[ROM] XenonHD v6.0 (01.07.12) *Theme chooser, lockscreen customization/weather*
Voici une rom pour laquelle il y a aucun sujet mais qui est pourtant très bien, rapide et personnalisable:
Team Horizon presents XenonHD
Base : 4.0.4 IMM76I : FULL AOSP BASE FROM SOURCE.
Rockstable and Blazing fast
Features:
ICS 4.0.4 IMM76I
Rooted
Busybox
Miscellaneous:
Trebuchet launcher with additional features and cleaned up.
DSP manager added.
CM music player added.
Apex launcher added.
Fancy widgets added.
Extended power menu with screenshot option.
Statusbar toggles.
180 degree rotation enabled.
Navigation bar button pressing speed quickened. (Galaxy Nexus only)
Scrolling cache improvements.
Support for caller display name.
Unlinking of of notification sound and ringtone value.
Separate headset and speaker volumes.
Battery percentage.
Volume rocker wake.
Long press volume rocker to skip tracks.
Kill app on long press back key.
Developer settings as shortcut option.
Use holo theme for activity picker dialogue.
Processor option in settings.
Launcher option in settings.
Toggles option in settings.
Added XenonHD wallpapers.
Added device specific settings.
Ability to use volume rocker as cursor.
Enabled wifi tether on Toro.
Louder output on speaker for Maguro.
Added Galaxy4, PhaseBeam and Holo spiral wallapers.
Wi-fi scan time to 100 to save battery.
Performance, battery life and other misc tweaks.
Init.d support.
Etc
Phone and Contacts application:
LTE and 2G toggle support in phone.
End call button in notification curtain.
Landscape while in call.
Access to statusbar while in call.
Lights out while in call. (Galaxy Nexus)
Option to exit to home screen straight after the call.
Added voicemail notification settings in phone settings.
Disabled accelerometer sensor while in call and screen is off.
T9 dialer option.
Etc
Camera:
Power key as shutter option.
Pinch to zoom. (Galaxy Nexus)
Additional options.
Etc
Alarm and Clock:
Added a setting to do nothing/snooze/dismiss by flipping the device.
Hide buttons completely in fullscreen to prevent burn in and give a cleaner look. (Galaxy Nexus)
SMS and MMS:
Support for emojis.
Gesture support.
Etc
Dernière http://goo.im/devs/TeamHorizon/Crespo
Changelog:
01.07.2012
Frameworks:
Boot animation: Don't cache textures
Fix sluggishness while launching an app
Fix MPEG4 time stamp.
More bug fixes.
Added AVRCP 1.3 with features from CM9 and AOKP.
New XenonHD boot animation by me.
Camera app updated with lots of bug fixes.
DSP Manager updated.
Trebuchet updated.
Torch app added.
Email app:
Added option to use/unuse led
Don't reset recipients when loading drafts
Added bigger refresh times
Resolved infinite alarms in every 15 second.
Etc
Apollo music player added back.
Lots of update to MMS app. Check Messaging>Settings
Lot's of other bug fixes
Etc
Modifié par Snouki
01.06.12
Navigation bar customization option.
Lock screen targets customization.
Lock screen weather support + fixes
Theme chooser and framework fixes.
Clean up of display settings.
Apollo player updates from CM source.
Long press toast message changed.
Bug fixes
etc
update v4.0
05.06.2012
Lock screen calendar.
Lock screen weather: Units changed to upper case = other fixes.
Lock screen weather: Option to inver high/low.
Option to hide IME switcher.
Expandable volume bar.
Safe volume restore when headset plugged in option.
More theme chooser and framework fixes.
Added a menu item in browser called close other tabs.
Open in incognito tab option added on long pressing a link.
Browser tab setting changes.
Increased the tab limit in browser.
Bug fixes (Camera, browser, etc)
Lots more.
Modifié par davidnexussdroid
16.06.2012
Linaro optimized build.
Fixed themeing of shutdown thread.
Weather:
  • Auto sync upon network connection.
  • New no data and refresh indicators.
Enabled notification numbers.
Added an option to change the device host name.
Added Ad-hoc network support.
Added MusicFX back for those for whom DSP Manager doesn't work. (Default option in sound settings)
Apollo music player updated.
Busybox updated.
Trebuchet updated.
Apex launcher updated.
Galaxy nexus settings updated with more things. (WIP)
System/app cleanup (Toro)
Removed fancy widgets.
Lots of bug fixes and other changes.
