akaaz Posté(e) 12 juillet 2012 Share Posté(e) 12 juillet 2012 (modifié) Android 4.1.1 JellyBean pour Defy et Defy+ AVERTISSEMENT : Ces manipulations ne sont pas sans danger. Donc ni moi, ni un membre du forum, ni Frandroid ne pourront être tenus responsables en cas de brick total d'un téléphone. Lien de Quarx: Download Link: http://quarx2k.ru Mirrors: http://defy.bytekiste.de/ http://d-h.st/users/Quarx http://mirrow.downlo....de/quarx2k.ru/ http://download.gala...s/diverse/CM10/ http://volkov.ath.cx/quarx2k.ru/ Lien de Epsylon3: http://defy-cm.net/ Gapps: http://goo.im/gapps/ Mini gapps (Gmail,Market,Gtalk,Synchronisation) http://quarx2k.ru/ga...726-minimal.zip Gapps + Working Google Now - http://forum.xda-dev....php?p=30988910 Status de la ROM de Quarx: 12.07: Boot up 14.07: Phone, Mobile Data, USB, Mass storage, Sensors, Camera(Photo), GPS/AGPS. 18.07: Audio (thanks to maniac103), Video rec/play, Panorama, FM-Radio. 19.07: Install app to sdcard, mp3 codec, video codec fixes, rework fm-radio, cyan update. 22.07: Usb fixes, USB Tethering, Data Usage, Preferred Network (umts/cdma) selection, CrystalTalk 23.07: Fix audio lock-ups (thanks to nadlabak), a2dp, fix volume change, OS FMRadio and fm volume change in background by maniac103, leds 26.07: Themes, button backlight, fix lag bootanimation, imei/mac... cyanogen updates. 28.07: re-fix button backlight, holo fm-radio, Option for enable/disable On-Screen Button(36dp) 04.08: Fix volume rocker music controls, Realtime switch of OnScreenButtons and size of it, Phone/SMS apps now in memory all the time, Enable CPU TLS Register, Auto-Backlight Settings, Boosted governor by default... maybe forgot some more.. 08.08: Improved stablity of camera (bayer have problem with sound), DroidSSHD, Trebuchet, common stablity fixes. 10.08: update Moto RIL to v4, fm-radio to lockscreen, hwui blacklist on mb525, fix realtime OnScreenButtons, Fix MotoPortal, Disable get local ipv6 adress. 12.08: Auto-backup battd, Port phone features from cm9, Add national data roaming and make it optional (from AOKP). 22.08: Fix ability change brightness of buttons(Defyparts), compass fix, Apollo intent fix (which fixes last.fm etc), dalvik heap 128mb -> 48mb, wifi changes 25.08: Disable lock in memory Phone and sms apps(by users requests), fix OnScreenButtons, ipv6 tweaks. 28.08: Fix 00:00:00:00:00:00 SSID in apps, fix audio routing in dock modes 03.09: Fix Audio in video rec(not ideal) and decrease fps in preview camera (not in video), 2Channels for audio, DSP-Manager in software which support JB (ex, apollo) it's not a bug, support multiboot, wifi-tethering (thanks ot devs of ml2, maybe have bugs, not tested) 04.09: Fix compass, update sgx libs to JB, fix wallpapers, improve video perfomance, new touch driver (for test, only 2 fingers for now, more will be enabled in next build) 2ndboot builds: 10.10 Android 4.1.2, CRT-Animation , custom kernel, experimental. Included patch for flashlght(not tested, but shouldn't burn it) 11.10 Fix red camera, updated 2ndboot.ko, fix pds mount and permissions.. 18.10 Kernel update:fix wifi tether(reboot), reduce battery drain, fix charge only mode, cleanup unused drivers, fix button lights, fix slow boot and lags after boot. 02.11 Add power hal, interactive governor+bootpulse(should be default in bootemnu for correct work power hal),kernel fixes from upstream, cleanup/disable unused drivers, fix SGX clocks, add bp_ptc service(only service), fix battery drain, add fuse rw-ntfs/extfat fs support(not tested, but should work), fix backlight settings, fix small problem with fm-radio on notfication drawer, add cm file manager(can work incorrect), restore live wallpapers, cm sync.... 17.11 Update kernel to 2.6.32-60, backport some optimisation from 4.2, fix mount options for ext4, cyanogen update, restore conversion to RGB->YV12 for video. 