LudoS20 Posté(e) 3 juillet 2012 Share Posté(e) 3 juillet 2012 (modifié) SOURCE http://forum.xda-dev...d.php?t=1742493 My CFW for I9100 - Hope you like it Preview Changes log: Base on DXLPB,Deodexed, rooted CF-Root kernel (Flash others ICS kernelif you like) SGS3 Themed icons, wallpapers, clock, TouchWizUX, shutdown logo, S3 music player... base on my newest S3 icon pack Added 14 statusbar toggle buttons, % battery Better camera mods (VideoBitrate, AudioBitrate, AudioSamplingRate) mediaprofiles for recording video 1920*1080 and 1280*720 Remove delay after talk end. I try to keep original with stock Other things i don’t remember New updates v1.0 pack ..With new mods :+ JellyBean Fonts+ S3 themed for MMS and Dialer + S3 animations+ ICS Battery Mod icons (install this if you like GreenBattery) New XWLPF version more mods, support more languages, Jkay14.1 (need install deluxe app to do more ) New version base on XWLPT With some new mods :+ Base on new XWLPT-ICS 4.0.4, S3 themed,TouchWizUX, S3 Animations.+ 15 Toggle Quick Panel,AOSP ICS lockscreen ,4 Way reboot+ Video player with PopUp MiniPlayer, S3 music player+ SpeedMod k3-30 kernel (Best for ICS 4.0.4) Tuto Prés-requis : Samsung Galaxy S2 Root : ICI Téléphone chargé à +80% Carte SD Externe Installation : • Démarrer votre téléphone en mode récovery • Option "wipe data/factory reset" et Validez YES • Option "wipe cache partition" et Validez YES • Menu "advanced" • Wipe Dalvik Cache • Selectionnez "Install Zip from SD Card" et Validez • Sélectionnez "Choose ZIP from SD Card" et Validez • Déplacez vous dans l'arborescence jusqu'à arriver dans l’endroit où vous avez mis la ROM • Validez la ROM • CWM fais l'installation • Rebooter le téléphone Téléchargement LINK DOWNLOADS : More info go to here ::::::: DXLPB ICS4.03 Version ::::::: GT-I9100_DXLPB S3modsV2.0.by.binh24-NOWIPE DEV-HOST MIRROR (thanks wis1152 ) GT-I9100_DXLPB S3modsV2.0.by.binh24-NOWIPE And ( thanks gundin59) http://narod.ru/disk....OWIPE.zip.html Download update packs : (install with CWM for DXLPB only) DXLPB S3mods update pack v1.0 ::::::: XWLPF ICS4.03 Version ::::::: More info go to here GT-I9100_S3mods.XWLPF.ICS4.03.JKAY14.1.NO-WIPE.zip ::::::: XWLPT ICS4.04Version ::::::: GT-I9100 XWLPT ICS4.04.S3mods.NO-WIPE mirrors: XWLPT ICS4.04.S3mods (thanks to Retseem) Notes: You need to use Speedmod kernel K-30or use this fixfor unsupport kernel for ICS 4.0.4 if preview image of photocamera is dark ----- don`t forget to click thanks ----- Plus mods: (use if you like-install with CWM ) ICS Galaxy s3 dialer theme mod.zip Galaxy S3 Animations.zip CWM_Sony Walkman_Player for_ICS Battery icon mod support DXLPB & XWLPT S3mods-Stock_Battery_Icon_without_Percentage.zip S3mods-Stock_Battery_Icon_with_Percentage.zip ***** Hacked AOSP Email (4.0.4) (if you are switching from stock one you have to remove your account and clear Email/Exchange apps data) Stock Launcher TouchWiz30.zipLG Home UI 3.0 Laucher.zip Galaxy S-III Wallpapers For Galaxy S-II SVoice PLUS MODS FOR DXLPB VERSION DXLPB Restore old SII icon pack Blue ICS Battery Mod for S3mods(DXLPB only) DXLPB_Addcallrecorder_SicOpaT.zip Stock LockScreen + Enabled Home Double Click DXLPB ICS LockScreen + Enabled Home Double Click DXLPB CWM_DXLPB remove incremental ringtones S2 icon CWM_DXLPB remove incremental ringtones S3 icon DXLPB_CRTOff_Activated DXLPB CRTOff_Deactivated PLUS MODS FOR XWLPF VERSION XWLPF added call recording (s3mods default) XWLPF Removed delay after call, Dialer with Contacts, Big Caller Image XWLPF Removed delay after call, Dialer with Contacts. Normal Caller Image XWLPF Restore old SII icon pack PLUS MODS FOR XWLPT VERSION XWLPT.NoCameraSound-S2 icon NoCameraSound-S3 icon XWLPT.Stock.LockScreen XWLPT.ICS.LockScreen XWLPT enable call recorder - s2tip.zip or here Hacked AOSP Email (4.0.4) (if you are switching from stock one you have to remove your account and clear Email/Exchange apps data) ******* Olds version here Mirrors are welcome Modifié 17 août 2012 par LuDoS2 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
