drakaz Posté(e) 28 mars 2010 Share Posté(e) 28 mars 2010 (modifié) Public BETA 1 WARNING This is a BETA release. At the time being, many features are not implemented yet. This beta intend to show you the current status of GAOSP, not replace Donut. This BETA remains slow, with lot of bugs. If you found one, please check if the bug is not already in issue's list (http://code.google.com/p/gaosp/issues/list), and if it's not already present in Donut (if it is, it's not really a bugs, but an improvement). Please make a backup before installing this beta. You will use it. If you want to have a fully working GAOSP, just help us, fix the bugs, and implement the last functionalities (check the home page for contact informations).But please acquire minimal android's knowledge before..(we've got lot of proposal help, but we had to train them. Unfortunatly, we don't have the time to do that, and all the informations can be found with Google's help). The GAOSP team is currently too small for a project of this magnitude. GAOSP needs you. Without a bigger team, GAOSP will die. Global features : System : * Clean vendor * RIL (telephony/data) * Original galaxy keys * Internal/External SD * Sound (need fix for stereo and some other few bugs) * LiveWallpaper? (remains slow because of 3D) * GPS * Sensors (except proximity sensor) * Bluetooth (first release, need lot of fix) Other : * Easy-to-build system by Linuzel * Custom Kernel 2.6.27 (waiting for Samsung's 2.6.29 sources) * Clean shutdown/startup system by Cyanogen * Tools included * Lof of tweaks * FLAC audio support from Kenny Root (from CyanogenMod?) * Perform zipalign-on-install of applications (merge with CyanogenMod?) * Lot of locations * 360-degree auto-orientation by Optedoblivion and Elanthis (from CyanogenMod?) * OpenVPN integration thanks to James Bottomley (from CyanogenMod?) * Full ssh server with real authentication (dropbear) * Custom bootanimation from Bioden (frandroid) * Custom android logo on boot by Epervier (frandroid) * Custom logo.rle by Alexandre (frandroid) * Root & Superuser * Reboot & Reboot recovery now included in shutdown menu * Full busybox with symlink What's not working yet : - Camera - 3D - Stereo sound - Proximity sensor - Bluetooth : file transfert with oldest Android version, AD2P How-To and files : http://code.google.com/p/gaosp/wiki/PublicBeta Modifié 28 mars 2010 par drakaz Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