18.11 Apply many optimisations: Android compiled with latest Linaro toolchain GCC-4.7, kernel compiled with Linaro toolchain GCC-4.5.4. Little wifi fixes. 28.11 Disable linaro for android, fix adhoch, new battd, fix bt. 04.12 Partial linaro, Fix upnp/dlna(thanks to nadlabak), fix reboot in bootmenu/recovery, cyan fixes. 05.12 Fix root, fix adb, fix ROOT/ADB settings from dev menu , cyan fixes. 22.12 Stability fixes, cyan updates. 23.12 Fix shutdown, built-in call rec function(thanks to nadlabak). 29.12 Revert to .9 kernel (for audio tests and stability), fix root permissions on CMFileManager, adb can be disabled now, bootmenu now has only one custom recovery option. 30.12 Restore .60 kernel, some fixes in android which can cause ringing problems. 07.01 Again fix root permissions on CMFileManager, fix battery when ADB disabledl, again some fixes which can cause ringing problems. 17.02 rgnd service, increase performance of camera. TODO: video rec fix, fix restart wifi tether. NOTE: Froyo Kernel + MB526 or GB Kernel + MB525 Build = Not working proximity. Pour faire un don à Quarx, pour son super travail: https://play.google.....om.donatecm_10 :) Pour installer, cette CM10: 1/ Télécharger la version de la rom CYanogenMod10 ainsi que les gapps, que vous voulez installer sur votre téléphone. 2/ Le placer sur votre carte SD 3/ Redémarrez votre téléphone et lorsque la LED bleu s'allume, appuyez sur volume (-). 4/ Choisir le costum recovery. 5/ Faire un wipe data/cache (Perte de vos donner telephone /!\ ) OU wipe cache et wipe dalvik si c'est pour update. 6/ Aller dans l'onglet install zip from sdcard / choose zip from sdcard et sélectionner la rom CyanogenMod10 préalablement placée sur la carte SD. 7/De meme pour les gapps 8/ A la fin de l'installation, vous pouvez reboot votre téléphone. Fix: Fix pour batteries des defy avec lentille rouge: http://forum.xda-dev...22&d=1344093287 Merci Zecko !! ENJOY !! Modifié 19 février 2013 par akaaz 5 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
mitsoumithaux Posté(e) 12 juillet 2012 Share Posté(e) 12 juillet 2012 (modifié) Plus qu'a attendre ! ça ne va pas tardez pour le defy! Quelqu'un a tester sur defy+ Modifié 12 juillet 2012 par mitsoumithaux Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
matyeux Posté(e) 12 juillet 2012 Share Posté(e) 12 juillet 2012 :) en voila une bonne nouvelle ^^ bon ça reste une version "pré-alpha" mais tout de même ça fait plaisir (je n'ai eu le courage/motivation de tester par contre :P ) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
akaaz Posté(e) 12 juillet 2012 Auteur Share Posté(e) 12 juillet 2012 Qand j'ai vus ca je me suis depeché de le partager. Oui une pres-alpha mais tout les rom passe par la !! :P Enjoy !! 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Zecko Posté(e) 12 juillet 2012 Share Posté(e) 12 juillet 2012 (modifié) Ouhhh mon cher Tailhandier alias Akaaz, tu prends la relève ;)? Ce Defy est loin d'être mort d'après ce que je vois! Modifié 13 juillet 2012 par Zecko Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
