[Eclair 2.1] [UPDATE 24/03/2010] Androbin_1.1 based on AOSP Eclair 2.1
Gutsu
Bonjour, ça fait plusieurs fois que je vois des gens qui préfèrent une version d'Android 2.1 sans sense II, alors je suis tombé sur ce post et j'ai pensé à vous :p
Hi!
This ROM has been built with cyanogen sources 2.1 (sdk7), with the addition of my customizations and optimization. The next release will bring this ROM to be very complete, faster and stable.
I'm not responsable if you bricked your phone, data lost or something else. You have to always do an nandroid backups' before updating.
THIS ROM IS ONLY FOR GSM HERO
Features:
-Making phone calls
-3G and 2G data
-HSDPA indicator
-Access
-Network location
-GPS and AGPS
-Bluetooth file transfer
-Live wallpapers
-Full market access
-Camera at 2-3 megapixel resolution
-APNdroid
-MinFree Manager
-Network Tweaks
-Apps2Sd
-Java Box
-3d gallery
and much more!
Benchmark: 2.36 MFLOPS / s
memory after fresh install 159 MB
Known Bugs:
- Gallery distorted when it is in Landscape
- Some Live Wallpapers very unstable
- BT audio during calls (maybe)
Instructions:
1.Wipe date, cache and ext partition
2.New ext partition (if you want to enable apps2sd)
3.The Flash ROM
4.Reboot
to enable apps2sd from a command prompt:
adb remount
adb shell
mkdir / system / sd
apps2sd on
reboot
It's highly recommended restarting a second time to allow the system to settle down.
It would be better to wait 30 seconds after the start of the device to permit full loading of the system, even if the lock screen is already visualised.
Changelog 1.1:
-Optimized framework
-Add backup / restore script
-Launcher2 (very fluid)
-Overclock widget
-Update and fix youtube (works )
-Remove amazon (save space)
-Camera operate at 5mpx (thanks yneveu!)
-Bugfix graphics market (thanks meLIanTQ!)
Radio update highly suggested!
http://forum.xda-developers.com/showthread.php?t=651103
Enjoy !!
J'ai installé pour testé c'est pas super fluide je trouve ca saccade avec le Launcher modifié et les fond d'écran animé bah y'en a qu'un seul qui fonctionne et ca rame pas mal :)
Je vais voir après un reboot et kill
EDIT : Après un kill et un fond 'écran animé (l'herbe) 125 mo de ram libre mais toujours une impression de ralentissement au switch de bureau
EDIT2: Donc je trouve ca vraiment pas fluide du tout avec autant de mémoire dispo c'est bizarre, je vais repasser sur une vilain 3.4 je pense
Modifié par Heldwin
Bon alors moi je suis du même avis que HeldWin, il y a toujours l'effet de lenteur comparé au défilement de Sense.
Des gros bug concernant les fond d'écran animés...
J'ai eu des Freeze de la rom et des FC assez souvent quand la RAM est surcharger (le telephone demande le code PIN ...)
Donc je suis repasser sous la Behero.
Au niveau de la batterie j'ai pas trouver de differences (j'utilise underclock Widget sur toutes mas ROM)
ah oui d'ailleur le Super User truc ne marche pas... donc pas de Root sur cette rom ..
Voila voila
Changelog 1.1101:
-fix facebook exchange
-fix update Maps
-opengl performance!
-optimize library renderscript (some livewallpapers work better!)
-add magic_smoke and nexusmodex from aHero (thanks MaXo)
-HtC_IME (separate)
Elle fonctionne nickel ;)
Utilisable 24/24 pour ma part (je n'utilise pas d'oreillette bluetooth ...)
Lut,
Quelqu'un a des screen ? Car quand je vois le temps pour avoir un Hero sous Android 2.1 avec Sense, je pense que la 2.1 sera la dernière avec Sense pour moi.
- Il y a la synchro des comptes avec Facebook ?
- A quoi ressemble les contacts ?
- A quoi ressemble les SMS ?
- A quoi ressemble l'Agenda ?
Merci.
