Vincent56 Posté(e) 2 mars 2012 Posté(e) 2 mars 2012 Here I bring you a CM7 based MIUI port, that’s why I call it Mix & Match. The base of this ROM is CM 7.2 (Ice Armor III by kelzsoca). The MIUI part is mainly ported from a MIUI port for Blade, made by andalululu. According to the author it's complied from MiCode's Patchrom and also based on CM7. MIUI Mix &Match V0.1 beta Dowload Link Flash order: 1. boot into clockwork recovery 2. wipe data/factory reset 3. install .zip from sdcard 4. reboot and enjoy the new ROM! Notes: Mix & Match Rom can fit a 130M System, 2M Cache partition layout. Latest version of superuser and Ti backup are installed in data partition, thus it can be easily updated in the future. No Gapps (Gmail, maps, talk etc.) are preinstalled. You can just download any gapps you want from the market. Working MIUI features: Launcher Notifications/Toggles/Lock MIUI themes manager Dialer/contacts Sms Music FileManager DownloadProvider Camera Note Compass Soundrecorder Known issues: Since andalululu only built a partial MiUI port for blade, some interfaces in Mix & Match ROM remain in CM7 as well, like Settings, calling, and so on. Some sceenshots: Credits Kelzsoca andalululu MIUI team CyanogenMod team This post has been edited by xiaoyaoswim Je l"ai installée ce matin...marche bien possibilité de telecharger les themes pas de soucis detectes pour le moment la V0.2 devrait arriver tres prochainement... Lien pour Gapps non fourni dans la rom: http://goo-inside.me/gapps/gapps-gb-20110828-signed.zip Lien vers quelques superbes themes: http://forum.xda-developers.com/showthread.php?t=1344051 origine : http://android.modaco.com/topic/352083-rom-miui-mix-match-v01-beta/ Citer
gil21 Posté(e) 3 mars 2012 Posté(e) 3 mars 2012 Bonjour, Sur un SKATE nu en 2.3.4 je suis obligé de faire une partition pour avoir 130M System, 2M Cache partition layout. sur le phone ? merci Citer
Vincent56 Posté(e) 4 mars 2012 Auteur Posté(e) 4 mars 2012 non ....perso je suis en 200Mb system,35 cache et 205appli 1 Citer
jp33 Posté(e) 4 mars 2012 Posté(e) 4 mars 2012 Il faut une partition system de 130Mo. Pour le cache, comme elle est basée sur une Cyanogen, elle se contente d'un cache de 2Mo. Moralité, les 4 Roms TPT disponibles sur le Wiki sont compatibles. Si vous restez avec vos partitions d'origines, cela fonctionnera également. 1 Citer
Vincent56 Posté(e) 4 mars 2012 Auteur Posté(e) 4 mars 2012 v0.2 en ligne... MIUI Mix &Match V0.2 beta Dowload Link Flash order: 1. boot into clockwork recovery 2. wipe data/factory reset 3. install .zip from sdcard 4. reboot and enjoy the new ROM! Changelog V0.2 beta 2/3/2012 FIX music app (Thanks andalululu) FIX MIUI Theming improved (Thanks andalululu) FIX headphone button control (Thanks Kelzsoca ) NEW MIUI official black theme included NEW Dspmananger 1 Citer
kecoyote Posté(e) 4 mars 2012 Posté(e) 4 mars 2012 (modifié) Que vois-je? Enfin des menus à fonds blancs ou beiges! Quel bonheur! Alors, finis les écrans noirs et verdâtres pourris des terminaux Android? Je ne sais pas ce que vaut cette rom, mais rien que pour ça, je l'essaye dès que j'ai 5 minutes... EDIT: Essayée et adoptée sans problème. Menus et dialer / contacts beiges et blancs. C'est très beau, par rapport aux ROM habituelles. De nouvelles options pour l'appareil photos. Le tout fonctionne plutôt bien et de nombreux thèmes existent pour l'adapter à vos goûts. Sur mon staraddict par contre, j'ai dû modifier un peu le generic.kb pour inverser les touches home et menu... Voilà, que du bon pour moi... Modifié 6 mars 2012 par kecoyote Citer
