Tavaicrukoi Posté(e) 5 février 2012 Share Posté(e) 5 février 2012 Bonjour, a tous, voila ce que je viens de commander en pré-commande chez Ownta : Ainol Novo7 Advanced II Voici les caractéristiques : Ainol NOVO7 Advanced II Tablet PC Specification: CPU Many Core A10 1.2GHz, 512MB DDR3 RAM GPU Mail 400 ROM 1.0GB OS Android 4.0 Display 7.0 inch, capacitive 5-point touch screen + Buttons, 800*480 pixels Memory 1GB ROM, 512MB RAM, 8GB storage memory, support MicroSD card that can expand up to 16GB Camera Built in 2.0MP Front Camera WIFI 802.11b/g/n Ethernet Support Ethernet RJ45 3G External Support E261, E353, E1750, EC122, EC189, EC167, EC150, EC156, EC1261, MF110, FM190, MF637U Music playtime About 25 hours, (Earphone, Wifi turn off) 3D Games About 6 hours Web About 7 hours Video playtime About 8 hours (Earphone) Video formats Support MOV, MKV, AVI, RMVB, RM, TS, TP, M2TS, VOB, DAT, MPEG, MP4, PMP, 3GP, FLV, WMV, ASF etc. formats Video coding H.264, H.263, VC-1, MPEG-1/2, DIVX, XVID, WMV7/8/9, WMV3, RV8/9 Video resolution Support MKV, AVI, WMV, RMVB, TS, TP, M2TS, RM, MPEG, VOB, MOV, FLV, MP4, 3GP,1920*1080P video playback, can max up to 3840*2160P Video ratio Yes, support 3D Model Yes, support Video Subtitle Support SRT, SSA, ASS, SMI, SUB, MKV etc. subtitle diaplay Audio formats Support MP3, WMA, WAV, APE, FLAC, AAC, OGG etc. formats S/N Ratio >95db Distortion <0.6% Earphone output power (L)10mw ® 10mw (32ohm) Picture Support JPG, BMP, PNG, GIF etc. picture browser E-book Support TXT, LRC, PDF, EPUB, FB2 etc. Audio recording MIC, MP3 format, can recording max up to 55 hours (8GB), 12K/24K/48K OTG Yes, support Earphone 3.5mm Earphone output HDMI Yes, support OS Win2000/XP/VISTA/Win7 Temperature -10~45℃ USB USB2.0 Battery 14WH G-sensor Yes, 3-way support Son prix : 129,99 USD Qu'en pensez-vous ?? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
djemils Posté(e) 5 février 2012 Share Posté(e) 5 février 2012 c'est une tablette qui n'est pas encor sorti! mais si c'est la remplacante de la novo7 advenced sa sera un tres bon produit! sinon pour un petit peu plus tu peut avoir une ips mais apres tout depend de l'utilisation que tu va en faire ainol c'est des bon produit Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Tavaicrukoi Posté(e) 5 février 2012 Auteur Share Posté(e) 5 février 2012 En fait je viens de commander en meme temps la Elf !! et je pense que ça devrait me suffir amplement pour l'usage que je vais en faire !! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
djemils Posté(e) 5 février 2012 Share Posté(e) 5 février 2012 pourquoi tu a pas prit la aurora? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
pablo08 Posté(e) 17 février 2012 Share Posté(e) 17 février 2012 Bonsoir, je viens de recevoir ma tablette novo 7 advanced 2, mais j'ai un petit problème, il n'y a pas d'android market sur la tablette, j'ai donc installé l'appli Apk de market mais cela ne fonctionne pas, la version d'android est ICS 4.01 et semble complètement buger. :angry: il y a aussi un bug sur l'installation d'une adresse Google, apparition de message d'erreur, je viens de faire une recherche sur le net afin de trouver une Màj. mais rien :( j’espère Ainol proposera rapidement une nouvelle version. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Tavaicrukoi Posté(e) 18 février 2012 Auteur Share Posté(e) 18 février 2012 J'attend toujours la mienne donc désolé mais peux pas te répondre pour le moment sur mon xp Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Tavaicrukoi Posté(e) 20 février 2012 Auteur Share Posté(e) 20 février 2012 Je viens de recevoir la mienne, a priori il faut la flasher en 4.0.3 comme la elf ou autres et ensuite plus de bug et surtout market ok Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
