Fonction USB Audio à activer
A mon avis, il faudrait veiller à la synergie ampli-casque et casque.
Quant à la compatibilité des DAC USB/ampli-casque FiiO et le Galaxy Nexus, à ma connaissance le FiiO E10 inter-opère avec le Galaxy Nexus utilisant uniquement l’application de lecture musique USB Audio Recorder PRO plutôt simpliste.
http://forum.xda-dev...84&postcount=55
Samsung Galaxy Note 2 & DAC USB/ampli-casque HRT microStreamer :
http://www.head-fi.o...05#post_9123185
http://www.stereophi...t-microstreamer
http://www.positive-...crostreamer.htm
"I need to say this: driving my Audeze LCD3's with the microStreamer (not the easiest headphones to drive well enough to truly show their magic) had me talking to myself when I first heard the magnificent combination! My wifey would hear me saying things like, "this can't be ******* happening," and "this is unreal"...
The HRT microStreamer has raised the bar so high in its category I hope it gets all the accolades it deserves. In uber-portable headphone amp/DAC combo solutions for the computer I can't think of another component outside the Audioquest Dragonfly, which to my ears doesn't have quite the dynamic punch of the microStreamer that even approaches the sonic performance of this miraculous little aluminum brick. It's like an audiophile’s reference-system-in-a-box. You have to hear it to believe it."
Apparemment, l'ensemble HRT microStreamer + casque orthodynamique Audeze LCD3 a une très bonne synergie.
http://www.6moons.co.../audeze2/1.html
Modifié par Ba Dan
Samsung Galaxy S3 & DAC USB Graham Slee Bitzie avec contrôle de volume de l'étage de sortie casque :
http://www.gspaudio.co.uk/bitzie-usb-dac-external-soundcard.htm
Apparemment, le Graham Slee Bitzie est bien appairé avec les casques Sennheiser HD250II, AKG K701 ou Sennheiser HD800.
"The only great sounding USB DAC to work with a mobile phone...
Plug & play compatible with Samsung Galaxy S3 running Android Jellybean. Over 7 hours continuous playing time!"
"OK, quality into high impedance headphones? HD250II: too good! K701: I'm shocked! HD800: almost very natural! All three very revealing... HD800 doing guitar string slides and moist mouth vocals extremely real."
http://audio-forum.gspaudio.co.uk/bitzie-usbdac-preview_topic1701_page3.html
Je viens de faire l'acquisition d'une chaine sony CMT G1iP http://www.sony.fr/product/micro-systemes/cmt-g1ip.
La micro chaine possède une prise USB en facade compatible Iphone / Ipod mais étant devenu (récemment) hostile à Apple, mon Galaxy SIII sous JB 4.1.1 n'est pas compatible avec le produit Sony une fois branché en facade (en tout cas, c'est ce qui est affiché sur l'ampli quand je branche mon Galaxy SIII !). Vous pourrez me dire qu'il reste la solution de passer par la prise mini jack de mon smartphone mais je préfèrerais utiliser le DAC de ma micro chaine plutôt que celui du Galaxy SIII.
D'où mes questions :
-comment faire pour transiter les fichiers numériques audio depuis mon Galaxy SIII vers l'ampli Sony (que ce soit de la musique stockée sur le Galaxy ou streamée depuis une application telle que Spotify) ? Est-ce un problème de drivers du Galaxy ou cela vient-il de la micro chaine ?
- L'autre solution consisterait à convertir la sortie USB du Galaxy SIII en sortie coaxiale qui peut être raccordée à la micro chaine. Existe-t'il des convertisseur USB / Coaxial ?
Merci d'avance !
Il semble que l'USB audio de ta micro chaîne ne soit compatible qu’avec les iPod / iPhones.
Elle n’est pas compatible PC / Mac et donc Galaxy S3.