Vincent56 Posté(e) 11 mars 2012 Auteur Posté(e) 11 mars 2012 la version v0.41 est arrivée... lien d'origine: http://android.modaco.com/topic/352083-rom-miui-mix-match-v041-beta/ tous les crédits vont à xiaoyaoswim Current version: MIUI Mix &Match V0.41beta (No need to wipe if you are updated from v0.3 or v0.4) Download link 115.com mirror Flash order: 1. boot into clockwork recovery 2. wipe data/factory reset 3. install .zip from sdcard 4. reboot and enjoy the new ROM! Changelog 0.41 beta Download link 10/3/2012 FIX Remove XLoud Engine to make the music player work normally v0.4 beta Download link 10/3/2012 FIX Mobile network setting bug (Thanks to andalululu) NEW Sony XLoud Engine - supposed to enhance the volume/sound quality (Thanks to solidchips) Other minor corrections v0.3 beta Download link 9/3/2012 NEW MIUI phoning interface has been ported (Thanks to andalululu) FIX Inproved MIUI launcher/theme: The UI should be smoother and of less FC (Thanks to andalululu) NEW UpdatedAdreno EGL Graphics libs to improve 3D performance (Thanks to C3C0) NEW MIUI gallery added (Thanks to Dirtburgler) NEW CM screenshot has been enabled, as you can access it by long press Power button when notification bar is set as 'compact' NEW MIUI official blue theme included instead of the black one for better visibility; also an examinationEX theme All pre-installed apps are updated to the latest versions Other minor corrections V0.2 beta Dowload Link 2/3/2012 FIX music app (Thanks to andalululu) FIX MIUI Theming improved (Thanks to andalululu) FIX headphone button control (Thanks to Kelzsoca ) NEW MIUI official black theme included NEW Dspmananger V0.1 beta Dowload Link 1/3/2012 Initial realease Notes: 1.Mix & Match Rom can fit a 130M System, 2M Cache partition layout. 2.Latest version of superuser and Ti backup are installed in data partition, thus it can be easily updated in the future. 3.No Gapps (Gmail, maps, talk etc.) are preinstalled. You can just download any gapps you want from the market. 4.If you encounter problems of launcher force close /laggy, please try the following setting: MENU button->Launcher settings->Turn off the Icon shadow option 5.By long pressing the ". . ." sign on the top right corner of the third sceenshot, you'll be able to access further notification bar options. And if the toggles style is set to 'compact', you could access CM restart and screenshot menu when long pressing Power button. Working MIUI features: Launcher Notifications/Toggles/Locksceen MIUI themes manager Dialer/contacts Sms Music FileManager DownloadProvider Camera Note Compass Soundrecorder Phoning(new in v0.3) gallery (new in v0.3) Known issues: 1.Since andalululu has only built a partial MiUI port for blade, some interfaces in Mix & Match ROM remain in CM7 as well, like Settings, calling, and so on. 2.Native WiFi hotspot is not working, please use external apps. 3.The launcher and/or theme is not absolutely stable. 4.There are occasional reboots when mounting USB storage. 5.The notification bar cannot be themed, wil stay in the original white background. Some sceenshots: Credits andalululu Kelzsoca & apeelme MIUI team CyanogenMod team This post has been edited by xiaoyaoswim Citer
benjy02 Posté(e) 11 mars 2012 Posté(e) 11 mars 2012 Par-contre la rom n'est pas totalement en français ? Citer
kecoyote Posté(e) 11 mars 2012 Posté(e) 11 mars 2012 Je peux vous dire que la v0.2 etait toute en français. Pas eu le tps d'installer la v0.4 mais ca doit etre pareil je suppose Citer
shangalisto Posté(e) 11 mars 2012 Posté(e) 11 mars 2012 D'une version a l'autre on regresse rarement en general :P Citer
