[ROM][CM7.2] Kyrillos' ROM v10.2
Ce qui fonctionne dans la 10.1:
Kyrillos' rom v10.1 Features
  • Based on Marcellusbe's CM7.2 Alpha8 port for Galaxy3. [Android 2.3.7]
  • PreRooted with Busybox 1.19.4-cm7 installed.
  • Odexed
  • Integrated Custom Kernel [CM kernel 1.4]
  • - CWM Recovery 5.0.2.8
  • - CPU Governors: Lulzactive, Lagfree, Ondemand, Userspace, Powesave, Conservative, Performance. [To configure it go to Settings => CyanogenMod Settings => Performance => CPU settings, or use Setcpu]
  • - Overclock support up to 1000MHz! [To configure it go to Settings => CyanogenMod Settings => Performance => CPU settings, or use Setcpu]
  • - 1% Battery Mod
  • Zipaligned
  • Optional Memory Manager! v6 Supercharger by zeppelinrox. [How to enable: open terminal emulator and type: su (enter), v6_supercharger (enter) and enable option 2!]
  • Integrated Video Drivers!! [Thanks to Lebidu]
  • Integrated Beats Audio Engine [Thanks to DeHuMaNiZeD & fuss123]
  • Full APN file for instant internet / MMS access
  • Adfree! [No more ads :P]
  • Tweaked Build.prop
  • - Disabled adb nofity
  • - Battery tweaks!
  • - Proximity Sensor tweaks
  • - More In-Call Volume steps
  • - Performance tweaks!
  • - Swype Keyboard v3.26 with 28 Languages!
  • - Android 2.3.7 Keyboard with all languages and many dictionaries!
  • 5 Launchers to choose from:
  • - Touchwiz30 [For the people who miss it]
  • - AOSP Gingerbread
  • - ADW.Launcher
  • - LauncherPro
  • - Xperia Arc Launcher [Thanks to Slither2006]
  • Custom BootAnimation!
  • Replaced some system apps with better ones!
  • - Tape-a-talk voice recorder [High quality record at cd quality instead of voice recorder]
  • - QuickPic instead of Gallery3D
  • Latest fonts by google!
  • Updated all Google Apps [Market, Gmail, Talk]
  • 2 Themes [Android 2.3 theme, ICS Black build 031]
  • Added Kyrillos-tweaks script [swap, faster partition mounts, Memory & Kernel tweaks, Default governor: Ondemand (with some tweaks), SQlite db optimization (off), Zipalign (off)]
  • Removed Apps [Gallery3D, Voice Dialer, Development, Spare Parts, Protips, RomManager, Sound Recorder, Download Provider, Html viewer, Latin Ime Tutorial, Livewallpapers]
  • Added binaries [sQlite3, Zipalign]
  • Added Voodoo Control App [To configure voodoo sound driver. Note: You must firstly check the /Settings/Device_Settings/Sound_Settings/Enable_WM8994_Control box. (Also turn off the rest two ticks and the stereo expansion gain.)]
  • App2sd [Added S2E app. To enable it: Open S2E, go to its settings, Tick the "Mount as ext4" option, reboot, open the app again, tick "Appications" & "Dalvik cache", reboot & enjoy!]
Ce qui ne fonctionne pas :
-Bluetooth (Partially works, sent-receive file works)
-Video Recording [You can try Videocam illusion, many people confirm that it works]
Les kernels compatibles
-CM7 Kernels => Thread
1000MHz CM7 OC Ultra Kernel v1.4 (Intergrated in v10.1)
-Arakmar's Kernels
Latest kernel (07/04/12) => Recovery
Kyrillos' rom v10.2
DOWNLOAD
One-Package.tar (Odin) => Coming Soon
Update.zip (Recovery) => Mediafire
Notes
-Recommended: Take a full backup with titanium, deactivate hd2sd if enabled, flash the rom from recovery, wipe data/factory reset.
-You can still use hd2sd but you need to disable the preinstalled app2sd script in init.d
Changelog
  • CM7.2 Alpha8.1 based with CM7 kernel v1.5 OC
  • Added an empty mtab file in /system/etc/ [it fixes tune2fs problems]
  • Fixes 05mountsd script issue [it did mount the sd-ext partition only if the type was ext3. Now it supports ext4]
  • Minor fix on Kyrillos-tweaks script [To prevent bootloops when you install an app]
  • Added cm7 app2sd script in init.d [Now you dont need S2E, Link2SD or HD2SD. The app2sd is activated automatically when the phone first boots]
  • Added a better swap script
  • Updated su binary
  • Updated sqlite3 binary
  • Zipaligned all system apk's [Faster system!]
  • GPS fix[Gps should be a bit better now]
  • Fixed bug on the optimize script [Zipalign bug related to /sdcard/download/*.apks]
  • Updated build.prop [3g turbocharger]
  • Fixed Ubuntu Font bug [Thanks ggdu for helping]
Je fais ce poste pour montrer l'évolution , vous en pensez quoi de cette rom?
Le lien xda : http://forum.xda-dev...d.php?t=1431393
Dis moi, j'ai quelque trou de mémoire en ce moment :s
Si j'installe la Kyrillos 10.2, je perdrais mes données ?
Car je me souviens, on m'avait dit que avec un certain flash, les données restaient, mais alors je n'ai aucun idée de quel flash ^^
Ta pas besoin de le configurer a chaque foi utilisere, titanium backup et le tour et jouer, tu sauvegarde le systeme et apres tu le restaure apres avoir flasher la rom le tel et c'est bon ;)
Par contre j'ai une question quelqun saurait comment réactiver le bip de notification qui fait savoir que la batterie et pleine ?
Modifié par Soldat
Bonjour darkomomo :)
Alors CM7, c'est comme une JPU, pas exemple, tu peux installer des Rom par dessus ;).
En fait, CM7 est un Firmware de Base, donc tu peux installer la Kyrillos par dessus.
Et voici le lien de la CM7 ===> http://forum.frandro...gen-72-alpha-8/ ;).
Modifié par John69
