Skatoid Posté(e) 24 juin 2012 Share Posté(e) 24 juin 2012 (modifié) Topic xda : http://forum.xda-dev...d.php?t=1729280 Advanced Stock ICS Caractéristiques Autorooté CWM Recovery init.d script support --- Download Build 11 : http://api.viglink.com/api/click?format=go&drKey=1359&loc=http%3A%2F%2Fforum.xda-developers.com%2Fshowthread.php%3Ft%3D1729280&v=1&libid=1343492382500&out=http%3A%2F%2Fdl.dropbox.com%2Fu%2F12943198%2Fics11.elf&ref=http%3A%2F%2Fforum.xda-developers.com%2Fforumdisplay.php%3Ff%3D1518&title=%5BKERNEL%5D%7BS%7D%20Advanced%20Stock%20ICS%20Kernel%20Build%2011%20%5B17%2F07%2F12%5D%20-%20xda-developers&txt=Build%2011%20(Fastboot)&jsonp=vglnk_jsonp_13434925947212 (Fastboot) Build 11 : http://api.viglink.com/api/click?format=go&drKey=1359&loc=http%3A%2F%2Fforum.xda-developers.com%2Fshowthread.php%3Ft%3D1729280&v=1&libid=1343492382500&out=http%3A%2F%2Fdl.dropbox.com%2Fu%2F12943198%2Fics11.zip&ref=http%3A%2F%2Fforum.xda-developers.com%2Fforumdisplay.php%3Ff%3D1518&title=%5BKERNEL%5D%7BS%7D%20Advanced%20Stock%20ICS%20Kernel%20Build%2011%20%5B17%2F07%2F12%5D%20-%20xda-developers&txt=Build%2011%20(CWM)&jsonp=vglnk_jsonp_13434926155463 (CWM) Build 9 : http://dl.dropbox.co...943198/ics9.elf (Fastboot) Build 9 : http://dl.dropbox.co...943198/ics9.zip (CWM) Build 8 : http://dl.dropbox.co...943198/ics8.elf (Fastboot) Build 8 : http://dl.dropbox.co...943198/ics8.zip (CWM) Build 7 : http://dl.dropbox.co...943198/ics7.elf Build 6 : Lien supprimé par le développer Build 5 : http://dl.dropbox.co...943198/ics5.elf Build 4 : http://dl.dropbox.co...943198/ics4.elf Build 3 : http://dl.dropbox.co...943198/ics3.elf Installation Modifie le nom du kernel par 'kernel.elf' puis suis cette commande avec fastboot : fastboot flash boot kernel.elf Changlogs : Build 11 : Go back to GCC 4.4 (fix artifacts with camera preview) Build 10 : Kernel built with GCC 4.6 Several autoroot fixes (Superuser app pushed just once and correctly removed in /data) Working reboot recovery command (with adb too) Updated su (3.1.1) and Superuser (3.1.3) A bunch of new command included in the new busybox (ifconfig, wget, vi, and many more !) Build 9 : Kernel construit via les sources. TUN/TAP driver inclus (pour VPN) Build 8 : Fix Mass Storage in CWM Build 7 : Fix MTP Build 6 : Key mapping in CWM Fixed Build 5 : Nouveau recovery basé sur les sources CM9 Taille du texte corrigé dans CWM Boot partition backup and restore Nouveau adb source CM9 Build 4 : Correct su binary Build 3 : Leds and vibrator at startup fixed Modifié 28 juillet 2012 par Skatoid 2 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
LordMelathar Posté(e) 27 juin 2012 Share Posté(e) 27 juin 2012 (modifié) Le kernel d'Arakmar fontionne nikel , on a le root et le recovery d'office :) voir ici :http://forum.xda-developers.com/showpost.php?p=27918955&postcount=120 Modifié 27 juin 2012 par LordMelathar Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Skatoid Posté(e) 27 juin 2012 Auteur Share Posté(e) 27 juin 2012 J'attends déjà que tout le monde ait ICS (par rapport aux SI) avant de finioler le topic :P Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
LordMelathar Posté(e) 27 juin 2012 Share Posté(e) 27 juin 2012 je signale juste pour les amateurs :P Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Skatoid Posté(e) 27 juin 2012 Auteur Share Posté(e) 27 juin 2012 Okioki, pas de problème Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
apashe Posté(e) 27 juin 2012 Share Posté(e) 27 juin 2012 Moi je vais le mettre ce midi, c'est bizar mais depuis ICS, je ne peu plus régler les autorisation des fichiers que je place dans system avec solid explorer. Je ne pense pas que ce soit a ca ait un rapport mais bon ca me déprime de devoir reutiliser root explorer ^^ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