kecoyote Posté(e) 13 mars 2012 Posté(e) 13 mars 2012 Ca y est. Je l'ai installée. Très belle interface pour passer des appels: terminée la page d'appel moche de CM7. A part ca, certains petits détails restent en anglais mais rom bien francisée ds l'ensemble. Citer
benjy02 Posté(e) 13 mars 2012 Posté(e) 13 mars 2012 Kecoyote est t'elle fonctionnel à 100 % ? L'appareil photo ? Musique ? Internet ? Des bug ? Citer
kecoyote Posté(e) 14 mars 2012 Posté(e) 14 mars 2012 (modifié) Oui, fonctionnelle à 100 %. Appareil photo ok, avec de nouvelles fonctions par rapport à mon ancienne rom (cyanostaraddict): anti-tremblement, retardateur.... Musique ok, mais pas trop testé encore. Internet Nickel. Par contre la Gallery fournie avec est celle de MIUIU et je la trouve moche. Pas grave, j'en utilise de toutes facons une autre, trouvée sur le market, et très belle... En ce qui me concerne en tout cas j'ai adopté cette ROM definitivement. Le seul truc destabilisant c'est que comme sur toutes les MIUII il n'y pas d'app drawer (repertoire des applications). Un peu destabilisant au debut mais en fin de compte je prefere ce systeme qui me rappelle bcp celui de mon Iphone. EN plus, possibilité de créer des dossiers pour ranger les apps, et un launcher d'origine un peu style GoLauncher, qui propose des animations lors du passage d'une page à l'autre.... Voilà, voilà. Bref, j'aime bcp. Modifié 14 mars 2012 par kecoyote Citer
glooobule Posté(e) 15 mars 2012 Posté(e) 15 mars 2012 En cours de test depuis hier, je suis agréablement surpris de trouver MIUI en Fr. Enfin pratiquement en Fr car on rencontre encore de l'anglais dans les menus voir même du chinois :) Sinon c'est plutôt réactif. J'attends de voir pour la gestion de la batterie, à comparer avec la R8. Citer
kecoyote Posté(e) 15 mars 2012 Posté(e) 15 mars 2012 (modifié) Version 0.5 dispo depuis hier. Support de Draktremor: 0.5 beta Download link 14/3/2012 NEW Added Darktremor support. Now you can install Darktremor Apps2SD to move apps to SD card. In additon reboot when mounted USB storage can be prevented by creating an EXT partition on SD card. FIX Apps not working including Google shopper,Netwest/RBS,line,whatsapp,and tuenti. FIX Notification area now can be themed (Thanks to 夢の終わり) FIX Chinese name display of mobile network carrier. NEW Added Chinese language for MIUI gallery Modifié 15 mars 2012 par kecoyote Citer
gil21 Posté(e) 15 mars 2012 Posté(e) 15 mars 2012 oui mais encore////////// dispo en FR ou pas ? Citer
Vincent56 Posté(e) 15 mars 2012 Auteur Posté(e) 15 mars 2012 Version 0.51 dispo et oui pour le français 1 Citer
shangalisto Posté(e) 15 mars 2012 Posté(e) 15 mars 2012 Si les autres versions sont en français...elle aussi. Citer
isbert Posté(e) 15 mars 2012 Posté(e) 15 mars 2012 Bonjour, ou peut on télécharger cette Version 0.51. Merci de la réponse. Citer
isbert Posté(e) 16 mars 2012 Posté(e) 16 mars 2012 Bonjour, Quand je passe un appel le téléphone s'énteint et il faut enlerver la battrerie pour l'allumer. Quand je recois un appel, j'ai un message d'erreur "le processus com.android.phone s'est interrompu de facon inopinée. Merci de réessayer (Forcer la fermeture)". Merci d'avance pour les astuces si vous en avez. Citer
shangalisto Posté(e) 16 mars 2012 Posté(e) 16 mars 2012 T'as installé la ROM correctement (sans louper d'étapes) ? Citer
yannliep Posté(e) 16 mars 2012 Posté(e) 16 mars 2012 Bonjour à tous, je travaille actuellement sur la traduction totale de la rom, donc si le responsable m'en donne l'autorisation elle sera disponible dans les jours qui suivent Citer