Tu pourrais choisir l’un des DAC USB de la liste suivante :
http://www.head-fi.o...60#post_9249029
. à la maison :
Galaxy S3 > sortie numérique >> DAC USB ou DAC USB avec ampli casque > sortie analogique >> ampli de la micro-chaîne >> enceintes
. en vadrouille:
Galaxy S3 > sortie numérique >> DAC USB avec ampli casque >> casque
Par exemple
. un DAC USB avec une sortie analogique assez puissante pour se passer d’un ampli-casque Stoner Acoustics UD100 à 50 us$
. un DAC USB avec ampli casque HRT microStreamer à moins de 200 € bien apprécié par des audiophiles
Il semble que ta micro-chaîne audio n’a pas d’entrée SPDIF.
Autrement, il existe des DAC USB avec convertisseur USB / SPDIF de la liste de DAC compatible mentionnée, par exemple le Turtle Beach Audio Advantage Micro II.
Galaxy S3 > sortie numérique USB >> Turtle Beach Audio Advantage Micro II > sortie numérique SPDIF >> DAC SPDIF avec ampli Leckerton UHA-6S MKII
  • 3 weeks later...
Felicitation pour ce post hyper complet, c'est une mine d'informations.
Je suis en train de convertir des enceintes DIY qui trainent dans un placard en une BoomBox de qualité HiFi....
Je reconditionne les HP sur de petites enceintes pilotées par un ampli classe D Topping TP60.
J'ai deux entrées analogiques sur l'ampli.
L'une sera branchée a un recepteur bluetooth APT-X pour se rapprocher d'une qualité CD
L'autre sera branchée a un DAC USB pour obtenir une qualité de son bien meilleur qu'en passant par le convertisseur de mon Galaxy S3.
Je m'adresse donc aux spécialistes qui rodent dans le coin pour leur demander conseil:
Sans y mettre une somme folle quel DAC me conseillez vous, sachant que je n'ai pas besoin d'une sortie casque ni même d'un controle de volume. Ces deux dernieres fonctions semblent malgrés tout souvent de mise et si un DAC équipé sortait du lot je m'en contenterai.
Merci votre aide!
Arnaud
C’est difficile de te conseiller un DAC.
L’idéal est que tu te fais prêter l’un des DAC ayant été testés positivement avec le Galaxy S3, listés dans le 1er post de ce topic, pour savoir si le son du DAC relié à ton ampli Topping TP60 et tes enceintes DIY te convient.
Il y a des DAC qui ne coûtent que quelques euros comme le C-Media CM119, qui permettent de faire le premier pas dans la musique numérique dématérialisée et de disposer d’une base de comparaison.
Galaxy S3 > sortie audio numérique >> câble adaptateur USB OTG >> DAC C-Media CM119 >> ampli Topping TP60 >> enceintes DIY
Câble adaptateur USB OTG :
http://www.amazon.fr/s/ref=nb_sb_noss?__mk_fr_FR=%C3%85M%C3%85Z%C3%95%C3%91&url=search-alias%3Daps&field-keywords=c%C3%A2ble+adaptateur+usb+otg&rh=i%3Aaps%2Ck%3Ac%C3%A2ble+adaptateur+usb+otg
DAC C-Media CM119 :
http://www.amazon.co.uk/s/ref=nb_sb_noss/280-9621641-4123667?url=search-alias%3Daps&field-keywords=cmedia+cm119
Il y a des DAC qui permettent d’aller au-delà du 16bits/44,1KHz du format CD, qui savent traiter du 24/96 ou du 24/192.
Il y a des DAC à liaison asynchrone, théoriquement plus apte à réduire le niveau de jitter.
Il y a des DAC disposant d’une plus ou moins bonne isolation contre les perturbations électromagnétiques, de filtre plus ou moins lisse, ou d’étage de sortie analogique plus ou moins neutre.
Enfin il y a des DAC plus ou moins esthétiques.
Merci pour cette reponse.
Entre temps j'ai poursuivi mes recherches et de ce que je comprend, la fonction USB audio dispo sur jelly bean et donc dans mon S3 est fonctionnelle sur des Dac standard.