theDexter Posté(e) 27 juin 2012 Share Posté(e) 27 juin 2012 Nouveau dans le monde du rootage, j'aimerai savoir à quoi cela sert? Et c'est dommage que tu ne continue pas ton tuto. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
skymike03 Posté(e) 27 juin 2012 Share Posté(e) 27 juin 2012 avoir accès au recovery, et a être rooté sans modification manuelle. il faut par contre dévérouiller le bootloader de facon officielle, ie. perte de la garantie ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
tofclaire Posté(e) 27 juin 2012 Share Posté(e) 27 juin 2012 testé ; il fonctionne bien ;) et la ka ics devrait sortir incessement sous peu, il est en train de la finir :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Skatoid Posté(e) 27 juin 2012 Auteur Share Posté(e) 27 juin 2012 A mon avis, déjà, dans 1/2 jours, y'aura les ROMs FR Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
skymike03 Posté(e) 27 juin 2012 Share Posté(e) 27 juin 2012 (modifié) dernière version test 3 : http://dl.dropbox.co...943198/ics3.elf avec led de notif indiquant qu'on peut accèder au recovery ;) Modifié 27 juin 2012 par skymike03 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Skatoid Posté(e) 27 juin 2012 Auteur Share Posté(e) 27 juin 2012 Qu'est ce que c'est ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
skymike03 Posté(e) 27 juin 2012 Share Posté(e) 27 juin 2012 la derniere version du kernel de ARAKMAR ! http://forum.xda-dev...6&postcount=140 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
gileragsm80 Posté(e) 27 juin 2012 Share Posté(e) 27 juin 2012 (modifié) À supprimé... Modifié 27 juin 2012 par Best of Android Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Skatoid Posté(e) 27 juin 2012 Auteur Share Posté(e) 27 juin 2012 Why ? J'attends juste que le déploiement d'ICS pour tous sois finit, et je finirais le topic, je me le suis 'réservé' en quelques sortes ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
skymike03 Posté(e) 27 juin 2012 Share Posté(e) 27 juin 2012 je pense qu'il parlais de son commentaire, vu qu'il la modifié Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Skatoid Posté(e) 27 juin 2012 Auteur Share Posté(e) 27 juin 2012 Ah oui effectivement, fail. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Skatoid Posté(e) 29 juin 2012 Auteur Share Posté(e) 29 juin 2012 MàJ du post Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
penta42 Posté(e) 2 juillet 2012 Share Posté(e) 2 juillet 2012 Merci pour le kernel c'st niquel Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
FanAsus Posté(e) 2 juillet 2012 Share Posté(e) 2 juillet 2012 @penta42: Oh le jeu de mots xD Flute ! J’hésite de + en + à dévérouiller mon bootloader :( Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Skatoid Posté(e) 8 juillet 2012 Auteur Share Posté(e) 8 juillet 2012 (modifié) Mise à jour du post ! Build 9 les amis ;-) Modifié 8 juillet 2012 par Skatoid Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
apashe Posté(e) 8 juillet 2012 Share Posté(e) 8 juillet 2012 (modifié) Petit mod interessant compatible grace au build 9: http://www.xda-developers.com/android/access-all-google-play-services-from-anywhere-in-the-world/ Modifié 8 juillet 2012 par apashe Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
laurent04 Posté(e) 9 juillet 2012 Share Posté(e) 9 juillet 2012 Bonjour, ce kernel est il compatible si on a le bl verrouillé? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
YokA Posté(e) 9 juillet 2012 Share Posté(e) 9 juillet 2012 Non ^^ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Skatoid Posté(e) 9 juillet 2012 Auteur Share Posté(e) 9 juillet 2012 Si pour les dernières versions, elles s'installent avec CWM ;- ) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