akaaz Posté(e) 12 juillet 2012 Auteur Share Posté(e) 12 juillet 2012 Il faut bien puisque tu te sauve !! :P Ce bon vieux Defy serait encore mieux avec un Bootloader deverouillé !! :( Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Burn2 Posté(e) 12 juillet 2012 Share Posté(e) 12 juillet 2012 Voué enfin il faudrait déjà une version 4.0 stable ça serait déjà ça. Commencer à rêver sur la 4.1 alors qu'aucune 4.0 n'est encore 100% stable c'est pas trop la peine. :D Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Zecko Posté(e) 13 juillet 2012 Share Posté(e) 13 juillet 2012 C'est pas en étant pessimiste que tu vas faire avancer le projet... Certes la 4.0.x n'est pas stable et 100% fonctionnel mais cette version était une mise à jour majeur, il faut réécrire tout le code alors que la 4.1.x n'est qu'une amélioration. Sur ce portage là, nul besoin de réécrire tout le code... 2 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Diogo De Oliveira Posté(e) 13 juillet 2012 Share Posté(e) 13 juillet 2012 Il me semble que c'est une sauvegarde, il faut donc l'installer en faisant une restauration (je ne sais plus le terme exact). On pert donc toutes nos données et applications ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
akaaz Posté(e) 13 juillet 2012 Auteur Share Posté(e) 13 juillet 2012 Perso, je la flasherai et par dessus une CM9. Suivi d'un wipe data/cache. Quarx ne donne aucun details pour le moment. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
matyeux Posté(e) 14 juillet 2012 Share Posté(e) 14 juillet 2012 Le 13/07/2012 à 15:30, diogo65 a dit : Il me semble que c'est une sauvegarde, il faut donc l'installer en faisant une restauration (je ne sais plus le terme exact). On pert donc toutes nos données et applications ? Je viens de tester effectivement c'est une sauvegard et on perd toutes les appli/données vue qu'il faut faire une restauration... l'appareil photo n'est pas foncitonnel, je ne teste pas plus loin, retour sous CM9 en ce qui me concerne pour le moment ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
akaaz Posté(e) 14 juillet 2012 Auteur Share Posté(e) 14 juillet 2012 Premier courageux !! Merci, pour ces precision. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
matyeux Posté(e) 14 juillet 2012 Share Posté(e) 14 juillet 2012 (modifié) la nouvelle version (du 14/07) est nettement meilleur, il s'agit d'un rom a flasher. j'ai fait un Wipe Cache + Flashage de la rom directement sur la CM9 + Wipe Cache + Wipe Dalvik et ca roule ;) l'appareil photo fonctionne par contre le menu de paramétrage me semble ultra succin, je vais approfondir ca ^^ en tout cas elle est testable en l’état :D [Edit : je n'arrive plus a passer en recovery pour restaurer une CM9, une bonne nuit de sommeil ça devrait aller mieux après ^^] [Edit 2 : la fonction appel n'est pas fonctionnel au faite ^^ ] Modifié 15 juillet 2012 par matyeux Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
matyeux Posté(e) 15 juillet 2012 Share Posté(e) 15 juillet 2012 Un double post pour vous faire un retour un peu plus complet sur cette première version JB sur nos chère Defy(+) l'installation ce fait comme une MAJ CM9 classique chez moi tout c'est lancer normalement, le GPS fonctionne, l'appareil photo aussi par contre le haut parleur a été désactiver (du coup plus possible d'appeler) les problèmes arrive lors que l'on veut revenir en arrière, cette version a virer le Root de mon tel du coup plus de recovery :S j'ai fait quelques recherches sur xda a priori il y a une série de script adbshell a faire tourné pour le récupérer, mais bon... Du coup je suis passer par un reflashage du sbf initial du defy et c'est repartie pour la procédure complète, mais après ça il est possible de faire une restauration du coup tout va pour le mieux. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
edowin Posté(e) 15 juillet 2012 Share Posté(e) 15 juillet 2012 Oui en effet, aucun son pour l'instant. Mise à part ça cette rom serait utilisable. Chrome fonctionne déjà pas mal, wifi et 3g ok. Appareil photo ok. Il y a même des moments ou elle à l'air plus fluide que la Cm9, entre 2 lags :). Pour l'install j'ai flashé la version kernel froyo de quarx (http://quarx2k.ru/cm10-nightly-defy/) en partant de la Cm9 et ça n'a pas posé de problème. Pour terminer, j'ai fait un restore de ma CM9 depuis le recovery qui a egalement fonctionné. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
