Achotjan_Stock_Remplacement_Rom | X10i_2.3.3_6.0.B.0.743_V2.0 | -Released-
Achotjan Project
video review thanks Tof37
U_4nbZD1pY4
Achotjan_Stock_Remplacement_And_Firmware Update
Hy this is a Sony Unofficial Firmware Update with sony Xperia S Firmware app and theme
Feature Inclueded In This Rom :
--- Stock Based ---
--- Stock Camera ---
--- Xperia S loockscreen ---
--- New semc tabhost widget ---
--- Mobile Bravia Engine ---
--- Xperia xLoud ---
--- Windows Media Audio Support !! ---
--- Sony Music Player ! ---
--- Sony Theme ! ---
--- Gallery with Facebook integration ---
--- Latest Sony Xperia S 6.0.A.3.73 Firmware ---
--- Facebook inside Xperia and more ... ---
Credits : Tof37 , SEMC , and all x10 developpers / community
shot000002m.pngscreenshot1335188573991.pngshot000011.pngshot000006k.pngscreenshot1335188607987.pngscreenshot1335188796434.png
If you dont want the full ROM and like more a light rom without many extra sony apps:
tray the Light vérsion of This ROM ( thanks to Tof37 )
Lite Version
REQUIREMENTS
  • xRecovery
  • Locked or Unlocked bootloader
Added Xperia S 2.3.7 Firmware
  • Loockscreen !!!!
  • Semc Theme !!!!
  • Semc Music
  • Facebbok inside Xperia
  • Timescape
  • Semc Phone 2.3.7
  • InfiniteView
  • Track ID
  • And all 2.3.7 SE Xperia S app ...
WORKING (Everything)
  • phone & data
  • location (GSM and GPS)
  • BT
  • WIFI
  • Multi Tuch (dualtouch)
  • sensors
  • Voice Command
  • GPS
  • USB Storage
  • video playback
  • video and audio streaming
  • 8mp pics
  • USB tethering
  • wifi tethering
BUGS
- no known bugs
INSTALLATION
  1. Go to xRecovery
  2. Do a factory reset
  3. Wipe Cache Partition
  4. Wipe Dalvick cache
  5. Wipe Battery stats
  6. Flash the "Achotjan_X10i_6.0.B.0.743_Generic_v2.0_Part_1.zip " package do not reboot
  7. Flash the "Achotjan_X10i_6.0.B.0.743_Generic_v2.0_Part_2.zip " Reboot
  8. Enjoy !
Check Post #2 for detailed changelog for each version
Check Post #3 for Addons and Extras
DOWNLOAD ROM
[center][size="4"][b][url="http://www.mediafire.com/download.php?836p4v2xcnxx8et"]Achotjan_X10i_6.0.B.0.743_Generic_v2.0_Part_1[/url][/b][/size][/center]
[center][size="4"][b][url="http://www.mediafire.com/download.php?3gltw5wn0s94sx7"]Achotjan_X10i_6.0.B.0.743_Generic_v2.0_Part_2[/url][/b][/size][/center]
DONATION
Modifié par Achotjan
Quel est la différence entre cette Rom et la Semc Debrand Engine V9 FXP?
Ensuite, j'aurai une seconde question mais plus personnel.
Comment faites vous vos Rom? Je veux dire, vous êtes déjà développeur? Si oui, qu'avez vous comme études? Sinon, comment avez vous appris à développer?
Merci d'avance. :)
edit : désolé pour le double post. :/
Modifié par monky62
Une ROM de notre ami Achotjan ??? Hum, je m'en méfie. Est-ce que quelqu’un pourrait me dire si cette ROM est stable et fonctionnel à 100%, histoire de voir autre chose que Wolfbreak, seule ROM stable à mes yeux et qui date depuis décembre 2011.
Franchement je tourne depuis environ une semaine sur cette ROM. Elle est nickel. En meme temps je fais rien de spécial avec.
Niveau autonomie, elle tient facilement la journée. Il me reste 30-40% environ quand je vais me coucher. ;) (sans No-frills CPU)
Sinon, l'appareil photo fonctionne nickel (en même temps je viens de la CM9, donc il m'en faut peu pour être satisfait. ^_^ ).
Niveau vidéo, j'ai pas testé.
Le GPS, Bluetooth fonctionne.
J'ai en moyenne un redémarrage du téléphone tout le deux jours. Peut être parce que la RAM est trop rempli.
Le seul problème que j'ai trouvé c'est qu'il n'accepte pas le DoomKernel overclocké.
Ensuite, la gestion du cpu ne doit pas bien etre fonctionnelle avec No-frills CPU. Le téléphone se crashe quand on demande trop de chose. (Ex : lorsque je cours j'utilise Endomondo, donc utilisation du GPS, de la data, du bluetooth pour la musique avec le MW600, le téléphone s'arrête au bout de 10min, donc je pense que le processeur doit passer soit en 245Mhz, ou en DeepSleep d'où le problème)
Enfin, le seul truc qui me dérange un petit peu c'est l'affichage de la batterie. (Il n'y a pas le pourcentage juste l'icone de la batterie). Mais bon je vais regarder comment fonctionne UOTKitchen ce weekend pour modifier ça. (si vous avez une autre solution, je suis preneur :) )
Ah si, il y a un dernier truc qui me dérange c'est : la résolution du "bureau" : 4 x 4 . pas moyen de changer cela. mais, je le savais déjà, c'est le cas pour toutes les ROM simulant l'Xperia S. -_-
@gaja : Je viens juste de testé et les mms sont fonctionnelle.
@adoleboss : Merci du petit conseil je vais regarder ça demain. ;)
@ocin49 : il te met fait quoi? Si tu as utilisé le doomkernel, tu as bien installé le bon patch wifi?
  • 1 month later...
