Recovery V5.0 - Samsung Galaxy : Eclair version
Last release :
28/03/10 : V5.0
Changelog :
V5.0 :
- New recovery for Android Eclair 2.1
Features :
- Mini/Full recovery (depending on the presence of the archive RECTOOLS.tar.gz in /sdcard)
- Custom wallpaper
- ADB root
- Flash update.zip, or any other zip stored in /sdcard
- Mount/umount internal/external SD
- Full wipe
- Nandroid backup
- Nandroid restore
- Deletion of old nandroid backup (be carrefull)
- Enable/disable root
- Fix permissions after an update
- Check filesystems on internal SD
- Restore google apps
How to :
1) Put RECTOOLS.tar.gz and recovery.img in the same directory on your computer
2) Boot the phone in fastboot mode
3) Flash your recovery partition (using fastboot) with the recovery image :
Quote:
./fastboot flash recovery recovery.img
4) Reboot in mini recovery mode
5) Using adb, put all the necessary files on your sdcard :
Quote:
./adb push RECTOOLS.tar.gz /sdcard/
./adb shell sync
6) Reboot :
Quote:
./adb shell reboot recovery
Please don't delete the recovery archive in your sdcard, or redo 5) if you have deleted it
If you like my work, give me beer, or give my girlfriend a flower :
File :
http://drakaz.sfhost.net/GALAXY/
I have a problem.. I tried to flash the recovery 5.0 but when the phone reboots in recovery mode nandroid shows a 0.4.4 version! In theory when I flash it with fastboot the phone says that everything is ok, showing an "writin 2890kb OK"...
I have flashed my galaxy with Odin and firm K4, with original recovery, and flashed the recovery again but.. the same thing...
Any ideas?
Now it works. I was trying to flash the galaxy with virtualbox on linux, but definetly I decided install xp and flash the phone keeping windows for the future.
Did the formatting option works? Because I decided to format with swap but when I tried it says that "format failed". The filesystem it's fat32? Doesn't is ext3 in android?
Thanks