matyeux Posté(e) 15 juillet 2012 Share Posté(e) 15 juillet 2012 @edowin pas de problème de root ? sur defy+ il disparaît avec le flashage (enfin sur le miens en tout cas ^^ ) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
edowin Posté(e) 15 juillet 2012 Share Posté(e) 15 juillet 2012 si la rom n'est pas rooté, mais ça ne m'a pas empêcher de faire un restore depuis le recovery Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
matyeux Posté(e) 15 juillet 2012 Share Posté(e) 15 juillet 2012 je crois que c'est là où je pèche je n'ai pas trouver le moyen d’accéder au recovery ... (mais je doit être a la masse ) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
edowin Posté(e) 15 juillet 2012 Share Posté(e) 15 juillet 2012 c'est vrai que tu n'as plus l'accès recovery depuis le menu reboot. Mais au redémarrage tu peux appuyer sur volume bas quand la led s'allume et tu peux normalement accéder au recovery. J'ai pas bien fait attention, mais il me semble pas que mon recovery ait changé apres le flash cm10. 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
matyeux Posté(e) 15 juillet 2012 Share Posté(e) 15 juillet 2012 ok merci, je n'ai pas du m'y prendre correctement je pense, je vérifierai lors des prochaines version (la prochaine avec le son je pense, pas avant ^^ ) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Diogo De Oliveira Posté(e) 16 juillet 2012 Share Posté(e) 16 juillet 2012 (modifié) Petit retour, j'ai installé JB, j'en suis assez content, c'est aussi fluide que la dernière ICS par Epsylon. Quelques soucis tout de même : Impossible d'installer certaines application comme Draw Something, DansTonChat Officiel ... Quelques application en double : galerie, appareil photo (masqué avec Apex Launcher) Pas aussi complet que CM9 : Il me manque le déverrouillage avec touche volume et les raccourcis dans la barre de notification. Google Now ne fonctionne pas. Pas de son, problème majeur, mais je reste sur JB en espérant que ce soit vite réglé. Sinon points positifs : Nouvelle barre de notification, ensemble fluide, nouvelles animations ... Modifié 16 juillet 2012 par diogo65 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Raphael-1427 Posté(e) 17 juillet 2012 Share Posté(e) 17 juillet 2012 Salut ! C'est mieux que WhiteRabbit 1.6 ? J'ai un Defy +. Merci d'avance :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
matyeux Posté(e) 17 juillet 2012 Share Posté(e) 17 juillet 2012 Salut passe plutôt sur Cm9 pour l'instant c'est plus fonctionnel 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Husi10 Posté(e) 17 juillet 2012 Share Posté(e) 17 juillet 2012 CM10 n'est je pense pas encore prête pour une utilisation quotidienne. Pour l'instant le son ne fonctionne pas à cause de nouvelles librairies qui permettent le son en temps réel. Cette librairie utilise des instructions qui n'existent pas dans le kernel et comme le bootloader est verrouillé il est impossible de les intégrer. 2 solutions : on remplace la nouvelle librairie par celle de CM9 qui fonctionne mais on perd à ce prix certains avantages de CM10. Soit on essaye d'adapter la librairie avec les instructions incluses dans le kernel, beaucoup plus compliqué mais les dev sur Defy sont de grands génies ! 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
yazus Posté(e) 17 juillet 2012 Share Posté(e) 17 juillet 2012 Je ne comprend pas pourquoi motorola ne veux pas le débloquer surtout que le téléphone commence a bien daté... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
