lent ... et la ram dispo aprés un kill dépasse pas les 62Mo.. la galerie 3D excellente ! bug en mode paysage. la différence que j'ai remarqué par rapport a la behero c'est la traduction, tout est en "vrai" français y'a plus d'anglais, de méme que le mode configuration au premier démarrage, avec tuto touch input d'office .. Modifié 20 mars 2010 par DoNuTs Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Torak Posté(e) 20 mars 2010 Share Posté(e) 20 mars 2010 @Profete : Je vois très bien de quel bug tu parles pour Friendstream sur la BeHero. Sur celle ci comme cela a été dit ce bug n'est plus présent, par contre en effet il semble qu'on doive le recharger manuellement =/ . Sinon, quelqu'un arrive à faire marcher le widget de News ? Il charge dans le vide chez moi Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
skhulleur Posté(e) 20 mars 2010 Share Posté(e) 20 mars 2010 Sur la villain' date=' le friendstream s'actualise bien?Sous BeHero, je me rappelle que c'était pas facile, quand on arrivait sur le widget il affichait des vieux statuts, puis mettait une ou 2 secondes à s'actualiser. ( et puis la synchro, fallait la faire manuellement, mais c'est moins grave ca!) Quen est-il chez Villain?[/quote'] Le widget ne semble pas s'actualiser automatiquement (ou alors avec une périodicité que je ne connais pas et qui doit être assez longue). Il y a le bouton refresh dans sa zone inférieure. Par contre, il n'affiche pas de vieux statuts. Il s'actualise par périodicité (par défaut toute les 2 heures). pour changer la periodicité il faut aller dans les préférence de FriendStream. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
yoyokarine Posté(e) 20 mars 2010 Share Posté(e) 20 mars 2010 j'suis en 3.4 je vais attendre encore un peu alors Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
brutecore Posté(e) 20 mars 2010 Share Posté(e) 20 mars 2010 je suis sur celle ci depuis hier soir je suis tres content niveau autonomie de 6h30 ce matin je suis a 66% a 18h avec des appels, sms, internet et maj meteo pour moi c'est celle qui consomme le moins les autres je perdais entre 15 et 20% par heures Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Ast2001 Posté(e) 21 mars 2010 Share Posté(e) 21 mars 2010 En ce qui me concerne, j'ai de réels soucis avec l'autonomie avec cette ROM mais le fait de me trouver enfin en 2.1 et de pouvoir utiliser le nouveau Sense et toutes les applications qui m'étaient interdites jusque là vaut vraiment la peine d'y passer. Franchement, à part deux ou trucs ici ou là, c'est vraiment une ROM remarquable. La vitesse n'est pas exceptionnelle (sans pour autant être catastrophique loin de là) mais une version optimisée devrait arriver très vite. Franchement, je recommande sans réserve. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Joeman Posté(e) 21 mars 2010 Share Posté(e) 21 mars 2010 Arf, il y aurait encore des problèmes d'autonomie sur cette rom :mad: Tant pis Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Torak Posté(e) 21 mars 2010 Share Posté(e) 21 mars 2010 Non perso autonomie nickel. Comme sur toutes les roms en 2.1 après 2 jours d'utilisation :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Profete162 Posté(e) 21 mars 2010 Share Posté(e) 21 mars 2010 Non perso autonomie nickel. Comme sur toutes les roms en 2.1 après 2 jours d'utilisation :) Je suis convaincu à 200% que l'autonomie a un rapport avec le signal du GSM/Data que le téléphone recoit. Il doit manquer un petit quelque chose qui fait qu'à certains endroits, le téléphone pompe comme un fou suivant les parametres des antennes/opérateur/autre Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Golork Posté(e) 21 mars 2010 Share Posté(e) 21 mars 2010 (modifié) Moi j'ai un gros problème depuis la rom 3.3 et j'ai la 3.4 qui est pareil : Tout fonctionne parfaitement pendant quelques jours puis plusieurs programmes se mettent à planter la galerie 3D plante tout le temps et me demande si j'attends ou si je force sa fermeture sachant qu'elle fonctionnait nickel au début ! Et si j'essaie de la lancer elle m'affiche un écran noir... Le pire c'est qu'elle plante alors que je ne lui ai pas demandé de se lancer !! Et le market -> le chargement n'en fini pas et j'ai rien du tout après 5 min d'attente (j'ai essayé en 2G, 3G et Wifi)... Est-ce que cette 4.0 fonctionne pareil dans le temps où c'est plus stable ?? Je vais devoir retourner à une Modaco si ça continu... Edit : @Profete162 : moi aussi des moment j'ai un bouffe batterie et je me demande si c'est pas ce "auto taskiller" qui fout la m****. Car depuis que le le lance plus ça va un peu mieux... Edit 2 : bon tout compte fait un petit reboot et désinstall d'autoKiller et tout semble mieux fonctionner. Modifié 22 mars 2010 par Golork Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité Posté(e) 22 mars 2010 Share Posté(e) 22 mars 2010 Exact que se soit sur cette villain ou la rom de bennahm celui-ci bouffe pas mal de batterie :/ La solution de faire un fichier nommé 05Memkill dans: /etc/init.d/05memkill et de mettre dedans: echo "1536,2048,4096,10240,12800,15360" > /sys/module/lowmemorykiller/parameters/minfree Evidemment tu met les valeur que tu veut ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
guigs Posté(e) 22 mars 2010 Share Posté(e) 22 mars 2010 c'est moi ou c'est super lent malgres les transitions en fast? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Ast2001 Posté(e) 22 mars 2010 Share Posté(e) 22 mars 2010 c'est moi ou c'est super lent malgres les transitions en fast? En ce qui me concerne, je ne trouve pas ça si lent. Venant dune Modaco 3.2 hyper rapide et ayant lu tous les commentaires sur la lenteur de cette ROM, je m'étais préparé psychologiquement ;) à avoir des performances vraiment pitoyables. Et au final, j'ai été agréablement surpris. Il y a des lags indéniables mais dans l'ensemble, ce n'est pas pire que la toute première ROM de mon hero. Et 'super lent' ne me semble pas du tout le bon qualificatif. Tu as bien rebooté trois fois ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Torak Posté(e) 22 mars 2010 Share Posté(e) 22 mars 2010 Pour moi c'est beaucoup trop lent aussi, inutilisable au quotidien. Je suis repassé sous BeHero, c'est vraiment le bonheur ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
gugux Posté(e) 22 mars 2010 Share Posté(e) 22 mars 2010 Salut, Petite question pour ceux qui utilisent cette ROM (et les autres aussi d'ailleurs) : est-ce que les fonctions associées au bluetooth sont présentes et fonctionnelles ? J'entends par là : échanger des objets avec un PC ou un autre tél, comme une photo, un fichier, etc ? C'est la fonction qui me manque le plus sur 1.5, et celle qui me pousserait vraiment à passer en 2.1 ... et j'arrive pas à trouver l'info ! Merci ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Joeman Posté(e) 22 mars 2010 Share Posté(e) 22 mars 2010 Rapide essai ce matin. je suis victime du problème de FC quand on veut positionner l'apn .. Je laisse tomber pour le moment. Mais effectivement, le peu que j'ai utilisé la rom, elle semblait très lente. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
