beta15 Posté(e) 11 juin 2012 Share Posté(e) 11 juin 2012 (modifié) ★★★ BlackStaR for SGS III ★★★ BlackStar V3 Based on stock LF6 Rom Deleted all Sammy bloat but all functions working Added Crt-On/Off effect Added 15 toggles thx gh.rohit SystemUI themed Framework themed Added Power Profile Siyah 1.3.7 Kernel added thx gokhanmoral Added Jelly Bean Music app Calculator blacked out File Manager blacked out Added HX-Camera 1.4 thx hyperX Jelly Beans Sounds added Jelly Beans Animation added Jelly Beans Fonts added Newest Play Store 3.7.13 blacked out added Added GoogleReader blacked out Center Clock with ICS color added Added newest Apex Launcher Added Home lag Fix Rom Size about 300mb only and more i forget... BlackStar V2.1 Disabled Increasing ring Disabled Scrolling Cache Added Themed Gtalk Themed phone ICS Themed Contacts ICS Added smooth spinners thx gadgetcheck Added siyah 1.1 Kernel thx gokhanmoral Added ExTweaks thx gokhanmoral Disabled fast dormancy Asus Weather Widget added Tweaked some .jar files for more speed and smoothness BlackStar V2 Based on XXALF2 Very fast and Smooth New SystemUi Theme thx jackmu95 modded with new Battery Icon Samsung Camera HX-MOD v1.35 thx hyperX Extended Power Menu thx Walhalla New CM9 MMS with Emoji support and new Theme Framework Theme changed New Framwork animation SiyahKernel S3-v1.0 thx gokhanmoral Added Sammy Fmradio Added Flipboard Added CM9 Browser Added CM9 Calculator Added CM9 Gallery (you can set fullscreen desktop wallpaper) BlackStar V1 Based on XXALEF Android 4.0.4 (Date: 22/05/2012) Rom is Deodexed + Rooted + Zipaligned Kernel: Abyss S3 kernel 1.0 Final Stable Version by Angelom Rom Size 250mb Framework tweaked SystemUI Theme changed + percentage Battery 4-WAY Reboot added New Framework Animation Deleted all Samsung Bloat, but all features still work Added newest CM9 Gapps and blacked them OUT ApexLauncher included, can be changed Camera MOD HX 1.25 added Disabled increasing ring on Phone init.d tweaks added Added CM9 App Icons Added File Manager and much more i forget... Prés-requis : Samsung Galaxy S3 Root : ICI Téléphone chargé à +80% Carte SD Extern Installation : • Démarrer votre téléphone en mode récovery • Option "wipe data/factory reset" et Validez YES • Option "wipe cache partition" et Validez YES • Menu "advanced" • Wipe Dalvik Cache • Selectionnez "Install Zip from SD Card" et Validez • Sélectionnez "Choose ZIP from SD Card" et Validez • Déplacez vous dans l'arborescence jusqu'à arriver dans l’endroit où vous avez mis la ROM • Validez la ROM • CWM fais l'installation • Rebooter le téléphone V3 Modifié 7 juillet 2012 par beta15 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Shib Posté(e) 11 juin 2012 Share Posté(e) 11 juin 2012 Overclock du GPU possible jusqu'à 800MHz ? :/ Sa doit le décrasser un peu de plus que doubler sa fréquence^^ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
melitalia Posté(e) 12 juin 2012 Share Posté(e) 12 juin 2012 Elle a l'air prometteuse en tous cas ! 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Neutre0 Posté(e) 21 juin 2012 Share Posté(e) 21 juin 2012 Belle ROM. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
