comment activer et désactiver une application android?
je voudrais développer un code qui me renvoyer a
u "img1"(image1) losque je clique sur" img"(image) et qui va afficher un QuickAction en executant img1. le problème ici donc c'est qu'il m'afficher seulement (image1) et le QuickAction ,je voudrais faire la liaison entre image 1 et image 2
et merci d'avance pour votre réponse !
voici mon code,
[/color]
[color=#000000]package com.android.com;[/color]
[color=#000000]import android.app.Activity;
import android.os.Bundle;
import android.view.View;
import android.view.View.OnClickListener;
import android.widget.ImageView;
import android.widget.TextView;[/color]
[color=#000000]public class DesactivateActivity extends Activity implements OnClickListener{
/** Called when the activity is first created. */
// action id
private static final int ID_UP = 1;
private static final int ID_DOWN = 2;
private static final int ID_SEARCH = 3;
QuickAction quickAction;
@Override
public void onCreate(Bundle savedInstanceState) {
	super.onCreate(savedInstanceState);
	setContentView(R.layout.main);[/color]
[color=#000000]	 ActionItem appel = new ActionItem(ID_DOWN, "Appeler", getResources()
	.getDrawable(R.drawable.call));
  ActionItem sms = new ActionItem(ID_UP, "Envoyer message",
	getResources().getDrawable(R.drawable.sms));
  ActionItem fermer = new ActionItem(ID_SEARCH, "Arreter application",
	getResources().getDrawable(R.drawable.ferme));[/color]
[color=#000000]	  final QuickAction quickAction = new QuickAction(this,QuickAction.VERTICAL);[/color]
[color=#000000]	  // add action items into QuickAction
  quickAction.addActionItem(appel);
  quickAction.addActionItem(sms);
  quickAction.addActionItem(fermer);
	ImageView img=(ImageView)this.findViewById(R.id.imageView1);
	setContentView(R.layout.main1);
	ImageView img1=(ImageView)this.findViewById(R.id.imageView1);
	img.setOnClickListener(this);
	img.setOnClickListener(new View.OnClickListener() {[/color]
[color=#000000]	  @Override
  public void onClick(View v) {
   // TODO Auto-generated method stub
  });[/color]
[color=#000000]		img1.setOnClickListener(new View.OnClickListener() {
	 public void onClick(View arg0) {
	  quickAction.show(arg0);[/color]
[color=#000000]		 }});
@Override
  [/color]
[color=#000000]}
Modifié par tuto
pouvez vous me proposer une solution efficace!!
j'ai établie le passage entre image1 et image ,mais je ne sais pas comment appliquer un listener sur image 2 pour que je puisse afficher le quickaction,il y a un probleme au niveau de listener de image 2 qui est dans un autre main.xml et merci d'avance pour votre reponse
Modifié par tuto
Deja on dit pas donne moi, c'est malpoli.
Ensuite, tu as des yeux, tu sais lire apparement ? Et ben tu prend 2 minutes, tu regarde la liste des sections un peu plus loin que le premier lien, et tu trouvera la section consacré aux devs ...
Les jeunes, de nos jours, faut leur faire tout le boulot a leur place...
Ce sujet ne peut plus recevoir de nouvelles réponses.
