[Résolu] Creer une base de données sur la SD Card
Bonjour
J'essaye de créer une base de données sur la SD Card mais je n'y arrive pas. Voilà mon code :
    public class DatabaseHelper extends SQLiteOpenHelper {
       Context    context;
       public DatabaseHelper(Context context) {
           super(context, "/sdcard/my_folder/my_base", null, 1);
           this.context = context;
       @Override
       public void onCreate(SQLiteDatabase db) {
       @Override
       public void onUpgrade(SQLiteDatabase db, int oldVersion, int newVersion) {
Le LocCat me retourne cela :
08-26 16:44:37.477: ERROR/AndroidRuntime(23576): Uncaught handler: thread main exiting due to uncaught exception
08-26 16:44:37.477: ERROR/AndroidRuntime(23576): java.lang.RuntimeException: Unable to start activity ComponentInfo{ts.S9000.planning_exterieur/ts.S9000.planning_exterieur.Libelles}: java.lang.IllegalArgumentException: File /sdcard/technic-soft/planning_exterieur/libelles contains a path separator
08-26 16:44:37.477: ERROR/AndroidRuntime(23576): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2496)
08-26 16:44:37.477: ERROR/AndroidRuntime(23576): at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2512)
08-26 16:44:37.477: ERROR/AndroidRuntime(23576): at android.app.ActivityThread.access$2200(ActivityThread.java:119)
08-26 16:44:37.477: ERROR/AndroidRuntime(23576): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1863)
08-26 16:44:37.477: ERROR/AndroidRuntime(23576): at android.os.Handler.dispatchMessage(Handler.java:99)
08-26 16:44:37.477: ERROR/AndroidRuntime(23576): at android.os.Looper.loop(Looper.java:123)
08-26 16:44:37.477: ERROR/AndroidRuntime(23576): at android.app.ActivityThread.main(ActivityThread.java:4363)
08-26 16:44:37.477: ERROR/AndroidRuntime(23576): at java.lang.reflect.Method.invokeNative(Native Method)
08-26 16:44:37.477: ERROR/AndroidRuntime(23576): at java.lang.reflect.Method.invoke(Method.java:521)
08-26 16:44:37.477: ERROR/AndroidRuntime(23576): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:860)
08-26 16:44:37.477: ERROR/AndroidRuntime(23576): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:618)
08-26 16:44:37.477: ERROR/AndroidRuntime(23576): at dalvik.system.NativeStart.main(Native Method)
08-26 16:44:37.477: ERROR/AndroidRuntime(23576): Caused by: java.lang.IllegalArgumentException: File /sdcard/technic-soft/planning_exterieur/libelles contains a path separator
08-26 16:44:37.477: ERROR/AndroidRuntime(23576): at android.app.ApplicationContext.makeFilename(ApplicationContext.java:1444)
08-26 16:44:37.477: ERROR/AndroidRuntime(23576): at android.app.ApplicationContext.openOrCreateDatabase(ApplicationContext.java:472)
08-26 16:44:37.477: ERROR/AndroidRuntime(23576): at android.content.ContextWrapper.openOrCreateDatabase(ContextWrapper.java:193)
08-26 16:44:37.477: ERROR/AndroidRuntime(23576): at android.database.sqlite.SQLiteOpenHelper.getWritableDatabase(SQLiteOpenHelper.java:98)
08-26 16:44:37.477: ERROR/AndroidRuntime(23576): at ts.S9000.DB.DBAdapter.open(DBAdapter.java:39)
08-26 16:44:37.477: ERROR/AndroidRuntime(23576): at ts.S9000.planning_exterieur.Libelles.onCreate(Libelles.java:52)
08-26 16:44:37.477: ERROR/AndroidRuntime(23576): at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1047)
08-26 16:44:37.477: ERROR/AndroidRuntime(23576): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2459)
08-26 16:44:37.477: ERROR/AndroidRuntime(23576): ... 11 more
A priori il ne faut pas de "/" dans le nom de la base... Comment faire alors pour créer cette base sur la SD Card ?
Merci d'avance
J'ai réussi à trouver.... Voici comment j'ai défini ma classe DatabaseHelper :
       String NAME_DB;
       String PATH_DB;
       Context    context;
       public DatabaseHelper(Context context, String _pathDB, String _nameDB) {
           super(context, _nameDB, null, 1);
           NAME_DB = _nameDB;
           PATH_DB = _pathDB;
       @Override
       @Override
       public SQLiteDatabase openDataBase() throws SQLException{
           boolean continu = true;
           SQLiteDatabase dbRetour = null;
           try {
               if (!checkDataBase()) {
                   SQLiteDatabase dbCreate = SQLiteDatabase.openOrCreateDatabase(PATH_DB + NAME_DB, null);
                   if (dbCreate != null) {
                       dbCreate.execSQL("create table my_table (_id integer primary key autoincrement, col1 text not null);");
                       dbCreate.close();
                   } else
                       continu = false;
               if (continu)
                   dbRetour = SQLiteDatabase.openDatabase(PATH_DB + NAME_DB, null, SQLiteDatabase.OPEN_READWRITE);
           } catch (Exception e) {
           return dbRetour;
       private boolean checkDataBase() {
           SQLiteDatabase checkDB = null;
           try{
               checkDB = SQLiteDatabase.openDatabase(PATH_DB + NAME_DB, null, SQLiteDatabase.OPEN_READONLY);
           }catch (SQLiteException e) {
               //database does't exist yet.
           if (checkDB != null)
               checkDB.close();
           return checkDB != null ? true : false;
