[ROM-AOSP JRO03H 4.1.1] JellyBelly 1.0.0
Rom AOSP développée par AdamG dans la lignée des Rom Oxygen.
Features
tick.png Android v4.1.1 (JRO03H) built from AOSP
tick.png Linux kernel v3.0.38
tick.png Google apps
tick.png Superuser
tick.png Busybox
tick.png Deodexed
Additional features
tick.png Advanced power menu with reboot and screenshot options
tick.png Battery percentage
tick.png Big HighMem (alternative kernels will kill this feature)
tick.png BLN
tick.png Cursor enabled keyboard with volume keys
tick.png Download any file type
tick.png Facebook contacts sync
tick.png Init.d script support
tick.png Receive any file type via Bluetooth
tick.png SIP calling over 3G
tick.png Status bar toggles
tick.png T9 Dialer
tick.png Touch to focus camera
tick.png Volume button music controls
tick.png Volume button wake
tick.png Voodoo sound
tick.png Various other tweaks and features
Downloads
http://download.adamg.co.uk/android/roms/crespo/JellyBelly-1.0.0.zip
Changelog
1.0.0 [31/07/2012]
forward.png Added am/pm to clock when 12hr option is chosen
forward.png Fixed automatic timezone failing for some users
forward.png Fixed random reboots that affected some users
forward.png Fixed stk
forward.png Fixed su
forward.png Fixed yellow tint for that affected some i9020 users
forward.png Updated kernel * **
* Custom kernel compiled and maintained by _thalamus
** Please note with this release you will not be able to use
an alternative kernel, I will remove this limitation when
I'm satisfied that no bugs are present, this has been
placed here so I can rule out specific issues.
0.1.5.1 [28/07/2012]
forward.png Fixed gallery
forward.png Fixed music
0.1.5 [27/07/2012]
forward.png Added cursor mod to keyboard
forward.png Added init.d script support
forward.png Added status bar toggles *
forward.png Added touch-to-focus to camera
forward.png Fixed long press back to kill
forward.png Fixed panaromaic camera mode
forward.png Fixed screen off animation
forward.png Remapped assist key back to original search key
forward.png Updated gapps
forward.png Updated su
forward.png Updated kernel **
* Enable under Settings > Developer options > JellyBelly
** Custom kernel compiled and maintained by _thalamus
0.1.4 [23/07/2012]
forward.png Added long press back to kill *
forward.png Added big highmem (experimental) **
forward.png Added volume button music controls *
forward.png Added volume button wake *
forward.png Updated Gallery to GoogleGallery ***
forward.png Updated kernel ****
** This frees around 50mb of RAM by remapping memory, the only drawback of this is the loss of 1080p playback
*** This should enable the use of Picasa in the Gallery
**** Custom kernel compiled and maintained by _thalamus
0.1.3 [22/07/2012]
forward.png Added battery percentage *
forward.png Added nexus boot animation
forward.png Added t9 dialer mod
forward.png Fixed backup service
forward.png Enabled HSPA icon
0.1.2 [21/07/2012]
forward.png Added BLN
forward.png Added MusicFX and JB Gmail
forward.png Set default wallpaper to static JB wallpaper on first boot
forward.png Updated kernel to v3.0.38*
0.1.1 [21/07/2012]
forward.png Deodexed all applications and framework
forward.png Fixed modversion in About
Lien du sujet sur XDA : http://forum.xda-dev...d.php?t=1786289
Modifié par Yoz
Cette Rom est à mon avis la meilleure sous JB pour le moment.
Fluidité permanente, je n'ai constaté aucun lag, même en utilisation intensive (jeux, 3g...)
Autonomie qui m'impressionne : 1% de batterie en moins après 2h en veille (3g connéctée, synchronisation activée)
J'était sur la version 1.4 et j'ai flasher l'update, mais depuis je ne pas la possibilité d'instaler Google Play Musique ( erreur 22 lors de l’installation apres le téléchargement )
Sachant qu'il me faut absolument Play musique qu'en penser vous ?
Quelqu'un d'entre vous a ce probleme ?
Et lors du reboot avec l'AirKernel ( version JellyBean) j'ai le Google avec le cadenas ouvert mais apres il s'eteind sans l'annimation de demarage --"
Quelqu'un a aussi ce probleme ?
Ouais j'ai eu pareil...
La solution que j'ai trouvé, c'est de télécharger Google Play Music sur frandroid ici . Tu peux les instructions qu'il y a sur la page. Sachant que moi, j'ai eu besoin de faire un adb remount (dossier /system/app en écriture seule)
Modifié par Dvorak
