Posté(e) (modifié)
Voici la Foliomod by Dexter, un membre actif du fameux forum XDADEVELOPER
CHANGELOG
v1.4
  1. libraries from v 2.2.5.0131 release of 18-feb-2011
  2. eUpdate patch from stock release of 18-feb-2011 (touchscreen+i2c update)
  3. Paid apps working. (thanks to weeds2000 for the fix)
  4. rotation & mouse (fixed by Weeds2000)
  5. Fixed toshiba pegadroid support (ext.jar missing pegadroid service), important for toshiba services.
  6. added newest Market app (2.2.11)
  7. 3D frame hack (increased framerate from 51 to 70), if you got touchscreen issues, here is the rollback patch
  8. BROKEN: 3G support (new toshiba kernel required for display driver, and we got no source available yet)
  9. BROKEN: CIFS support
  10. Filesystem optimization still active
  11. newest flashplayer v10.1.120.10 included.
  12. newest mediaplayer & filemanager update from toshiba.
  13. Maps 5.0 added with multitouch rotation support
  14. build.prop changed to emulate GalaxyTab (tablet Market support with more apps)
  15. NOTE: Name is written as SGH-T849 (please just ignore, forum reports will be ignored too)
  16. HDMI option added in Settings, for option to switch between 480p,576p,720p,1080p
  17. note: tablet is still just 1024x600, so desktop is scaled, movieplayback should be correct.
  18. 360 degree rotation
  19. settings - gapps sync enabled
  20. deodex'd
  21. wpa supplicant (adhoc) support (use FolioWidget to enable)
  22. Added WMA/WMV support (upto 1080p)
  23. Fixed Wifi script issues
  24. Fixed /mnt/sdcard mount location (apps issue, better support now)
  25. Root'd (Superuser + su included)
  26. Rooted recovery + busybox tools
  27. increased main filesystem (252MB)
  28. SpareParts (disable "compatibility mode" to have old apps fullscreen.
  29. Taskkiller included (Fixed for Toshiba framework)
  30. More Locale 2 included (so all languages can be selected)
  31. BROKEN: NTFS / CIFS / 3G support will be enabled as soon as a kernel source update is available, so DerArtem can compile a working kernel for us.
Installation: (mis à jour le 05 Avril 2011)
Ne faites ces manipulation uniquement qu'avec le chargeur branché
Pré-requis :
A- Une carte SD formatée en FAT32
B- Un PC avec lecteur de Carte SD
C- La dernière version de la ROM FolioMod v1.4 by Dexter
Etape 1 : Mettre le nouveau firmware sur la carte SD
- Décompressez le fichier zippé FolioModv14.zip sur votre PC , vous aurez un autre fichier nommé update.zip, ce fichier est le nouveau firmware de votre Folio à mettre à la racine de la carte SD.
- N’insérez pas la Carte SD dans votre tablette pour l'instant
Etape 2 (WIPE) : Effectuer un formatage de la Folio (Obligatoire avant la mise à jour)
1- Au démarrage de la tablette, quand vous avez le logo Toshiba, appuyez rapidement sur POWER et VOL+ en même temps pour entrer dans le "Recovery Menu"
2- Appuyez sur "VOL+" pour Factory reset or system update.
3- Appuyez sur "VOL-" pour "continue to system update".
4- Appuyez sur "VOL+" pour "confirm system update".
5- Appuyez sur le bouton HOME quand vous voyez un android tenant une plaque avec "!". Un menu bleu sur fond noir apparait.
6- Sélectionnez "wipe data/factory reset" à l'aide des boutons VOL- et VOL + puis valider en appuyant sur "Power" rapidement
7- Selectionnez "Yes -- Delete all user data" à l'aide des boutons VOL- et VOL + puis valider en appuyant sur "Power", votre folio entamera un formatage de sa mémoire, attention vous perdrez l'ensemble de vos données
8- Atteignez la tablette en appuyant longtemps sur le boutton Power.
Etape 3 : Appliquer le nouveau Firmware
1- Inserez la carte SD dans la tablette
2- Demarrez la tablette, quand vous avez le logo Toshiba, appuyez rapidement sur POWER et VOL+ en même temps pour entrer dans le "Recovery Menu"
3- Appuyez sur "VOL+" pour Factory reset or system update.
4- Appuyez sur "VOL-" pour "continue to system update".
5- Appuyez sur "VOL+" pour "confirm system update".
6- Le recovery de la folio va automatiquement prendre en compte le fichier update.zip et l'installé (cette installation peut prendre jusqu'a 10 min). A la fin de l’installation la folio redémarrera automatiquement . Ce redémarrage peut prendre également jusqu’à 10min sur le logo "Android"
Voila profitez de votre nouvelle ROM ;)
Pour revenir à la rom d'origine, telechargez la Folio ROM Toshiba et refaites les etapes 1 à 8 ci-dessus avec ce fichier.