pablo08 Posté(e) 20 février 2012 Share Posté(e) 20 février 2012 Bonsoir, quelle est la procédure pour changer la rom? merci d'avance Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Tavaicrukoi Posté(e) 21 février 2012 Auteur Share Posté(e) 21 février 2012 pour le moment pas de roms officielle ni autres compatibles avec nos advanced 2... Attendons quelques jours, je suit cela de près et vous mettrais tout ici dès qu'une rom pointe le bout de son nez... Avec une procédure pour les débutants !!! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Tavaicrukoi Posté(e) 22 février 2012 Auteur Share Posté(e) 22 février 2012 Bonjour à tous, il y'a du mouvement du côté de nos tablettes apparemment mais pas encore de roms officiels juste des bétas alternatifs à ce que j'ai compris. En revanche je vous partage le lien pour les pilotes usb de la bête... http://www.mediafire.com/?1p4ln5yn2u7v5jb Merci aux auteurs !! Vérifiez que le mode débogage est activé sur votre tablette Allez dans le menu des applications Allez dans le menu Paramètres Allez dans les options pour les développeurs Vérifiez que Débogage USB est coché Télécharger le pack usb àen suivant ce lien http://www.mediafire.com/?1p4ln5yn2u7v5jb Dé-zippez le sur votre bureau Installation des drivers Branchez votre tablette à votre PC en USB Faite un clic droit sur l’icon Ordinateur (ou poste de travail pour XP) Cliquez sur Propriétés Cliquez sur Gestionnaire de périphériques Faite un double clic sur le périphérique Android Cliquez sur Mettre à jour le pilote… Cliquez sur Rechercher un pilote sur mon ordinateur Cliquez sur Parcourir… Sélectionnez le dossier Ainol Novo 7 Drivers 64Bit_win_7_vista dans le dossier que vous avez dézippé Cliquez sur OK Cliquez sur Suivant Cliquez sur Installer ce pilote quand même Une fois le pilote installé, cliquez sur Fermer et fermez les autres fenêtres Crédits et merci à Tablettedroid Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
pablo08 Posté(e) 7 mars 2012 Share Posté(e) 7 mars 2012 Bonsoir, je viens de m'appercevoir qu'il y a de nouveau sur le site de ainol, quand pensez vous! http://www.ainol.com/plugin.php?identifier=ainol&module=download bonne soirée Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
djemils Posté(e) 9 mars 2012 Share Posté(e) 9 mars 2012 vous pouvez nous faire un retour de la advenced II? ce que vous en pensez quoi? la navigationest rapide le market marche bien dessus? flash player c est ok? enfin donnez nous notre avis c est bon a savoir sa ! comme si une personne veut en acheter une et bien il poura trouver les info ici! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
pablo08 Posté(e) 11 mars 2012 Share Posté(e) 11 mars 2012 Bonsoir, Petit retour sur novo7 advenced II, cette tablette est de bonne qualité, l'autonomie est tres bonne ainsi que la finition, Actuellement, le pb est sur la version d'Android 4.01 et je commence à regretter mon choix. Cette version a beaucoup de bug pas de market enfin presque, un market chinois est présente mais la galère! Apres le paramétrage d'une adresse gmail la tablette plante. J’attends avec impatience une Màj d'une nouvelle rom, mais? les jeux fonctionne bien la vidéo est bonne. Conclusion: actuellement, si je devais refaire mon choix je prendrai une C71. bonne soirée Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
