Nanis Posté(e) 26 mai 2010 Share Posté(e) 26 mai 2010 Bonjour, j'ai un soucis lorsque j'essai de lire un flux JSON. Le flux est très long (environ 80000 lignes), est cela provoque un OutOfMemory Cela arrive lorsque je converti la réponse du serveur en String à la ligne : sb.append(line+NL); public static String responseReader(InputStream is) { String result; BufferedReader br = null; try { br = new BufferedReader(new InputStreamReader(is)); StringBuilder sb = new StringBuilder(); String line = ""; String NL = System.getProperty("line.separator"); while ((line = br.readLine()) != null) { sb.append(line+NL); } br.close(); result = sb.toString(); } catch (IllegalStateException e) { Log.e("DEBUGTAG", "Error occured", e); return e.toString(); } catch (Exception e) { Log.e("DEBUGTAG", "Error occured", e); return e.toString(); } finally { if (br != null) { try { br.close(); } catch (IOException e) { return e.toString(); } } } return result; } le message d'erreur : 05-26 07:33:28.826: ERROR/AndroidRuntime(288): Uncaught handler: thread main exiting due to uncaught exception 05-26 07:33:28.877: ERROR/AndroidRuntime(288): java.lang.OutOfMemoryError 05-26 07:33:28.877: ERROR/AndroidRuntime(288): at java.lang.AbstractStringBuilder.enlargeBuffer(AbstractStringBuilder.java:97) 05-26 07:33:28.877: ERROR/AndroidRuntime(288): at java.lang.AbstractStringBuilder.append0(AbstractStringBuilder.java:155) 05-26 07:33:28.877: ERROR/AndroidRuntime(288): at java.lang.StringBuilder.append(StringBuilder.java:216) 05-26 07:33:28.877: ERROR/AndroidRuntime(288): at com.android.booztermobile.utils.ServletUtils.responseReader(ServletUtils.java:93) 05-26 07:33:28.877: ERROR/AndroidRuntime(288): at com.android.booztermobile.servletcall.BlockLoaderCall.BlockLoader(BlockLoaderCall.java:75) 05-26 07:33:28.877: ERROR/AndroidRuntime(288): at com.android.booztermobile.activity.ExplorerActivity.generateList(ExplorerActivity.java:530) 05-26 07:33:28.877: ERROR/AndroidRuntime(288): at com.android.booztermobile.activity.ExplorerActivity.onClick(ExplorerActivity.java:351) 05-26 07:33:28.877: ERROR/AndroidRuntime(288): at android.view.View.performClick(View.java:2364) 05-26 07:33:28.877: ERROR/AndroidRuntime(288): at android.view.View.onTouchEvent(View.java:4179) 05-26 07:33:28.877: ERROR/AndroidRuntime(288): at android.view.View.dispatchTouchEvent(View.java:3709) 05-26 07:33:28.877: ERROR/AndroidRuntime(288): at android.view.ViewGroup.dispatchTouchEvent(ViewGroup.java:852) 05-26 07:33:28.877: ERROR/AndroidRuntime(288): at android.view.ViewGroup.dispatchTouchEvent(ViewGroup.java:884) 05-26 07:33:28.877: ERROR/AndroidRuntime(288): at android.view.ViewGroup.dispatchTouchEvent(ViewGroup.java:884) 05-26 07:33:28.877: ERROR/AndroidRuntime(288): at android.view.ViewGroup.dispatchTouchEvent(ViewGroup.java:884) 05-26 07:33:28.877: ERROR/AndroidRuntime(288): at android.view.ViewGroup.dispatchTouchEvent(ViewGroup.java:884) 05-26 07:33:28.877: ERROR/AndroidRuntime(288): at android.view.ViewGroup.dispatchTouchEvent(ViewGroup.java:884) 05-26 07:33:28.877: ERROR/AndroidRuntime(288): at com.android.internal.policy.impl.PhoneWindow$DecorView.superDispatchTouchEvent(PhoneWindow.java:1659) 05-26 07:33:28.877: ERROR/AndroidRuntime(288): at com.android.internal.policy.impl.PhoneWindow.superDispatchTouchEvent(PhoneWindow.java:1107) 05-26 07:33:28.877: ERROR/AndroidRuntime(288): at android.app.Activity.dispatchTouchEvent(Activity.java:2061) 05-26 07:33:28.877: ERROR/AndroidRuntime(288): at com.android.internal.policy.impl.PhoneWindow$DecorView.dispatchTouchEvent(PhoneWindow.java:1643) 05-26 07:33:28.877: ERROR/AndroidRuntime(288): at android.view.ViewRoot.handleMessage(ViewRoot.java:1691) 05-26 07:33:28.877: ERROR/AndroidRuntime(288): at android.os.Handler.dispatchMessage(Handler.java:99) 05-26 07:33:28.877: ERROR/AndroidRuntime(288): at android.os.Looper.loop(Looper.java:123) 05-26 07:33:28.877: ERROR/AndroidRuntime(288): at android.app.ActivityThread.main(ActivityThread.java:4363) 05-26 07:33:28.877: ERROR/AndroidRuntime(288): at java.lang.reflect.Method.invokeNative(Native Method) 05-26 07:33:28.877: ERROR/AndroidRuntime(288): at java.lang.reflect.Method.invoke(Method.java:521) 05-26 07:33:28.877: ERROR/AndroidRuntime(288): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:860) 05-26 07:33:28.877: ERROR/AndroidRuntime(288): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:618) 05-26 07:33:28.877: ERROR/AndroidRuntime(288): at dalvik.system.NativeStart.main(Native Method) J'ai essayé plusieurs façon de faire mais je me retrouve toujours avec ce message... Lien vers le commentaire Partager sur d’autres sites More sharing options...
Pierre87 Posté(e) 4 juin 2010 Share Posté(e) 4 juin 2010 t'es sur un téléphone ... c'est pas fait pour parser un JSON de 80000 lignes il n'y a pas assez de mémoire plusieurs solutions selon moi : - tu fais en sorte que le serveur envoie un json plus petit (ne me dit pas que ce n'est pas possible : C'EST POSSIBLE !) - tu enregistres le json reçu dans un fichier sur la carte sd, et tu le parse "à la main" GL & HF Lien vers le commentaire Partager sur d’autres sites More sharing options...
