haven Posté(e) 1 novembre 2012 Share Posté(e) 1 novembre 2012 (modifié) Bonsoir à tous, je ne vois aucun topic sur cette rom je me permets d'en faire un alors :) La team AOKP est un bon dérivé à Cyanogen, je trouve leur rom performant et ultra-fluide, je viens d'un Nexus S ou la rom était tout simplement génial alors sur un S notes ça doit être trop bien :D Voici un bref résumé : *****ICS***** Lien pour la rom : http://goo.im/devs/aokp/n7000/aokp_n7000_milestone-6.zip Lien des Gapps: http://goo.im/gapps Android 4.0.4-- XXLA2 Support for many devices (e.g Galaxy Nexus (maguro/toro), Galaxy S (GT-I9000), HP Touchpad (tenderloin, etc) Unsecure boot.img (stock AOSP kernel) Superuser & Busybox preinstalled Deodexed 180 Degree rotation Built in performance/init.d configuration (Thanks Kejar & company) Custom Power Menu Brightness slider in navigation bar. Custom color for anything in RC Custom Clock Color/Location: Right, Center, Disable Battery Icon/ Color Picker: CircleMod, Bar, Text Only, Icon Only, Icon+Text or None Battery Bar in Status Bar or Nav Bar, Bar Thickness, Charging animation Nav Bar Transparency Nav Bar Button Reorder: Back-Home-Search-Menu Nav Bar Color Picker Nav Bar Button Glow Duration: Off, Fast, Slow Nav Bar: Long press to Search button Nav Bar Hide on Lockscreen Toggles in Pull Down Menu: Auto rotate, Bluetooth, GPS, Wi-Fi, Aiplane mode, Vibrate, Silent, Sync, Data, 4G, Tethering, Torch, Brightness 'Traditional' toggle layout (where the toggle are on the very top) -- find in RC > Statusbar General > Layout LCD Density (Careful with this) Menu Button location: Right, Left, both, Remove Menu Button Visability: Always show, Always show Invisible Icons Lockscreen Style: Stock, Quad, Octo, ol' gingerbread Lockscreen Wallpaper Lockscreen color changer Lockscreen calendar Lockscreen SMS customizable shortcut (with icons) Lockscreen Horizontal Option Performance Menu: (Use With Caution) Max/ Min CPU, Scaling Governor Unlock Sceen with Legacy Menu Icon Volume Key to Wake Screen Volume Key to Skip Tracks Long-press back button to kill process Disable CRT off animation LED pulse settings (time on/off) ICS ringtones/notification sounds Customize carrier text to whatever. Power Menu options: Boot to recovery/ Boot loader, Reboot, Screenshot Facebook contact sync integration (must wipe to get this) Disable Boot animation Keyboard: Volume keys act as a cursor while typing -- disable in keyboard options Long press home for recent apps (thanks brucekey) Quick torch (enable in ROMControl, long press power when phone turned off. See the magic.) Fast charge toggle for maguro/toro for kernels that support it Weatherpanel in notification drawer Weather on lockscreen INSTALLATION : Avant tout faire un nandroid backup (recovery > backup & restore > backup) au cas ou ;) 1- entrez en RECOVERY 2- WIPE DATA/CACHE 3- WIPE CACHE 4- ADVANCE --> WIPE DALVIK/CACHE 5- INSTALL ZIP FROM SD 6- CHOOSE ZIP FROM SD 7- choisissez le zip de la ROM --> YES INSTALL 8- installez les GAPPS (même principe que la ROM) 9- REBOOT PHONE Vous trouverez toute les infos par ici : http://rootzwiki.com/forum/424-aokp/ *****JB*****: Dernière rom en date, MILESTONE1 : http://aokp.co/index.php/releases/_/jb-milestone-1-r34 Gapps: http://goo.im/gapps Infos: http://rootzwiki.com/forum/424-aokp/ Cette rom marche sur un système de Build qui paraisse plus ou moins régulièrement et qui sont plus ou moins stable, ensuite la team sort la Milestone qui est une version stable. Je vous conseils fortement cette rom :) Modifié 2 novembre 2012 par haven Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
gaja Posté(e) 1 novembre 2012 Share Posté(e) 1 novembre 2012 Hello ! Des screens peut-être ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
haven Posté(e) 2 novembre 2012 Auteur Share Posté(e) 2 novembre 2012 Ah oui, je l'ai pas encore installé, dès qu'elle est sur mon note je mets des screens ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
patriarch Posté(e) 2 novembre 2012 Share Posté(e) 2 novembre 2012 il y a quoi comme différence entre elle et cyanogen ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