mouradk28 Posté(e) 17 mars 2012 Share Posté(e) 17 mars 2012 (modifié) Je viens de recevoir la tablette aussi; et je suis très déçu surtout que volontairement j'ai choisi celle-ci pour la version ICS! DONC TRES GROSSE DECEPTION. Je ne l'ai pas payer au prix de l Ipad certes mais il y a un minimum! Le site de ainol n'est qu'en chinois, je n'arrive pas à le traduire pour savoir s'il existe une mise jour...c'est la moindre des choses... Je viens de trouver ce lien: http://www.slatedroid.com/topic/30485-firmware-403-v303-7th-march-2012-market-and-flash/ peut on s'entraider pour trouver une issue et enfin profiter de notre tablette, je suis un débutant et l'union fait la force... Modifié 18 mars 2012 par mouradk28 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
mouradk28 Posté(e) 24 mars 2012 Share Posté(e) 24 mars 2012 finalement tant bien que mal, j ai réussi à flasher la tablette en 4.0.3 officiel de ainol... franchement pas très pratique leur site officiel en chinois qui ne se traduit pas mais grâce au lien ci-dessus en anglais, j ai réussi à m en sortir ouf mais s il fallait le refaire, je ne le saurais même pas! en tout cas google play fonctionnel, c 'est beaucoup mieux je profite réellement de ma tablette aujourd hui... merci au forum english! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
copy32816 Posté(e) 26 mars 2012 Share Posté(e) 26 mars 2012 Salut, je sais que c'est noob mais comment je fait pour la flashé en 4.0.3? J'ai télécharger le lien mais le mode d'emploi est en chinois. Merci d'avance :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
yana Posté(e) 28 mars 2012 Share Posté(e) 28 mars 2012 Bonjour, J'ai reçu hier ma tablette. j'avais le Market qui a évolué en Go Play au premier lancement avec un compte gmail paramétré. je n'ai pour le moment aucun problème avec. pour info : version android 4.0.3 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
hadaak Posté(e) 8 avril 2012 Share Posté(e) 8 avril 2012 (modifié) Bonsoir, Premier post ici :-) j'ai besoin d'un coup de main pour tester cette tablet avant de l'acheter. en fait j'ai besoin de savoir si une BD en format pdf est lisible sur cette tablet. je peux mettre en ligne (ftp) une BD en format PDF (Asterix par exemple) pour celui qui voudrait bien faire le test. Je dis ça parce que jai acheté une tablette 8 pouces sur ebay et le texte dans la BD est illisible. Merci de votre aide. Modifié 8 avril 2012 par hadaak Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Bifton Divko Posté(e) 29 avril 2012 Share Posté(e) 29 avril 2012 (modifié) salut es ce que quelqu'un peux detailler les procedures à suivre pour le flash svp Modifié 29 avril 2012 par Bifton Divko Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
MusicalBox Posté(e) 1 mai 2012 Share Posté(e) 1 mai 2012 Bonjour à tous et à toutes Quelqu'un sait comment faire des captures d'écran sur la Advanced II ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Vaz Posté(e) 1 août 2012 Share Posté(e) 1 août 2012 (modifié) Salut, J'ai acheté la tablette Ainol Novo 7 Advanced 2 sur Mychinesecost et elle me convient très bien ! Pour les capture d'écran je ne sais pas non plus dsl... a+ Modifié 24 août 2012 par Vaz Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Loriane Dumont Posté(e) 22 janvier 2013 Share Posté(e) 22 janvier 2013 up^^ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Loriane Dumont Posté(e) 25 janvier 2013 Share Posté(e) 25 janvier 2013 Allez svp répondez moi, j'en peut plus je trouve pas comment faire pour mettre l'android en francais svp, aidez moi!! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Loriane Dumont Posté(e) 25 janvier 2013 Share Posté(e) 25 janvier 2013 SVP aidez moi, je veux juste savir comment mettre l'android market en francais svp? ou aoir un truc pour télécharger des applis en francais ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Loriane Dumont Posté(e) 26 janvier 2013 Share Posté(e) 26 janvier 2013 quelqu'un peut répondre svp, pour m'aider a installer un market francais svp?? * Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
