zth Posté(e) 2 mai 2012 Share Posté(e) 2 mai 2012 Bonjour! J'aimerai avoir avotre avis sur cette tablette. YINLIPS M907 Bluetooth keyboard Detail: 82 Keys Shortcut keys control the tablet very convenient Built in 160mAh battery Charging time: 4~5 hours Working time: 55 hours Cradle angle adjustment function It could be a portable cover with the tablet Model YINLIPS M907 Tablet PC CPU All Winner A10, 1.0GHz, Cortex A8; GPU: Mali 400 Operation System Android 4.0.3 RAM 1GB (DDR 3) ROM(Memory) 16GB Nand Flash Shell Material Metal Screen Size 9.7 Inch Type Capacitive Screen, IPS Display LED Resolution 1024 x 768px Visible Angle 180° Extend Card Support TF card up to 32GB extended Camera Dual camera, front is 0.3 Mega and back is 2.0 Mega Gravity Sensor Yes Multi-Touch Yes, 5 points touch Android Market Yes Bluetooth Yes, bluetooth V2.0 Video 2160P, AVI/MOV/MP4/RMVB/FLV/MKV… Music MP3/WMA/WAV/APE/AAC/FLAC/OGG Ebook UMD, TXT, PDF, HTML, RTF, FB2… Skype Yes Email and Browser Yes, built in WIFI Yes, 802.11 b/g/n 3G Not built in, support external 3G dongle: E1916, ZTE AC2736, HUAWEI E1750, HUAWEI EC122, HUAWEI EM770W Earphone Interface 3.5mm Work Time Up to 6~8 hours Battery 7000MAh Language Czech, Dansk, German, English, Spanish, Russian, French, Italian, Dutch, Norwegian, Polski, Greek, Portuguese, Svenska, Turkey, Korean, Japanese, Simplified Chinese, Traditional Chinese Other Applications File Manager, OfficeSuite, Google Search, Task Manager, Browser, Gallery, Android Webkit, Clock, Calculator, Calendar, iReader, Gmail… Product Size 242 x 185 x 9.9mm Product Weight 630g (1.1Kg with keyboard) Extend Port 1 x TF card slot; 1 x MINI HDMI port 2 x Micro USB port 1 x 3.5mm Earphone port Package including 1 x Charger 1 x USB cable 1 x Bluetooth keyboard Package Weight 1077g Vidéo youtube : Video Chinaphonehouse Video Pandawill Prix : Chinaphonehouse : 243,70€ Pandawill : 195,22€ Support constructeur : Yinlips en Anglais Page de support pour de futur MAJ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
zth Posté(e) 5 mai 2012 Auteur Share Posté(e) 5 mai 2012 Personne ne s'intérrèsse à cette tablette? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
dadou345 Posté(e) 8 mai 2012 Share Posté(e) 8 mai 2012 Si quelqu'un a quoi que ce soit comme info qu'il n'hésite pas à partager pour avoir une comparaison avec la Onda Vi40 Elite, car celle-ci pour quelques euros de plus dispose du Bluetooth =) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
misterwood Posté(e) 8 mai 2012 Share Posté(e) 8 mai 2012 Suis aussi intéressé par des avis, j'hésite entre vi40, JXD S9000, Yinlips M907 et Cube GT30. La Vi40 est reconnue côté perfs et fiabilité aux US. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
spamnco Posté(e) 14 mai 2012 Share Posté(e) 14 mai 2012 Il y a un test assez complet sur le site CPH. Elle a 2 défauts pour moi, d'abord son prix, pour moi une tablette chinoise ne devrait pas dépasser les 200 euros car certaines grandes marques proposent des modèles à peine plus chers (Toshiba chez Carrefour) ensuite son autonomie avec une batterie de 7800 mAH pour 5 heures c'est très peu. Soit le BT bouffe tout, soit la batterie ne fait pas plus de 4500 mAH. Ceci dit le BT intégré est un excellent point car il permet par exemple de contrôler sa tablette à distance (média center). Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
dadou345 Posté(e) 14 mai 2012 Share Posté(e) 14 mai 2012 Sur qu'elle site dis tu ? CPH ? J'ai pas trouvé :s Mais as ton avis comparé a une Onda Vi40 à 170€ max c'est quoi le mieux ? Parce que moi qui prend souvent le train ou l'avion, je t'avoue que le BT fait la différence pour mes casques BT ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
zth Posté(e) 20 mai 2012 Auteur Share Posté(e) 20 mai 2012 Ayer j'ai franchi le pas. Je l'ai commandé chez http://www.chinaphonehouse.com/. Je vous ferai part des retours! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Neo47 Posté(e) 30 mai 2012 Share Posté(e) 30 mai 2012 Bonjour, Un retour sur votre achat ? Merci Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
littlesyn Posté(e) 30 mai 2012 Share Posté(e) 30 mai 2012 je l'as trouve cher , a ce prix la, tu as des tablettes chinoise en cortex A9, le petit avantage , c'est le clavier , sinon ça reste une config classique A10 , 1ghz , mali 400. Mais je suis intéressé par ton retour :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
karenax Posté(e) 30 mai 2012 Share Posté(e) 30 mai 2012 le RK30 est sortie, les autres paraissent assé ridicule a coté ^^ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
