Samoht59 Posté(e) 20 septembre 2012 Share Posté(e) 20 septembre 2012 Traduction en cours CheckROM EvoHD: Infos: Based on XXBLH1 Firmware from Samsung Kernel: Stock Samsung LH1 (Hacked) (Samsung Built love with Team induced chemistry ) Baseband: XXLH1 SuperSu v0.94 No Wipe Scrolling Made Smoother Build.prop tweaks Hardware Acceleration Enabled (GPU UI Enabled) Multi CSC Deodexed Zipaligned BusyBox Sd Card Speed Fix %Battery (Use settings>>Display>Battery percentage) Most of the Samsung widgets and app's removed! Fully optimized .png's Smooth animation's Installation Script cleanup/optimization Added Jelly Stock Animations Added Crt-OFF Effect Volume Keys mapped to Skip Music OOM Priority Charger Reduced Touchwiz Redraw Smooth Spinners Added Traditional Extended Power Menu Fixed the Cell Stand By issue Optimized Ram Téléchargement: CheckROM_EvoHD_RC2_XXDLI8 (no mirros please, Support our Server) Instructions pour l'installer: You can be on any rom You need to have CWM5 and ROOT You need to do a full wipe manually Download ROM Put in your SD Card Reboot to Recovery and do a /data wipe and and a /Cache Wipe Then Flash the ROM via Recovery After the process is over Phone Should Reboot takes 10~15min And you will on JB 4.1.1 Change Log: Zipalinged Deodexed Rooted BusyBoxed Supercharged OOM Priority Grouping for better Memory Management Added New Gallery app from Note Improved Battery Improved Stability All Bloat Removed Re-based Jkay alpha one to LI8 frameworkQuote: + Fixed JB lockscreen so it shows pin/pattern when activating camera or Google (bug in JB) + Fixed home button when it is not used for launching S-Voice when double pressed (bug in JB) + Fixed volume down so you get Silent mode too! (bug in JB) + Status bar background changed from dark gray to black + Added lock screen rotation (works on both Samsung and JB lock screen)* + Enabled volume keys on lock screen* + Added 'Fast unlock' for pin/password lock screen (OK button has been removed as it is not needed to unlock)* + Original Jelly Bean GlowPad lock screen (hack: enable it by checking 'Help text' Samsung Circle lock screen options)* + Replaced background_holo_dark png with the hi-res version. + Removed AccuWeather logo from Circle lock screen + Moved the clock a bit on the PIN/Password lock screen + Added AM/PM to the clock on the JB lock screen Added SiyahKernel 1.6Beta12Quote: + charge boost (for AC: up to 1200mA, for USB: up to 900mA) + Auto NTFS mounting to /mnt/ntfs after attaching an NTFS formatted USB stick + Audio enhancements, call it scoobydoo sound, eargasm or whatever (fully functional in v1.6b3) + Overclocking (changes 1400 step to 1500 or 1600, available in v1.6a5) + Some tiny script based tweaks… + Undervolting support, but works with nstools only. Used Ezekeel’s customvoltage interface. it is very similar to netarchy’s UV_mV_table and you can use your existing scripts with some little modification. I have also added vdd_levels (don’t know who implemented this) and AndreiLux’s UV_uV_table interfaces but they are in /sys/class/misc/customvoltage. Lowest voltage level is 850mV until the sources are released. (available in v1.6a6) + Disabled some logs + added lulzactiveq (not tweaked for s3 yet) and hotplug governors (v1.6a7) + removed the settings which are not available yet from STweaks (1.6a8) + mdnie sharpness tweaks from hardcore (1.6a9) + added kernel version to version string to let you see which SiyahKernel version you have (v1.6beta10) based on LI8 stock kernel (v1.6beta10) + 4-step gpu clock settings (clock and thresholds), with 533MHz option and with some limitations because of the lack of voltage settings (v1.6beta10) + mDNIe sharpness tweaks made optional, in STweaks/Screen tab (v1.6beta11) + SIO and V/R I/O Schedulers (v1.6beta12) + CIFS and NFS modules (v1.6beta12) + GPU undervolting (lower limit:850mV, upper limit: 1075mV until the kernel is compiled from the sources) (v1.6beta12) + support for setcpu, voltagecontrol and similar apps which are using universal UV interfaces (v1.6beta13) added 1.6GHz and 1.5GHz CPU freq steps. no longer modified 1.4step for overclocking. (v1.6beta13) Credits: Leomar75 Gadgetcheck Wanam - Great Support and Help fixing things on ICS Gokhanmoral - He is the kernel king, and patient listener _Jkay_ - on gem of a person Original Thread @ checkrom.com Original Thread @ XDA Lien vers le commentaire Partager sur d’autres sites More sharing options...
Samoht59 Posté(e) 21 septembre 2012 Auteur Share Posté(e) 21 septembre 2012 elle vous inteéresse pas cette rom? ou c'est parce que c'est moiqui l'ai posteé? Lien vers le commentaire Partager sur d’autres sites More sharing options...
sebennett Posté(e) 21 septembre 2012 Share Posté(e) 21 septembre 2012 Très bonne ROM mais des bases samsung LI8 y en à pas mal.... :) Rassure toi tu es le bienvenu même venant d'HTC :P La kitchen est mis à jour pour JB ? Lien vers le commentaire Partager sur d’autres sites More sharing options...
foxraph Posté(e) 21 septembre 2012 Share Posté(e) 21 septembre 2012 Hello, elle apporte quoi cette ROM??? Lien vers le commentaire Partager sur d’autres sites More sharing options...
Samoht59 Posté(e) 21 septembre 2012 Auteur Share Posté(e) 21 septembre 2012 En gros, j'ai mal choisit :P Lien vers le commentaire Partager sur d’autres sites More sharing options...
crocodyle Posté(e) 21 septembre 2012 Share Posté(e) 21 septembre 2012 salut j'etais sous checkrom sous mon magnifique sgs2 puis une fois passé sur le s3 je trouvais la checkrom trop vide cette version est elle stable ? je vois qu'elle possède jkay un outil que j'adore que propose t il sur sgs3 ? merci d'avance Lien vers le commentaire Partager sur d’autres sites More sharing options...
spritiman Posté(e) 23 septembre 2012 Share Posté(e) 23 septembre 2012 Bonjour, moi je l'ai télécharger mais pas eu ( pris) le temps de la tester. J'adore la checkrom depuis mon gs2 aussi. En plus avec jkay c'est tous ce que je cherchais. Envoyé depuis mon Transformer Prime TF201 avec Tapatalk Lien vers le commentaire Partager sur d’autres sites More sharing options...
