[ROM CUSTOM][XXALF6][4 juillet] ╠█╣ RGUI V6.1 ╠█╣ ✰| Rapide.Legere.Batterie ++ |✰
RGUI V6.1
Lien du thread
XDA
Nouveauté du pack V6.1 :-
1. Fixed light manager
2. Mise a jours SU ( Root )
Changelog V6 :-
1. Ajout de plusieurs option dans le pannel Settings ( Criskelo )
- Fast Dormancy
- Light Manager
- Reglages de la statut bar
- Cpu Spy
- CPU Monitor
- CSC Change
2. Ajout du Jelly Bean Play Store
3. Ajout des Jelly Bean Wallapeprs
4.Correction des lags sur la Home
5. Ajout de nouvelle icônes pour le Statut bar
Previous changelog :-
- added 15toggles as default with new layout,
- home+power button wakeup
- Fixed Cell standby battery drain
- hacked mms.apk
- black themed settings, file manager. ( other you can flash from add ons section)
- Enabled notification,touch sound etc. sounds
- Updated Su binary
- Added clock package
1. rearranged toggles
2. power button wake up only
3. Increased notifications,ringtone,speaker volume & Disabled camera sound
4. Disabled non market app restriction by default.
5. Stock kernel with init.d support
6. Blue ics battery icon with left side clock ( for other mods check post 2 )
7. Added AOSP apps as Add-ons
---> calender,calculator,email,exchange,mms,deskclock,3 D gallary,keyboard,live wallpaper
8. Disabled lockscreen 4way rotation
9. Enabled keyboard change icon
10. Added Android battery icon
11. TW Launcher redraw is minimised by the modified services.jar thanks to UpInTheAir for the information
12. Accuweather app added as requested by users
13. Updated Gapps
14. Disabled scrolling cache
15. Enabled Call recording thanks to wanam
16. Removed sms log from call log thanks to wanam
17. Added 4way reboot thanks to kristofpetho
18. Removed keyguard and other security policies from email app
19. init.d script support
20. Samsung Camera HX-MOD v1.35 by hyperX
21. Cleaned up build.prop and Init.d for better results
22. Tweaks for Sqlite optimisation
23. Increased touchscreen sensitivity
24. Zipalign apps at boot
25. Tweaks for smoother scrolling
26. Removed bloatware apps
27. tweaked kernel governors
28. Removed weather widget, you can download it
29. New live wallpaper
30. Proximity sensor tweak, minimized duration of black screen before call screen appears
31. Minimized duration between two rings
32. tweaks for wireless connectivity
33. HD Youtube player
Download Link
FAIRE UN FULL WIPE !!!!!!
Mise à niveau Pack V6.1 :-
IMPORTANT:-
Wipe Cache/Data/Dalvik avant de flasher..
Traduction du ChangeLogs en cours.
Je ne peux pas uploder les screenshots " votre quota d'envoi global restant est de L'envoi de fichiers n'est pas autorisé "
Modifié par iHeath