marcool Posté(e) 31 mai 2012 Share Posté(e) 31 mai 2012 (modifié) le RK30 est sortie, les autres paraissent assé ridicule a coté ^^ un lien, une boutique pour acheter, où avoir des infos? merci. Sinon un retour sur le YINLIPS M907? Modifié 31 mai 2012 par marcool Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
zth Posté(e) 2 juin 2012 Auteur Share Posté(e) 2 juin 2012 Bonjour! Alors je suis très content de cette tablette. Elle correspond parfaitement à mes attentes. Au début, j'ai eu un petit soucis pour l'allumer. C'était un problème du firmware. Mais le SAV de chinaphonehouse a assuré. Je conseille vraiment cette boutique. Voici une adresse où je mettrais au fur et à mesure mes expériences sur cette tablette. http://yinlipsm907.blogspot.fr N'hésitez pas à me poser des questions. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Neo47 Posté(e) 2 juin 2012 Share Posté(e) 2 juin 2012 (modifié) Merci pour ton retour. Je me permet de te poser quelques questions car je suis intéressé par cette tablette. -Es-ce que les dimensions sont similaires à l'IPAD ? dans la mesure ou je pense prendre une housse avec clavier BT intégré. -Les performances sont elles au RDV ? fluidité, jeux (type GTA ?), flash ? -Comparé à un double coeur, penses-tu qu'il y ai une grande différence ? -Quel est l'autonomie de ta tablette (afin d'avoir un comparatif avec le test de CPH). -Un accessoire conseillé pour une bonne utilisation ? Merci d'avance Modifié 2 juin 2012 par Neo47 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
zth Posté(e) 4 juin 2012 Auteur Share Posté(e) 4 juin 2012 1) Alors oui les dimensions sont les mêmes que l'IPAD. J'ai pu comparer avec celui de mon beau-frère. Par contre la coque de la Yinlips est en alu et n'est donc pas aimantée. Alors pas d'étui à aimant, mais la housse dont tu parles devrait aller je pense. 2) Niveau performance, elle sont correctes. Je ne suis pas un grand joueur de jeux vidéo, donc je ne peux pas trop m'avancer là dessus. Mais j'ai testé Sonic et c'est bien fluide. Après pour mon utilisation j'en suis très satisfait. 3) Pour le double cœur, je n'en ai aucune idée. Je n'ai rien pour comparé. 4) Niveau autonomie, c'est pas fameux bien sûr! Mais on le sait, c'est le point faible des tablettes chinoises. Cependant, elle tient bien la journée avec le wifi allumé, mais c'est sûr qu'avec une utilisation intense, je pense qu'il faudra la brancher souvent. Pour le moment, je l'utilise la journée puis la branche le soir. 5) Pour l'instant, je n'ai pas d'accessoire à conseiller. Je n'avais pas pris le clavier à la commande et pour le moment je n'en ai pas besoin. Je verrai par la suite. Il y a en à 30€ en azerty sur ebay. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Dany_Edouard Posté(e) 5 juin 2012 Share Posté(e) 5 juin 2012 Voici 3 vidéos de la tablette: Test partie 1 Test partie 2 Flash maintenant OK Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
pamfou Posté(e) 10 juillet 2012 Share Posté(e) 10 juillet 2012 Bonjour, Je souhaite acheter une tablette. J'hésite entre la tienne et la ONDA Vi40 dual core. Es tu toujours satisfait de ta tablette, est elle assez rapide? Je compte en faire un utilisation pour du surf internet, lire des ebook ou magazine, un peu de bureautique et regarder des videos occasionnellement. Le site CPH m'a l'air serieux : ils repondent aux questions rapidement sans même avoir encore acheté chez eux, leur blog est bien fait. Merci! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
pamfou Posté(e) 11 juillet 2012 Share Posté(e) 11 juillet 2012 J'ai aussi franchi le pas : je viens de commander moi aussi sur http://www.chinaphonehouse.com/. Ils me semblent sérieux! Je ferais des retours. zth ton blog de suivi m'a aidé dans ma décision, je saurais où chercher en cas de mise à jour et autre conseils! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
zth Posté(e) 11 juillet 2012 Auteur Share Posté(e) 11 juillet 2012 Content que cela ait pu servir. C'est le but! J'espère que tu ne sera pas deçu! Moi je ne le suis pas. Je cherche juste une rom custom ou le moyen d'en faire une. Pour le moment pas de pack de compatibilité pour le CM9 ou le AOKP. 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
pamfou Posté(e) 20 juillet 2012 Share Posté(e) 20 juillet 2012 J'ai reçu ma tablette hier! Pour l'instant je suis globalement content de celle ci! La version du build est la 4.010. Elle est relativement rapide, le wifi un peu faible par rapport a mes autre appareils. Seul hic pour le moment : pas de mots dans la correction automatique d'orthographe: il faut les rentrer 1 a 1: si il existe un moyen de rentrer une listre! Je suis preneur! Merci. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
smeexx Posté(e) 20 juillet 2012 Share Posté(e) 20 juillet 2012 met swiftkey pour tablette c est un des meilleur clavier Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