Snouki, il faudrait que tu refasses ton message, car chez moi tout apparaît, sans effet (les codes Html apparaissent).
Je vais tester cette Rom.. :)
Edit: Elle ne me convient pas.. Dommage.
Modifié par AirOne70
01.07.2012
Frameworks:
  • Boot animation: Don't cache textures
  • Fix sluggishness while launching an app
  • Fix MPEG4 time stamp.
  • More bug fixes.
Trebuchet updated.
Torch app added.
Email app:
  • Added option to use/unuse led
  • Don't reset recipients when loading drafts
  • Added bigger refresh times
  • Resolved infinite alarms in every 15 second.
  • Etc
Etc
Je ne vois pas quelle code tu as mis, mais je crois que tu as utilisé la balise [*code] au lieu de [*quote] !
(les petites étoiles, je les ai mises pour pas qu'elles soient prises comme de vraies balises)
Et c'est donc pour ça que l'on voyait tous les codes de présentation !
  • 1 month later...
[ROM][JB] XenonHD v5.0 (02.08.12) *Calling All*
uppp
Features:
JB 4.1.1 JRO03H
Rooted
Busybox
Miscellaneous:
Apex Launcher
DSPManager (JB) added with all the binaries.
Apollo Music player added and fixed for JB.
Proper extended power menu.
Digital clock widget added.
Louder output on speaker for Maguro and Toro.
Init.d support with added tweaks and scripts.
SuperSU application for root.
File manager added. (Compiled with JB SDK 10 by me biggrin.gif)
GPS and Camera fixed.
Reflective soft keys.
Build.prop tweaks.
Battery life tweaks.
Etc
Alarm and Clock:
Frameworks:
Fix restoring network mode preference on reboot.
Telephony: Add DORMANT state to GSM data link activity
Fix automatic timezone failing on some GSM networks
Added missing Tuna ringtones.
LegacyUSB: Add support for legacy USB implementations.
Bootanimation: performance enhancements.
Much more
Added quick unlock.
Added menu unlock.
Added expandable volume overlay.
Added option to show battery percentage on lock screen.
Fixed theming of lock screen.
Fixed theming of reboot dialog.
Battery bar fixed for landscape.
Navigation bar themeable.
Made notification icon aligned with text.
Unknown sources ticked by default.
Reboot dialog fixed to appear on lock screen.
Fixed data dialog activity not disappearing when wifi is on.
Fixed lag for crespo users.
Updated proprietaries for Crespo, Maguro and Toro.
Fixed some tweaks not working.
Etc
Avec le kernel thalamus c'est une petite tuerie ;)
Updated to 4.1.1 JRO03L
Added support for Grouper.
Added performance settings.
Added lock screen weather.
Added Bluetooth AVRCP 1.3!
Unlinked ringer and notification volume.
Added safe volume headset.
Added NFC polling settings.
Added prebuilt effects for camera.
Added color selection and alpha settings for notification toggles.
Added lockscreen wallpaper settings.
Added option to change navigation bar color and transparency.
Fixed bug in lockscreen battery percentage.
Added spare parts.
Somethings I forgot!
Added lockscreen custom targets. (Settings > Security)
Added screenshot option in power menu.
Added brightness slider widget.
Fixed AVRCP 1.3 and added new features.
Fixed bug of vibrate when ringing not sticking in sound settings.
Updated build prints for Crespo, Maguro, Toro and Grouper to official fingerprints.
New weather icons for lockscreen.
Adjusted the lockscreen clock a bit.
Removed Youtube app and fixed the issue which didn't let youtube app to be installed from Play Store.
Fixed SMS warning dialog.
Updated File Manager.
New torch app.
Updated Apex Launcher to the latest beta.
Added transparency to in call screen.
Etc
25.08.2012
Added notification LED settings with options for custom settings for different apps.
Added ability to limit notifications for apps.
Added option to toggle IME switcher in notification shade. (From XenonHD ICS)
Added option to disable boot animation for faster boot,
Ability to change clock color.
Added rotation lock button like in tablets for phone.
Battery icon update for tablets.
Centered lock screen clock.
NFC polling: Summary now shows the set value.
Fixed down button while keyboard is in use. (Doesn't play well with custom images.)
Fixed sync toggle icon.
Removed torch from grouper.
Removed bug mailer.
Crespo users can now enable navigation bar!
Much more bug fixes. I'm lazy!
Phone App:
End call to Home Screen Setting is back.
Ability to add "my phone number".
Fix centered layout for inbound call ring.
Contacts App:
T9 dialer searches through nicknam
