Posté(e) (modifié)
Voilà la nouvelle Rom Sense portée par l'équipe BeatMod Rom Developpement (sujet d'origine sur XDA)
Pour ceux dont la plupart des termes paraissent obscurs, allez voir le lexique du forum : ici
Infos
Rom Sense 3.6 sous Android 4.0.3 portée de la Rom pour HTC Sensation
Détails de la Rom
Base Sensation
Sense 3.6
Android 4.0.3
XxXPachaXxX Kernel
Advanced power menu (thx capy)
Custom Bootanimation
Ad-Free
Speed tweaks
Ext4 Support
Rooted
Busybox
Deodexed
Removed useless things
Multilanguages
Added some apps
Good Support ^_^
Attention, la Rom n'est pas totalement fonctionnelle : en vert ça fonctionne, en rouge non.
Call
SMS / MMS
Data
Wifi
Audio
Touchscreen
GPS
Acclerometer
Flashlight
Touchkey
Keylights
SDCard
GPU acceleration (2D et 3D)
Microphone
USB Mounting
probaply more...
Camera
Bluetooth
more...
Changelog
3.1 XL
Added Advanced power menu (thx j4n87)
Added Advanced Quick Settings + leedroid tweaks (thx j4n87)
Desire z & Mytouch4G boot problem fix
Inspire 4G wifi + sound fix
Desire z rotation fix (may cause problems with APM)
Anciennes versions
3.0 XL
Added device support for:
*Desire S
Desire Z
Mytouch4G
Changed ace kernel to lord -Inspire 4G audio fix
2.1 XL
Notification LED fix
Beats fix (thanks to lyapota)
SRS & Dolby (ported from sensation XE)
Included Qualcoms new Adreano drivers
Included Inspire and Telus sound fix (not tested yet)
Added/fixed USB Mount app
Updated flashplayer
2.0 XL
fixed wifi
fixed bluetooth(not tested, you tell me)
improved UI with Ultrasmooth Rosie
changed kernel to MDJ-AOSP-ICS-V 5
credits to virtuous team for wifi and bluetooth
1.0 XL
Updated base to runny
All fixes from ealier
releasesUpdated Ramdisk
data/app_s support
smartbeat downanimation
Data fix
GPS fix
Beats dosent work
0.3
Full audio fix by memnoc
Full working beats by bich0n
Working microphone during calls
Music player fix
Fixed root and busybox
Added more resized apps
Some minor changes
0.2
Advanced power menu fix
Updater-script edits
Build.prop edits
Ramdisk edits
/data/local support
updated hosts
added some 3rd party apps
handsfree speaker 100% working during calls
0.1
initial release
Téléchargements
Pour installer la Rom
Regardez ici, tout est expliqué
Crédits
Capychimp for base and much help
dexter
diamondback
chrisch1974
m-deejay
lordclockan
Modifié par grand sir tagada
je trouve juste dommage l'apellation sense 3.6 qui n'existe pas mais sinon c'est un projet prometteur en esperant qu'il aille à therme, car 4 des developpeur son des habituer du "je fini jamais mes roms", donc wait and see
Je suis assez d'accord, j'attendais une rcmix aboutie du dev principal mais il a arrêté pour faire une nouvelle rom ... enfin bon.
Si ils mènent à bout ce projet ça sera pas mal le résultat je pense.
Mon seul soucis avec c'est que les racourcis du lockscreen ce sont les icônes du dock obligatoirement ...
C'est surtout zFr3eak qui avait commencé ICS (celui de LM) pour arrêter peu après ^^ Mais bon, voir Capychimp, m-deejay et lordclockan est rassurant.
@grand sir tagada : tu peux toujours prendre une application faisant office de lockscreen ;)
oui je sais bien t'en fais pas j'en ai sous le coude niveau personnalisation (cf ma dropbox dans ma signature) ;)
mais le problème c'est que justement c'est un des trucs que j'aime le plus dans les roms sense, le lockscreen :P et j'ai pas forcement les mêmes trucs dans mon dock que dessus ... mais bon.
en tout cas perso je vais attendre que la data et la wifi soient fixés pour installer ;)
Je tourne avec LiveLocker comme lockscreen que je trouve magnifique et dont les features sont opti (notamment avec la possibilité de changer les modes volumes directement dessus, appareil photo/galerie, + 3 appli basique, et la possibilité en option d'afficher un dock pour d'autres raccourcis encore) ;)
Sinon il y a Go Locker où tu pourrais trouver un thème Sense, mais je ne sais pas ce qu'il vaut.
Clair qu'il faut attendre pour flasher ^^
"temporarily closing this thread, cant explain more right now...."
-_- Maintenant va falloir que vous suiviez de près sa ré-ouverture haha
C'est dommage parce que je l'ai testé et elle est fluide mais bon, on peut rien faire avec donc bon ...
J'vais finir par ne même plus regarder ce que va poster zFr3eak, deuxième fois qu'il "abandonne" un projet en cours. Il a le mérite d'apporter les nouveautés avant les autres, mais bon quand même :)
[26 Feb] SmartBeat Supremacy || Android 4.0.3 || Sense 3.6 || Sensation Port
version 0.3
vers 0.3
