Vincent56 Posté(e) 31 mars 2012 Share Posté(e) 31 mars 2012 (modifié) Merci tilal6991 lien: http://android.modac...m-updated-3003/ ROM details: MIUI v4 2.2.30 Ice Cream Sandwich 4.0.3 2.6.35 kernel - based if ZTE source ROM sources - https://github.com/MIUIFusionX Thanks to: Everyone who helped me with ColdFusion MIUI team - thanks for a great ROM! FLASH ORDER: First you'll need to TPT your phone to a layout that gives you at-least 185 MB space on the system partition. You can get TPTs and instructions on how to flash them here Second: you should get the ROM and put it on your SD card Now FORMAT SYSTEM <- VERY IMPORTANT Then flash the ROM After this wipe data Then reboot out of recovery and let it boot into the ROM After you let it sit on the launcher for ~ 5 minutes and you're done! If you still have problems post on the thread. Download Link: Download - 30/03/2012 - http://goo.im/devs/t...kate-signed.zip Changelog: 30/03/2012: Initial release Based on ColdFusionX 30/03/2012 Functionality: Working: WiFi Full Hardware Acceleration with OpenGL Smooth UI Mobile data 2G and 3G Network Audio Sensors Live Wallpapers Hardware video decoding - slightly choppy but working USB Mass Storage Camera YouTube - LQ USB tethering - Use an external app WiFi tethering - Use an external app Everything Else apart from stuff below Partially Working: Youtube - HQ is laggy Reboot menu is messed up - should be fixed in the next release Not Working: Bluetooth Panorama in camera Video recording Modifié 31 mars 2012 par Vincent56 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
kaulex54 Posté(e) 3 avril 2012 Share Posté(e) 3 avril 2012 Bonjour, et merci pour cette ROM, mais j'ai un petit soucis, quand je veux déverrouiller l'écran la ROM reboot ... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
alex_02 Posté(e) 3 avril 2012 Share Posté(e) 3 avril 2012 C'est quoi l'interet de faire des ROM sans bluetooth... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
shangalisto Posté(e) 4 avril 2012 Share Posté(e) 4 avril 2012 Le bluetooth est loin d'être important pour une grande partie des utilisateurs et encore plus lorsqu'il s'agit de faire fonctionner la ROM, si il n'y est pas, c'est pas par bonne volonté, c'est que sa pose des problèmes avec ICS (je rappelle que les constructeurs balancent aucune librairies ni rien pour aider les devs' et ZTE en fait parti jusqu'à preuve du contraire) donc tout comme la caméra, sa sera régler en partie mais pour l'instant faut attendre... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
