StreamingMT Posté(e) 6 octobre 2012 Share Posté(e) 6 octobre 2012 (modifié) Omega v3.0 Based on firmwareXXALJ1 Android 4.1.1 (Date: 02/10/2012) Screenshots: More Screenshots here Inside Omega v3.0: Based on firmware XXALJ1 Android 4.1.1 (Date: 02/10/2012) Kernel Stock XXALJ1 Modem XXALIH CSC: XXALJ1 set to EUR Aroma installer - Installation is fully customizable by user and there is options to install everything and remove Bloatware - Read here for more info. With custom Installation you take control of what is installed in your device. init.d support without the need of a kernel that supports init.d Wipe cache partition automatic before roms installation Wipe Dalvik Cache automatic during installation Wipe preload partition automatic before roms installation Added: Busybox SuperSU OmegaDroid wallpaper Omegas JB Bootanimation by anbech GenieWidget Live Wallpapers Flashplayer support Updated (to latest version): Gmail Google Maps Play Store Google Search Mods: Disable Scrolling Cache TouchWiz with wallpaper scrolling Battery % mod Disabled advertisements Faster GPS lock Enable custom bootanimations Enable init.d scripts Contacts with Greek index Shutter Sound menu Enabled to stock camera Tweaks: build.prop tweaks Stock Theme Changes: Dithered Holo Background added by Zabalba Blue % battery icons Blue Toggle Buttons Omegas addon applications: Es File Explorer (with great Root Explorer) Hide It Pro Theme: Black Status bar Removed: Boot sound Charger Connection Sound Shutdown Animation Removed Bloatware: Learning hub Reading hub ChocoEUKor.apk DeepSea.apk Lcdtest.apk SelfTestMode.apk Stock Theme Changes: Dithered Holo Background added by Zabalba Rom is Deodexed + Rooted + Zipaligned Modifié 6 octobre 2012 par StreamingMT Lien vers le commentaire Partager sur d’autres sites More sharing options...
dago Posté(e) 28 octobre 2012 Share Posté(e) 28 octobre 2012 On continue par ici: https://forum.frandroid.com/topic/124177-romzsalj727oct-omega-v50-%E2%97%8F%E2%96%BAcustom-installation%E2%97%84%E2%97%8Fomega-files%E2%97%84%E2%97%8F%E2%96%BA8-themes%E2%97%84%E2%97%8F%E2%96%BA/ Lien vers le commentaire Partager sur d’autres sites More sharing options...
