HTC et S-OFF: Pétition universelle
HTC peut donner une réponse générique à un seul utilisateur, mais peuvent-ils faire la même chose pour un milliers utilisateurs?
abc27 membre d'XDA à crée une pétition dans le but de faire changer la politique d'HTC.
Pour ma part j'ai signé, on véra bien si cela abouti.
We, the undersigned, are formally requesting that HTC consider extending end users the ability to turn on/off the platform security on their phones (S-OFF) preferably through a method that also permits full access to the phone's software partitions (For example: "APX/NvFlash" mode on the Tegra platform). This would be a further development on the current "Bootloader Unlock" being provided on the domain htcdev.com for certain devices. Such a feature, if granted would greatly ameliorate the esteem developers and non-developer users have for HTC for its relationship with its customers.
Collectively, we also wish to make it clear that we acknowledge the risks involved with such a feature and understand that HTC is not liable for any faults caused through software modifications carried out by the end user. HTC reserves the right to refuse warranty repair on this basis providing sufficient evidence of user-induced damage is present. We are requesting that if HTC are to respond positively to this feature request that they would also make it clear that within the terms of their limited warranty and with the statutory rights of the consumer undisturbed they will not invalidate the limited warranty for instances of faults clearly arising from manufacturing errors. We would also request that any such statement would be clear in its terms without resorting to ambiguous terminology such as "may".
We also wish to state that we are aware of HTC's carrier agreements which may make such a feature impossible to implement on customised devices sold by certain carriers. With this in mind, we wish to make it clear that we are requesting such privileges only for devices that are sold as "sim-free" or by carriers who do not actively oppose such features.
Sincerely,
The undersigned customers of HTC
voir les signataires : http://goo.gl/9a1pz
signer la pétition ici.
lien du sujet XDA
http://forum.xda-dev...d.php?t=1657241
Modifié par naruz
Bien vu, merci de l'info.
Signé
Envoyé depuis mon HTC One X avec Tapatalk
Présente la dans les autre section htc, ca pourrait les interresser ;)
Je signe en prévision d'un futur achat :P
  • Auteur
c'est fait ;)
  • 1 month later...
  • Auteur
un petit up pour ceux qui n'auraient pas vu le sujet et pour ceux qui auraient oublié de signer. :)
Qu'est-ce que le S-OFF ?
S-OFF veut dire Sécurité-OFF.
S-OFF signifie que la partie NAND de l'appareil est débloqué et qu'on peut écrire dessus. Le réglage par défaut pour les appareils HTC est S-ON, ce qui signifie que ne vous pouvez pas accéder à certaines zones du système et que vous ne pouvez pas avoir un accès root permanent. En outre, la vérification de signature pour les images du firmware est également assurée par le drapeau S-ON.
S-OFF – Qu'est-ce et Pourquoi ?
HTC a installé une sorte de vérification de sécurité dont le niveau est déterminé par S-OFF/S-ON.
Essentiellement, ce niveau de sécurité est un drapeau stocké sur la radio de l'appareil qui vérifie les signatures d'images pour n'importe quel firmware avant qu'il ne soit autorisé à écrire dans la mémoire système. Cette entrave restreint l'accès à la mémoire flash NAND pour utiliser les roms customs, splash images, recovery, ....
Toutefois, lorsque le niveau de sécurité est défini sur S-OFF, la vérification de signature est court-circuité, ce qui permet à un utilisateur de télécharger des customs firmware, démarrage non signé, recovery, splash et images HBOOT, ainsi que le firmware officiel qui a été modifié, ce qui active un maximum la personnalisation de votre dispositif Android HTC Android.
En outre, le S-OFF permet également de réduire les restrictions d'accès à la mémoire flash NAND sur le périphérique, ce qui permet d'avoir accès à toutes les partitions (y compris / système) pour être monté en mode écriture tandis que le système d'exploitation est démarré.
merci à colonel59 pour cette belle définition
Bref, le gros avantage du S-OFF, on peut re-allouer la taille des partitions de la NAND.
Mettre à jour le HBOOT pour avoir les mises à jours avant les sorties officiels. EX: JB+ sense 4.5 :emo_im_undecided:.
Surtout devenir SUPER CID, et pour pouvoir virer la couche pourri de Orange ou de SFR sans devoir flasher une rom custom.
Voila.
Modifié par naruz
En tout cas tout ceux qui ont un téléphone opérateur ne pourront certainement pas profiter de JellyBean sans le S-OFF, malheureusement...
Dans la release de football diffusée sur xda (JB 4.1 et Sense 4.5) le réseau GSM ne fonctionne pas (on ne peut pas appeler quoi) car il faut mettre notamment à jour le hboot pour tenter de le faire fonctionner.
Et donc on en revient au même problème: pas de S-OFF = impossible de mettre à jour le hboot = impossible d'utiliser pleinement JellyBean.
Par contre ceux en téléphone nu, pourront mettre à jour leur hboot par RUU (le RUU officiel de JB devrait sortir en octobre/ novembre).
Les autres il faudra attendre la RUU opérateur avec JB inside, soit dans un an environ :) (si ça sort un jour..).
donc même avec des roms customs sur JB on ne pourra pas les utiliser avant d'avoir mis à jour son hboot par RUU, donc uniquement les téléphones achetés nus si vous m'avez suivi...
Sacré mauvaise nouvelle pour nous les bidouilleurs, j'avoue...
Le problème principal réside toujours dans la protection S-ON qu'HTC s'obstine à implémenter pour vendre ses téléphones plus chers !
Et malgré la pétition, je pense qu'on aura jamais de S-OFF, le développement sur xda est arrêté car ils sont dans une impasse...