Toujours pdt mes recherches, je suis tombé sur ce DAC:
http://www.audiophonics.fr/audiophonics-uac-mini-usb-dac-16bit48khz-pcm2706wm8501-p-5807.html
C'est un modele facilement intégrable dans mon projet, je ne l'ai pas trouvé dans ton listing, d'apres toi il serait utilisable ?
Arnaud
C'est probable, car le DAC Audiophonics UAC 27 utilise une vieille puce USB TI PCM2706 dont les descripteurs USB devraient être bien conformes aux spécifications USB. Et le logiciel USB audio du Galaxy S3 est plutôt intolérant avec les descripteurs USB qui ne sont pas tout à fait conformes aux spécifications USB.
  • 1 month later...
Bonjour à tous !
Je remonte ce topic car je cherche désespérément à connecter mon Galaxy S3 via USB dans ma voiture afin de pouvoir y controler mon appli DeeZer .
Le fait d'activer l'audio via USB permettrait il de faire cela ?
Pour le moment , aucun moyen de faire reconnaitre le téléphone à ma voiture .
Alors qu'en y branchant un Ipomme , le contrôle est possible via les commandes aux volants etc ...
Le sujet parle à la base de DAC's mais je me permets d'écrire ici car vous avez lair de bien maitriser le sujet donc peut être que quelqu'un sera en mesure de me renseigner sur le protocole usb qui permet à l'Ipomme d’être parfaitement reconnu et contrôlable alors qu'avec Android on à le droit qu'a du "simple" MTP pas tres évolué ...
Bonsoir a tous !!
Je ne suis peut être pas sur le bon forum mais c'est celui qui pour moi me paraissais le plus adapté.
Voila je suis novice dans le domaine de l'audio et l'amplification,voyageant de forum en forum , j'ai appris qu'il était possible d’améliorer la qualité de mes écoutes grâce à un ampli pour casque.
J'ai acquis il y a très peu de temps un superbe casque Philips Fidelio L1 dont je retire entière satisfaction.Je l'utilise principalement avec un Sony Xperia Z , et sur mon ordinateur. J’écoute la plupart de mes musique en FLAC et MP3 320 kpbs.
Je souhaiterai acquérir un ampli , pas trop encombrant, pour un usage à la fois nomade et sédentaire,pour un budget grand maximum de 150 euros.
J'ai cherché sur les forums , mais n’étant pas certain, j'aimerai être guidé dans le choix de mon futur achat au vu de ma configuration afin de profiter au mieux de mon casque .
Apres quelques recherches, la gamme d'ampli Fiio semble appréciée de la communauté audiophile, et j'aurais voulu avoir vos avis sur les modeles E12 Montblanc , E17 ou encore E07K. Quelles sont les différences entre ces modèles? ou si vous aviez d'autres suggestions.
Je vous remercie par avance pour votre aide
Modifié par Novaa1990
Je ne connais pas très bien le Xperia Z, mais il me semble qu'il ne dispose pas de sortie analogique line-out pour le relier proprement à un ampli.
Il faut donc éliminer l'ampli FiiO E12.
Le DAC USB/ampli-casque FiiO E07K a été testé avec succès avec le Xperia Z :
http://forum.xda-dev...30&postcount=14
Xperia Z > sortie audio numérique >> câble adaptateur USB OTG + câble USB fourni par FiiO >> DAC/ampli-casque FiiO E07K >> casque
http://www.amazon.fr...ptateur USB OTG
Bonjour à tous !
Android & solutions proposées par Grom Audio :
http://www.ebay.fr/s... audio&_sacat=0
D'autres préfèrent les DAC standard de meilleure qualité :
http://www.head-fi.o...95#post_9442956
http://forum.frandro...40#entry2093781
Galaxy S3 > sortie numérique >> câble "USB OTG" >> DAC USB Behringer UCA202 >> ampli autoradio >> enceintes autoradio
Une liste de DAC USB standard testés avec succès avec le Galaxy S3 :
http://forum.telleme...=2116&start=435
  • 1 month later...
Bonjour a tous ,
Désole si je déterre le topic , mais il m'a semblé approprié.
