Salut a tous!
J'ai tente de deverouiller le bootloader du x10 en utilisant flashtool 0.6.8, j'ai clique sur le menu "unlock bootloader" et appuye sur 'run' et j'ai suivi la procedure du flash mode.
Seulement, au moment de l'installation, il est inscrit en rouge:
drivers need to be installed for connected device.
you can find themin the drivers folder of Flashtool.
J'ai pourtant installe les drivers!!!
Pourquoi ca marche pas???
J'ai reessaye, et reinstalle les drivers. cette fois, il me met:
canceled.
C'est quoi. ca ?
la voila:
11/004/2012 10:04:03 - INFO - <- This level is successfully initialized
11/004/2012 10:04:04 - INFO - Flashtool Version 0.6.8.0 built on 2012-02-26 19:26:25
11/004/2012 10:04:04 - INFO - You can drag and drop ftf files here to start flashing them
11/004/2012 10:04:18 - INFO - Device connected with USB debugging on
11/004/2012 10:04:18 - INFO - Connected device : X10
11/004/2012 10:04:18 - INFO - Installed version of busybox : BusyBox v1.18.4 (2011-03-20 15:16:04 CDT) multi-call binary.
11/004/2012 10:04:18 - INFO - Android version : 2.3.5 / kernel version : 2.6.29-00054-g5f01537
11/004/2012 10:04:19 - INFO - Remounting system read-write
11/004/2012 10:04:19 - INFO - Installing toolbox to device...
11/004/2012 10:04:19 - INFO - Pushing C:\Documents and Settings\xp\My Documents\Flashtool\custom\root\ftkit.tar to /data/local/tmp
11/004/2012 10:04:19 - INFO - Running installftkit as root thru sysrun
11/004/2012 10:04:20 - INFO - Root Access Allowed
11/006/2012 10:06:27 - INFO - Please connect your device into flashmode.
11/006/2012 10:06:31 - INFO - Device disconnected
11/006/2012 10:06:57 - INFO - Opening device for R/W
11/006/2012 10:06:57 - WARN - Cancelled
11/006/2012 10:06:58 - ERROR - Drivers need to be installed for connected device.
11/006/2012 10:06:58 - ERROR - You can find them in the drivers folder of Flashtool.
11/007/2012 10:07:01 - INFO - Device connected in flash mode
11/007/2012 10:07:08 - INFO - Device disconnected
11/008/2012 10:08:31 - ERROR - Drivers need to be installed for connected device.
11/008/2012 10:08:31 - ERROR - You can find them in the drivers folder of Flashtool.
11/008/2012 10:08:33 - INFO - Device connected in flash mode
11/008/2012 10:08:38 - INFO - Device disconnected
11/010/2012 10:10:50 - ERROR - Drivers need to be installed for connected device.
11/010/2012 10:10:50 - ERROR - You can find them in the drivers folder of Flashtool.
11/011/2012 10:11:20 - INFO - Device connected with USB debugging on
11/011/2012 10:11:20 - INFO - Connected device : X10
11/011/2012 10:11:20 - INFO - Installed version of busybox : BusyBox v1.18.4 (2011-03-20 15:16:04 CDT) multi-call binary.
11/011/2012 10:11:20 - INFO - Android version : 2.3.5 / kernel version : 2.6.29-00054-g5f01537
11/011/2012 10:11:20 - INFO - Root Access Allowed
11/012/2012 10:12:40 - INFO - Device connected with USB debugging on
11/012/2012 10:12:40 - INFO - Connected device : X10
11/012/2012 10:12:40 - INFO - Installed version of busybox : BusyBox v1.18.4 (2011-03-20 15:16:04 CDT) multi-call binary.
11/012/2012 10:12:40 - INFO - Android version : 2.3.5 / kernel version : 2.6.29-00054-g5f01537
11/012/2012 10:12:40 - INFO - Root Access Allowed
je ne suis plus en 2.3.3, c'est vrai, mais mon tel est bien reconnu normalement. je suis sous xp.
c'est fait. j'ai réessaye avec la wb 2.3.3...
sans succès, il affiche toujours WARN - Canceled.
mode debuggage et source inconnues sont bien désactivé. il faut être en 2.1 pour déverrouiller avec s1tool...
