[ROM]m1ndh4x8r
shenrone
Bonjour j'ai voulu insttaller cet rom mais jne n'est pas compris certain point
APPS2SD
I:
Copy ROM to SDCARD
Use Minitool Partition Wizard to resize SDcard in Following format: NOTE: use card reader not in phone usb.
1st-FAT32 - size any
2nd-Ext4 - Not more than 2GB
3rd-Linux Swap - mine is 512MB
All primary
II:
In CWM recovery
Wipe Factory, Data, Cache and Wipe Dalvik Cache
Install Zip from SD Card
After finish reboot
Configure settings
Run link2sd app choose Ext 4
then in Nofrills CPU change to whatever mine is Smartass with noop
Then Reboot again.
DATA2SD
I.
Follow no I. Apps2sd Instructions on top
Install ROM, after finished
Reboot to Sense Android wait for 30 secs. to fully boot
turn off fast boot in settings, power off
go to recovery install zip data2sd installer, when finished
reboot, uninstall link2sd cause you won't be needing it
anymore.
car moi des que j'installe ceci la rom ne démarre plus est reste bloquer sur le screen htc