J'ai récemment acheté un Fidélio L1 , et je me demandais si il était utile d'acheter un Ampli/DAC externe tel que le FiiO E07k pour mon Galaxy Note 2.
Il y à t'il des possesseur d'un Galaxy Note 2 ou d'un Galaxy S3 qui on un Ampli/DAC ? Si oui , cela vaut'il vraiment les 80 € a mettre dans un FiiO E07k ? Si vous connaissez d'autre Ampli/DAC dans la limite de 120€ et compatible avec le Note 2 , je suis ouvert a toute proposition .
Merci d'avance pour votre aide .
  • 2 months later...
Tout d'abord, je trouve ton topic excellent ba dan. Malgré toute les infos que j'ai pu trouver, je n'arrive toujours pas à faire fonctionner ma configuration :
_ Samsung Galaxy S3 4G, sous Android 4.1.2
_ appli utilisées : Spotify, USB Audio Recorder PRO
_ câble OTG Samsung officiel
_ DAC USB Audioquest Dragonfly
_ intra Earsonics SM64
Pour résumer, la seule configuration qui fonctionne est celle qui passe par USB Audio Recorder PRO. Je peux écouter mes morceaux FLAC mais seulement s'ils sont stocker sur un support physique (mémoire téléphone ou SD card). Ça ne me convient pas du tout.
Mais ce que je voudrais faire, c'est pouvoir utiliser Spotify vu que j'ai un abonnement. J'ai trifouillé dans les réglages d'Android, j'ai passé en revue toutes les catégories de paramètres, mais je n'ai jamais réussi à trouver d'option pour forcer le signal audio à passer par l'USB.
Quand je branche mon DAC Dragonfly, elle s'allume en violet (= ne fonctionne pas), elle devrait être allumée en vert pour fonctionner (si tu connais un peu, ça marche avec le taux d’échantillonnage).
Alors en parcourant le net, j'ai trouvé le DAC USB Audioquest Bumblebee qui serait spécifique Android, mais je n'ai pas très bien compris si c'était le même que le Dragonfly. Et puis j'aimerai pas à avoir à acheter un second DAC.
Sur Headfi j'ai trouvé un tableau où il était marqué que le Dragonfly nécessitait l'appli USB Audio Recorder PRO pour fonctionner. Mais ce que je ne comprends pas, c'est que d'autres DAC USB intégrant la même puce SABRE fonctionnent sans problème d'après les liens que tu as posté.
J'ai aussi vu le post sur les drivers ALSA, mais mon niveau d'anglais et de compréhension technique bloque, je saisi pas vraiment ce dont j'ai besoin et ce que je dois faire des fichiers...
... bref je suis un peu déçu après beaucoup de temps à chercher une solution.
Le DAC USB et le cable OTG fonctionnent parfaitement car je les ai testé avec d'autres appareils. Par contre je n'ai pas d'autres smartphone sous la main pour tester le Dragonfly.
Est-ce que tu vois une solution? (driver, appli...)
  • 4 weeks later...
Ce n'est pas un problème de la puce Sabre du DAC DragonFly.
Il faudrait d'abord que le Galaxy S3 arrive à communiquer avec la puce USB du DragonFly.
Ce serait plutôt une mauvaise interprétation du protocole USB des développeurs USB audio du S3. Ce qui n'est pas le cas des développeurs USB audio de l'application USB Audio Recorder PRO.
http://developer.samsung.com/forum/board/thread/view.do?boardName=GeneralB&messageId=227582&startId=zzzzz~
Samsung a amélioré l'USB audio dans le Galaxy Note3 qui peut interopérer avec le DAC USB DragonFly sans recourir à l'application USB Audio Recorder PRO.
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/3285#post_9895489
Désolé de cette réponse tardive ! Je viens rarement ici, car il y a très peu d'intervenants.
La liste de compatibilité Appareil Android - DAC USB est régulièrement mise à jour dans les topics suivants :
http://www.tellementnomade.org/forum/viewtopic.php?f=82&t=2116&start=585
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/3270#post_9891160
  • 1 year later...