seblabebete Posté(e) 3 juillet 2012 Share Posté(e) 3 juillet 2012 pas en fr!!!!!!!!!!!!!! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité Posté(e) 3 juillet 2012 Share Posté(e) 3 juillet 2012 Beau topic ;) Par contre, c'est quoi les caractéristiques de la ROM ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
LudoS20 Posté(e) 3 juillet 2012 Auteur Share Posté(e) 3 juillet 2012 (modifié) Elle n'est pas encore en FR Et pour les caractéristiques elles ne sont pas mentionnées sur XDA Modifié 3 juillet 2012 par LuDoS2 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Meyd Posté(e) 16 août 2012 Share Posté(e) 16 août 2012 Hello les amis ! La rom est passée en 2.1 et en Français ! Autant vous dire qu'elle est terrible ! Une fluidité remarquable ! Honnêtement je suis un maniaque de la fluidité surtout au niveau du scrolling des homes mais là je suis bluffé de ce que peu faire encore notre galaxy s2 ^^ Vraiment en toute objectivité cette rom est génial ! Si vous aimez Touchwizz mais surtout le galaxy s3 que vous ne pouvez pas vous offrir tout de suite et bien cette rom s'en rapproche grandement ! Du moins sur certains points lol il ne faut pas exagérer :) Mais ça vaut vraiment le coup de flasher ! Mode recovery wipe de tout ce qui bouge et c'est partie pour un pure bonheur :) J'espère que cette rom deviendra populaire car elle le mérite, j'ai tout essayé et à fond comme je l'ai l'habitude de faire, pas de bug pour l'instant ! Du moins pour ce que je fais avec ! Surf (vrai surf pas du Facebook et youtube lol) , wifi, téléphone, photo ,contact galerie stockage de mass etcc Voilà les amis j'espère que ce petit témoignage vous aidera ^^ Et désolé pour les fautes d'orthographe il est 22h30 j'ai vraiment la flemme de me relire :$ 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Neutre0 Posté(e) 16 août 2012 Share Posté(e) 16 août 2012 (modifié) @Meyd : Ton commentaire a fait en sorte que cette ROM m'intéresse, parce que je suis un maniaque de fluidité (et tout le monde le sait ici et ailleurs) et je préfère le TW du Galaxy S3 que celui du SGS II. A tester donc... ! EDIT : Avoir les icônes d'origine, ça ne serait pas du " Luxe " je pense. Modifié 16 août 2012 par Neutre0 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Meyd Posté(e) 16 août 2012 Share Posté(e) 16 août 2012 Oui honnêtement moi je trouve que ça s'en rapproche pas mal ! Après voilà j'espère juste ne pas me faire incendié si vous aimez pas mdr ou toi "Neutre0" ^^ Par contre j'ai remarqué que j'arrivé pas à le faire marcher en stockage de mass sur mon mac...ça craint un peu j'espère que je vais pouvoir trouver une solution...:( Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Neutre0 Posté(e) 16 août 2012 Share Posté(e) 16 août 2012 [color=red]tkt[/color], je ne te mangerais pas :P Si tu trouve la solution pour le stockage de masse, n’hésite pas à partager :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
seblabebete Posté(e) 17 août 2012 Share Posté(e) 17 août 2012 je reteste Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
LudoS20 Posté(e) 17 août 2012 Auteur Share Posté(e) 17 août 2012 Je vois pas de version 2.1 je vois juste la 2.0... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
seblabebete Posté(e) 17 août 2012 Share Posté(e) 17 août 2012 et toujours pas de FR!!!!!!!!!!!!!!!!!!! il faut la version LPF dans "more info go to here". 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Meyd Posté(e) 17 août 2012 Share Posté(e) 17 août 2012 C'est bizarre pourtant je l'ai bien en FR ! j'ai cliqué sur le lien ou il y a écrit : XWLPT ICS4.04.S3mods (thanks to Retseem)... Après il y a écrit dans le titre de la rom : ICS DXLPB/XWLPF/XWLPT S3mods V2.1 C'est qu'elle dois bien exister non ^^ ou c'est une preview ? Bref en tout cas je sais pas si je possède la 2.1 mais en tout cas de sur elle est en FRENCH ... Sinon non j'ai toujours pas trouvé de solution pour le stockage de mass et ça m'embête.. 2 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
