Invité Posté(e) 25 mai 2012 Share Posté(e) 25 mai 2012 (modifié) Doixanh est de retour, après les très bons Froyobread et GingerDx il nous propose IscreamDX (ICS 4.0.4) ! On peut s'attendre à quelque chose d'excellent venant de Doixanh. Topic XDA : http://forum.xda-dev...d.php?t=1672477 Caractéristiques : ICS 4.0.4 Optimisée Fluide Le minimum d'applications Thèmes supportés Bugs connus : Camera Radio Fm ADD A2SD ? Battery stats Exigences : Rooté Bootloader déverrouillé CMW (inclus directement dans le kernel) Baseband M76XX-TSNCJOLYM-53404015 Le dernier kernel nAa ICS : http://forum.xda-dev...d.php?t=1576002 Installation : "Wipe Data Factory reset" via CMW "Install custom zip" via CMW Enjoy :) Versions : V004 ou V004 V003 V002 ou V002 V001 Historique développement : June 028 v004. More fixes... Big fixes..FileManager 1.2 -- I planned to integrated it into ISDX built but then I was lazy, so apk was taken. Fixed 3MP camera (camcorder SLOW because of no hw accel encoding) Fixed battery stats Fixed SIM not found when having SIM pin Fixed timezone info Removed "bootloader" in reboot menu ADB over TCP June 018 v003. Some fixes.Latest CM nightly 2012-06-16, some CM additions like weather/news widget on lockscreen... Screen off animation Low screen brightness A2SD[?] Flickering nAa kernel logo and boot animation Some internal changes to framework June 03 v002. Some fixes and improvements.Latest CM nightly 2012-06-01 Fixed root problem Scrolling/Flinging optimized. Should be a bit smoother. Apex launcher instead of Trebuchet Fixed team name on lockscreen The latest lightweight acWidget: Your calendar, by AChep. Thanks man! Force theme loading: You can even apply HDPI themes, like Sense 4! Be warned: applying HDPI themes may require more RAM for surfaces CM9 Apollo (music player app). Original Music app is still installed. May 25 v001. First release.Preference screen optimization A bit improved speed Remerciements : Que dire si ce n'est remercier encore Mr Doixanh pour son excellent travail. Il a fait un travail fanstastique sous android 2.2 avec la rom froyobread et il a été le premier à nous fournir une ROM 2.3 fluide et avec peu de bugs. Il faut aussi remercier les différents acteurs qui ont permis à Doixanh de créer cette ROM ainsi que le kernel. Doixanh : "Thanks go to the CyanogenMod Team, racht, nobodyAtall, zdzihu, jerpelea and lots of others... Thanks also go out to Google for their great little Android. And don't let us forget to throw Sony Ericsson a thanks for their nice X8 hardware but craptastic software support." Modifié 29 juin 2012 par mik35 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
BaBaA Posté(e) 25 mai 2012 Share Posté(e) 25 mai 2012 je vais attednre encore un peu pour tester ca :) ! mais j'ai hate ! donc faut mettre le kernel avant le flash si j'ai bie compris ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
duntown Posté(e) 25 mai 2012 Share Posté(e) 25 mai 2012 Superbe nouvelle que je testerais dès que possible, par contre si tu pourrais compléter ton post avec entre autre le A2SD dans les bugs et une partie de remerciement pour rendre à César DX ce qui lui appartient Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
sybiload Posté(e) 25 mai 2012 Share Posté(e) 25 mai 2012 Il faut aussi rajouter le bug de l'historique d'utilisation de la batterie... Sinon, good news !!! A suivre !!! PS : Petite ROM deviendra grande... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité Posté(e) 25 mai 2012 Share Posté(e) 25 mai 2012 Il est revenu en force :D Oh yeaaaaaaaaaaaaah ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ChromeShady Posté(e) 25 mai 2012 Share Posté(e) 25 mai 2012 La caméra fonctionne sur MiniCM9 et pas sûr ISDX ... Je vais encore attendre un peu ... Mais si c'est Doixanh ça promet du lourd. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité Posté(e) 25 mai 2012 Share Posté(e) 25 mai 2012 (modifié) Pas de soucis pour le post, j'avais fait ça rapidement car je devais filer, je vais l'améliorer ;) En plus, il n'y avait pas ces 2 bugs tout à l'heure de signalés. Espérons que la liste ne s'allonge pas ^^ Pour le kernel je préfère toujours le flasher avant. Rebooter sur CMW et flasher la rom Modifié 25 mai 2012 par mik35 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
the tortue Posté(e) 25 mai 2012 Share Posté(e) 25 mai 2012 c'est possible d'avoir des capture d'écran?? quelqu'un la déjà testé? enfin vu le travail que Doxianh a déjà fait sur la 2.2 et la 2.3 je pense que cette rom a un belle avenir :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité Posté(e) 25 mai 2012 Share Posté(e) 25 mai 2012 Hélas je ne peux pas mettre de captures, je n'ai pas testé la rom et Doixanh n'en a pas mis. Si quelqu'un teste la rom, je veux bien qu'ils mettent des captures que je mettrai sur le 1er message :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
