[ROM] Brainmaster's Stock JB 4.1.1
What do you get with this ROM?
Its Full Stock JB 4.1.1 ROM that includes following
Tweaks:
- Deodexed
- Rooted
- Zipaligned
- Busyboxed
- Busybox Run-Parts (support for scripts in the init.d)
- Supercharged
- Circle Battery
- Unsecured Boot.img
- ADB Enabled
- EXT4 and TCP Tweaks
- Dalvik moved to the /cache partition
- Advanced automated Zipaligning of system/app and /data/app
- ADFree Hosts file
- Sticky Recovery (Custom recovery doesn't get overwritten after flashing the ROM)
- Unicode support for SMS/MMS
- AppWidgetPicker
- 360° Rotation
- Symlinked SDCard to /storage/sdcard0
DISCLAIMER:
You are installing this ROM on your own risk!
How to install:
- Copy ROM file on your SDCard' date='
- Start Recovery,
- Go to "mounts and storage" and select format /system, /data, /cache, /boot,
- Install ROM,
- Reboot,
- After the Setup procedure, let the Phone settle down for few minutes.
Further Instructions:
Don't forget to Force the GPU Rendering in the Developer Options.
Download:
Brainmasters.JB.4.1.1.JRO03E.Nexus.S - Size: 198 MB MD5: 1c7f4896c52937a4fce912db33a7104a
If you like this ROM you can support my work with a PayPal Donation.
Note:
This is probably my last tweaked ROM for the Nexus S Community, since I'll be probably moving in the next weeks to GNex.
You are great guys and great Community - thanks for supporting my work. Without you, I wouldn't spend so much time tweaking my Phone.
Le thread XDA est ici : http://forum.xda-dev...d.php?t=1786043
A noter que de base l'icône de la batterie a été modifié (comme dit dans le changelog), si vous voulez avoir celui de la stock, flashez par recovery le fichier qui se trouve ici : http://forum.xda-dev...78&d=1342821740
Enjoy !
___________________
Je l'ai installé, pas de problème notable, elle est plus réactive que la stock je trouve ! J'attends maintenant un petit kernel des familles qui ira bien avec !! ^^
Modifié par Lebep
celle d'Adam est trop "stock" pour moi vais tester celle de brain
finalement non car brain arrêté après pour le NS et passe au GN -_-
Modifié par Snouki
Celle la :
http://forum.xda-developers.com/showthread.php?t=1786289
je vais tester,car une rom stock ..........berk
On te reconnaît bien là xD
Il faisait des roms du tonnerre pour le X10 Mini Pro !
Oui c'est plus rapide,
mais parce qu'elle est optimisée (surtout certains comme moi = 8 mois a la paufiner) mais lorsque JB sera bien réglée avec le bon kernel,ce sera quasi aussi fluide dans les menus,listes,applis.
Ya deja du bon sur les bureaux.Et JB apporte des choses en plus (qui ne sont pas utiles pour moi)
C'est une progression évidente pour la majeure partie des fans.
Fin du HS,désolé.
Sacré Funk lol
ROM de AdamG [ROM-AOSP JRO03H 4.1.1] JellyBelly 0.1.2
Changelog
0.1.2 [21/07/2012]
Added BLN
Added MusicFX and JB Gmail
Set default wallpaper to static JB wallpaper on first boot
Updated kernel to v3.0.38*
* Custom kernel compiled and maintained by _thalamus
Modifié par Snouki