LudoS20 Posté(e) 17 août 2012 Auteur Share Posté(e) 17 août 2012 Tu as raison dl en cours et maj du topic :) 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Meyd Posté(e) 17 août 2012 Share Posté(e) 17 août 2012 Impeck :) tu m'en diras des nouvelles ^^ Comme ça ça animera un peu ce Topic qui le mérite ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
LudoS20 Posté(e) 17 août 2012 Auteur Share Posté(e) 17 août 2012 J'aimerai bien avoir les icones en blue par contre tu sais comment faire ? Envoyé depuis mon GT-I9100 avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Meyd Posté(e) 17 août 2012 Share Posté(e) 17 août 2012 Non pas du tout je suis désolé :-/ du moins je me suis pas intéressé pour tout te dire mdr ^^ En faite c'est parce que je m'intéresse à un truc qui me prend bien la tête je vaudrais que le stockage de mass MTP soit en UMS !!!! J'aime pas du tout ce stockage de mass qu'il propose...parce que sur mon mac il connais pas...Et meme sur pc c'est délicat qu'il le trouve en lecteur multimédia...Si quelqu'un à une solution ça serais vraiment magnifique lol Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Kevin_93 Posté(e) 17 août 2012 Share Posté(e) 17 août 2012 Bonsoir a tous j'aurais quelques questions. Tout d'abord, je suis sous rootbox qui franchement je dois dire est vraiment top a mes yeux, c'est une aopk donc j'aimerai savoir si cette roman vaut la peine de revenir sur du stock ?? Quelle est la procédure a suivre pour passer de roman custom a rom stock ? Et ma dernière question c'est quelle est le petit plus de cette rom par rapport au autre ?? Merci d'avance pour vos reponses Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Meyd Posté(e) 19 août 2012 Share Posté(e) 19 août 2012 Salut Kevin_93, tout d'abord je te déconseille de flasher cette rom maintenant car tout simplement je me suis très vite emballé pour rien elle est pas mal buggé, j'ai eu avec le temps pas mal d'écran noir avec impossibilité de faire quoi ce soit...Et ce problème de stockage de mass me prend bien la tête..Donc pour l'instant je me suis tourné vers une rom aroma avec toujours touchwizz en attente mis a jour potentiel.. Ensuite pour répondre à tes interrogations, elle n'apportera rien de révolutionnaire...Mis a part peu être de la fluidité ou de l'autonomie, mais en terme de fonctionallité on fait pas de miracle, après je sais pas trop quoi te dire car je connais pas ta rom, j'ai jamais test.. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
lifenight Posté(e) 20 août 2012 Share Posté(e) 20 août 2012 (modifié) J'ai flashé la xwlpt (4.04) à partir d'une dilidroid 4.0.3, aucun fc, cette rom est très stable, je suis très étonné d'avoir pu faire un no wipe d'une rom custom à une autre sans problème ^^ :-) Très rapide avec son kernel speedmod k30, à voir pour l'autonomie sinon je passe en phenomenal 6.1 medium. La rom est bien en français aussi ;-) Merci de nous avoir fait découvrir cette superbe rom Modifié 20 août 2012 par lifenight Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Meyd Posté(e) 23 août 2012 Share Posté(e) 23 août 2012 A lifenight , tu n'as vraiment eu aucun problème ? C'est bizzare moi j'en avait pas mal, quand je voulais mettre l'appareil photo écran noir, quand je voulais mettre un widget style calendrier de samsung pareil, rien moyen de faire , ça buggé de tout les bouts..Par contre tu l'as flasher via recovery ? je sais pas ce que ça veut dire no wipe, c'est la rom via Odin c'est ça ? C'est dommage car j'avais vraiment accroché cette rom.. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