the tortue Posté(e) 25 mai 2012 Share Posté(e) 25 mai 2012 ok merci mik35 je sais le courage de la testé je te passerai des captures mais sinon elle est bien stable ?? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité Posté(e) 25 mai 2012 Share Posté(e) 25 mai 2012 Apparemment elle semble stable, cependant n'ayant pas l'appareil photo et souffrant de quelques bugs je conseille pour le moment de rester sous MiniCM9. Si Doixanh fait les MAJ à la même fréquence qu'au début de froyo ou gingerbread on peut s'attendre à 2 versions / semaine environ, ça devrait évoluer très vite :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité Posté(e) 25 mai 2012 Share Posté(e) 25 mai 2012 Ce dev', je crois que c'est le meilleur qu'on ait jamais connu sur x8. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
duntown Posté(e) 26 mai 2012 Share Posté(e) 26 mai 2012 Je sais que pour GDX il a fallu attendre la v10 environ pour poser quelque chose de vraiment stable, obtenir un niveau proche des Froyo de l'époque. Après il faut être franc, les ICS, quelles qu'elles soient, ne sont pas encore des bètes de stabilité donc je pense que pour ICS stable il faut attendre encore un peu mais comme les travaux sur MiniCM9 entre autre montrent, on est sur la bonne voie. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
sybiload Posté(e) 26 mai 2012 Share Posté(e) 26 mai 2012 Il semble que plusieures personnes sur XDA ont des problème avec la carte SIM qui n'est pas reconnue, l'historique de la batterie qui ne fonctionne pas et les applications ROOT qui ne s'affichent pas dans Super-Utilisateur... Sinon, un petit screenshot pris sur XDA : http://dl.xda-developers.com/attachdl/6d03f255238d19e1e390906ddc666dde/4fc09f55/1/0/8/4/2/5/6/Screenshot_2012-05-26-01-40-24.png Sujet à suivre de près !!! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité Posté(e) 26 mai 2012 Share Posté(e) 26 mai 2012 Le lien est mort :! Ouais pour ICS il faut attendre un peu car pour le moment c'est pas des betes de course. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité Posté(e) 26 mai 2012 Share Posté(e) 26 mai 2012 Tout à fait, il va falloir attendre pour le moment. On peut espérer d'ici la rentrée quelque chose de très bon à mon avis :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité Posté(e) 3 juin 2012 Share Posté(e) 3 juin 2012 MISE A JOUR :D Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité Posté(e) 3 juin 2012 Share Posté(e) 3 juin 2012 Yep, je ne l'ai pas signalé mais j'ai modifié ce matin tout ça :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Skatoid Posté(e) 4 juin 2012 Share Posté(e) 4 juin 2012 Ce dev', je crois que c'est le meilleur qu'on ait jamais connu sur x8. C'toi qui dit ça :k Sinon, très bonne nouvelle! On va tester tout ça avec RM :D Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
rayji Posté(e) 4 juin 2012 Share Posté(e) 4 juin 2012 C'est quand même grâce à lui qu'on a eu le fake dt, lOC, l'UV et plein d'autres tweaks... C'est un des dév qui a le plus apporté à nos X8. Sinon concernant la rom, je testerai lorsqu'elle me semblera mieux, pour l'instant, je reste sur MiniCM9 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité Posté(e) 5 juin 2012 Share Posté(e) 5 juin 2012 Fais gaffe c'est la 'v002' xD Un topic qui peut être intéressant : http://forum.xda-developers.com/showthread.php?t=1673727 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Skatoid Posté(e) 6 juin 2012 Share Posté(e) 6 juin 2012 Lol, j'viens de repenser à un truc quand t'as dis ça, les entrainements vidéos sur cette ROM :o Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
rayji Posté(e) 11 juin 2012 Share Posté(e) 11 juin 2012 Question, je suis en recherche d'autonomie mais je veux garder toutes les avancées ICS (oui, je suis difficile). Est-ce que quelqu'un qui aurait essayé la minicm9 et celle là avec exactement la même utilisation pourrait me dire laquelle tiens le plus longtemps. Parce qu'en ce moment même si je laisse le tél en veille, je tiens que 1,5j sur minicm9 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ben53 Posté(e) 11 juin 2012 Share Posté(e) 11 juin 2012 En tout cas IScream DX, l'autonomie est excelente Si tu teste merci de nous dire l'autonomie que tu obtiens, et si elle est plus fluide que la MiniCM9 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Skatoid Posté(e) 12 juin 2012 Share Posté(e) 12 juin 2012 Pour l'autonomie, j'avais fais un test de l'a laisser en charge, j'étais vers les 95% Je l'ai laissé 1,5 j, j'étais dans les 40. A savoir que je n'avais pas installé Supercharger. Plus d'autonomie sur GingerDX, donc c'pour vous dire... Pour la fluiditée, jte passes directement un test : http://www.youtube.com/watch?v=v7o3MD70-Ss Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
