[Question] Rom 4.0 sur le Wildfire
Petit up avec ce qu'en pense arco68 si vous l'avez loupé sur xda :
Not so good news I'm afraid. Although it's not so much of a problem getting most of the hardware to work (except camera which all devices struggle with atm), the biggest problem for us is that Google has completely removed all support in the source for non-GPU devices. Even in Gingerbread we had to rely on hacks to make the ui smooth, but these hacks are not easy to implement in ICS due to lot's of code removed. I've managed to forward port some of it, but it's far from perfect. A lot better than without it, but still not as smooth as in Gingerbread. There's also something weird with the color space in Android now, which I guess is because it expects and uses graphics capabilities we don't have. For example gradients look like crap, like they are shown in 8 bit mode or something. Unless someone are able to fix it, I don't expect there will be a CM9 for the Wildfire. Almost all of the top coders are working on the high-end devices and probably doesn't give a crap, so I'm not optimistic.
I've put the device config for ICS up on GitHub, so anyone that wants to can build from it. You can also get a prebuilt version of it here: http://www.multiupload.com/1Y14642PG0 (I'm not bothering making a new thread for it). It should be ok enough to poke around in. Consider it some kind of Christmas gift. tongue.gif
Edit : je viens d'installer sa rom et je ne serais pas autant pessimiste que lui, c'est quasi fluide, mais j'ai quelques fois le réseau qui "saute", je suis vraiment surpris par la fluidité, je m'attendais à bien pire !
A SUIVRE ! :)
Modifié par Vlad
Heu... oui, bien sûr !
C'est la première version, beaucoup de bugs.. :
Rapporté parheavy_metal_man :
NOT WORKING.
Gallery
Web browser
Camera
Phone calls - screen says unfortunately the process com.android.phone has stopped working and gives the option of ok but if you don’t click it the call still works. After the call is over it says that a new sim has been inserted and the phone must restart, but it you hit back on the keypad it buggers off.(but txts work)
Key board in portrait mode, as stated earlier.
WORKING.
Sound
Touch screen
Sms
Music
Downloading apps
Market place
Superuser
Trackball! Select as well as move!
C0ntacts
Signal
Wifi
Email
3g data
Clock
Battery &
Status bar icons
Home button, back button, menu button, search button.
Power button, volume buttons.
  • 2 months later...
j'ai un ami qui a installé la 4.0 sur un Galaxy S il me semble, elle est vraiment stable, et il a apparement plusieurs nouveauté dessus, notament la possibilité de pouvoir regler le proxy sur le reseau de la fac de Lille 1, vraiment pratique, j'espere donc qu'une version 4.0 sortira pour notre bon vieux wildfire, pour qu'on puisse profiter de ces nouveautés ^^