Conseil : installez a partir de l'android Market et parametrez en mode stric l'application Autokiller. Cette application modifie les paramètres mémoire et rendra votre folioMod encore plus fluide.
Source : http://forum.xda-developers.com/showthread.php?p=9323923
Crédit : Dexter_nlb - Lui faire un don paypal CLIQUEZ ICI
Modifié par zizouth
Humm... Hummm....
Not Found
The requested URL /FolioModv01.zip was not found on this server
Cdlt
Stéph.
Une fois le programme téléchargé, voici la traduction de la procédure de la mise à jour.
instructions d'installation:
Copier "update.zip" dans ma libération à la racine de votre carte SD.
Insérez la carte dans folio 100 et appuyez sur power + VOL + pour commencer
système de mise à jour. suivre les directives à l'écran à partir d'ici.
Appuyez sur la touche HOME, pour voir à l'écran l'activité lors de l'installation.
v0.1
- Enraciné + superuser.apk inclus
- Utilisation de démarrage et de récupération img, qui sont la racine default / adb permis
- Ajout dernier SDK drivers de Nvidia EGL 1105 Communiqué
- Cela permet une plus grande compatibilité avec les jeux et fonds d'écran en direct
comme des oiseaux en colère & wallpapers poissons vivants comme exemple.
- Utilisation de stock Android lanceur + Google Apps
- Inclus MarketEnabler, de sorte que vous pouvez obtenir toutes les applications visibles.
- Problème connu du marché possible - seulement 10-15 applications énumérées
Bien que le nombre d'applications XXXX trouvé. (Travail en cours)
- Fonction de zoom capable de package par défaut Nvidia.
- Flash NON inclus, comme nécessaire pour le moment d'installer manuellement.
- Pinyin et le clavier actions inclus.
Cordialement,
Dexter
Pour le moment je ne pense pas le faire, trop peur que ça rate
:emo_im_lips_are_sealed:
Si ça c'est un tuto en langue de Molière, ce dernier doit se retourner dans sa tombe :D
Moi j'ai rien pané (et Molière non plus).
Telechargé, installé sans erreur mais au reboot aucun changement :(
idem pour moi , ai appuyé sur power et volume + au démarrage , puis installation kernel , reboot automatique et retour à la ROM d'origine android version toshiba ...
Attention il faut dezipper le fichier téléchargé FolioModv01.zip, dedans il y a le update.zip. Apres 2 download chez moi le fichier est corrompu, j'ai demander a l'auteur de le re-uploader.
Posté(e) (modifié)
fichier FolioModv01.zip que j'ai eu non corrompu ; l'ai dézippé puis après avoir reformaté ma SD en fat 32 , mis le fichier update.zip à la racine .
redémarrage de la folio puis power+volume+ , puis chargement du kernel et après reboot à nouveau l'interface Toshiba ...
Modifié par donylandes
Posté(e) (modifié)
Je vais formaté ma carte sd alors et mettre uniquement le fichier update.zip.
il ne précise pas si on doit wipe après....
J'ai retesté et le bouton "home" sert juste à afficher les détails ... :mad:
Pourtant j'ai les infos suivantes :
Extractiong packs...
Done Extraction...
Preparing filesystem...
tun adbd
+---------start adb daemon-------+
+---------installing boot-------+
+---------installing recovery-------+
+---------extracting system-------+
+Instaling system, this takes a while
Installation done.now reboot system.
Formating MISC:...
Et après on peut juste "rebooter" ou recommencer l'opération (ou wipe peut-être :rolleyes: )
Modifié par Daek
En fait il faut faire:
power vol+
vol+ ->"continue factory data reset..."
vol- ->"continue system update"
vol+ ->"confirm"
quand la boite et l'android apparaissent appuyer sur le bouton HOME
a un moment un menu bleu apparait et on peut naviguer avec vol+ (haut) vol-(bas)
vol- ->"apply sdcard:update.zip"
bon là je suis pas très sûr mais power pour valider semble logique y a pas d'autre bouton
ensuite rock'n'roll
le systeme demande apres de redemarrer, on retombe sur le menu bleu -> "reboot system now"
voilà si quelqu'un réussi avec ça qu'il le dise j'en suis à ma 4ieme fois :P
power vol+
vol+ ->"confirm"
ensuite rock'n'roll
ok je tente une nouvelle fois ! :emo_im_angel:
Ah Dexter a trouvé le pb, il met à jour :lol:
patience !!! B)
Finalement , il ne faut pas être trop pressé ..... B)
Dexter : "problem found..
im uploading a recovery fix.. this needs to be run first, then reboot and put image update.zip on sdcard and it works..
link will be up in a moment."
Posté(e) (modifié)
le fix ( update recovery )
FIX
à renommer en update puis placer à la racine de la carte SD reformatée , et après reboot avec les procédures précédentes , la Folio sera rootée .
Et à ce moment là refaire la manip , reformater carte SD et mettre le gros fichier image original update.zip .
