FabienHuet Posté(e) 4 avril 2012 Share Posté(e) 4 avril 2012 Bonjour bonjour ! j'ai un petit soucis quand je veut recompiler un fichier apk. voici le message que j'obtient : C:\ADB>apktool b settings W: Could not find sources I: Checking whether resources has changed... I: Building resources... C:\ADB\settings\res\values\strings.xml:16: error: Apostrophe not preceded by \ (in Appel d'urgence seulement) C:\ADB\settings\res\values\strings.xml:106: error: Apostrophe not preceded by \ (in une application demande d'activer le blue tooth, voulez vous le faire ?) C:\ADB\settings\res\values\strings.xml:123: error: Apostrophe not preceded by \ (in Changer l'heure) C:\ADB\settings\res\values\strings.xml:153: error: Apostrophe not preceded by \ (in redirection d'appele:) C:\ADB\settings\res\values\strings.xml:161: error: Apostrophe not preceded by \ (in statut de l'appele:) Exception in thread "main" brut.androlib.AndrolibException: brut.common.BrutException: could not exec command: [aapt, p, -F, C:\Users\deve\AppData\Local\Temp\APKTOOL6825448384241829995.tmp, -I, C:\Users\deve\apktool\framework\1.apk, -S, C:\ADB\settin gs\res, -M, C:\ADB\settings\AndroidManifest.xml] at brut.androlib.res.AndrolibResources.aaptPackage(AndrolibResources.java:193) at brut.androlib.Androlib.buildResourcesFull(Androlib.java:301) at brut.androlib.Androlib.buildResources(Androlib.java:248) at brut.androlib.Androlib.build(Androlib.java:171) at brut.androlib.Androlib.build(Androlib.java:154) at brut.apktool.Main.cmdBuild(Main.java:182) at brut.apktool.Main.main(Main.java:67) Caused by: brut.common.BrutException: could not exec command: [aapt, p, -F, C:\Users\deve\AppData\Local\Temp\APKTOOL682544838 4241829995.tmp, -I, C:\Users\deve\apktool\framework\1.apk, -S, C:\ADB\settings\res, -M, C:\ADB\settings\AndroidManifest.xml] at brut.util.OS.exec(OS.java:83) at brut.androlib.res.AndrolibResources.aaptPackage(AndrolibResources.java:191) ... 6 more savez vous d'où viens l'erreur ? ca fait un moment que je cherche et là j'ai la tête qui va exploser !! Lien vers le commentaire Partager sur d’autres sites More sharing options...
oqs Posté(e) 24 avril 2012 Share Posté(e) 24 avril 2012 il ne manque pas un backslash devant une apostrophe dans ton strings.xml? Lien vers le commentaire Partager sur d’autres sites More sharing options...
