micky51100 Posté(e) 9 novembre 2012 Share Posté(e) 9 novembre 2012 (modifié) Welcome to ICE DS v. 8.0 FINAL BEST HTC SENSE 3.6 EXPERIENCE on HTC Desire S ICS 4.0.4 Sense 3.6 Stock Based in official RUU_SAGA_ICS_35_S_HTC_WWE_14.01.401.2 This is ROM made with dsixda and his kitchen and based on the latest official from HTC This ROM is pre-rooted, with busybox, bash and has been the /system/apps and /system/framework files have been deodexed. Features: Quote: - Based official 14.01.401.2 release-keys HTC Desire S - Tweaked kernel v Xl+ - amidabudha - Bravia Engine Service - HTC IME without arrows (optional) - HTC Notes - Very fast, clean & stable! - Full HTC Sense 3.6 Interface - Multi-language (WWE) - ROOT SuperSu or SuperUser Permissions (optional) - JB animations - Super Full Beats Audio - RAM optimizations - Sense 4 Lockscreen - BlissMod (optional) - init.d scripts (BusyBox run-parts) support - Excellent battery life! - Improved EXT4 performance - Bug&Lag FREE - more... How to install: Quote: 1.Download Full_wipe_DS.zip 2.Install Full_wip_DS.zip 3.Wipe Cash + Dalvik cash 4.Install zip , let the rom install complete 5.Reboot 6.Enjoy Quote: If you install a rom using a different base from your current rom then a full wipe is recommended, but if it is listed as optional then it's your choice! However if a full wipe is not mandatory, you are still going to want to reboot into recovery and clean cache and clear dalvik cache before installing the new rom build. In addition if a full wipe is recommended and you did not do one and you are experiencing problems that other users are not reporting then please do a full wipe before reporting any problems in the thread. Quote: Formatting your SD card is always a must, to do so a nice tool is available permitting to optimize them. Using generic formatting utilities may result in less than optimal performance for your memory cards. Quote: This is a good time to back up your new rom as all apps have been installed and your accounts setup. Restore your data/settings using EXT4 with restore Data from previous nandroid. But be aware that you need to go to Settings > Security > tick Unknown sources before restoring any data. Please be advised that you should never restore data from a different base ROM as this is likely to cause problems and lead to instability. Recommended radio: 20.72.30.0833U_3831.17.00.310 Download: v 8.0 Final https://sourceforge....al.zip/download NEED FULL WIPE! FULL WIPE DS OLD ROMs: v 6.5 http://d-h.st/53m v 6.0 http://d-h.st/Gan v 5.3 http://d-h.st/zk4 v 5.2: http://d-h.st/yOq v 5.1: https://hotfile.com/....v_5.1.zip.html v 5.0: http://hotfile.com/d....S_v_5.zip.html Je l'est légèrement modifié car quelques petites bourde avais été faite et donc j'ai recorrigé la Rom. Kernel conseillé Patchad 3.0.57 ( Experimental pour évité le drain battery wifi ) => Download: 3057.zip md5sum: 7ab8567b554fbc1b31693249c460e830 Citation Change log: version 8.0 légèrement corrigé par moi même : - re-based to official base 14.01.401.2 CL434411 release-keys - no visual chenges - fixed sense reboot issue - sense 4 lockscreen (now optional) - Added Tweaks for better Performance / Battery / Graphics / RAM utilization / Scrolling & Straming - Something More That I Can't Remembered Modifié 24 janvier 2013 par micky51100 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Finiarel01 Posté(e) 9 novembre 2012 Share Posté(e) 9 novembre 2012 Celle ci est top, bien mieux que la 5.1 que j'avais avant, mais j'ai eu des soucis avec google navigation, l'image se figeait sur un point de la carte avant chaque changement de direction, voire plus... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
micky51100 Posté(e) 9 novembre 2012 Auteur Share Posté(e) 9 novembre 2012 Moi aussi je suis du même avis que toi ! Et n'est constaté aucun problème de mon coté mais depuis peut je test " Blackout ICS Incredible v3.1.1 Good Enuff Ed " et je dois dire que je suis surpris du travail accomplis sur se portage ! La Rom est plus fluide et réactive que ICEDS 6 et aucun problème constaté à part le fais d'être obligé de reflashé le noyau après la rom car, le Dev à oublié quelque fichiers pour le wifi ! Mais je pense que se problème sera vite réglé ! Donc conclusion je préfère Blackout pour le moment pour sa fluidité et réactivité ! Aucun lag, aucun FC, tout de fonctionnelle. Un vrais plaisir à utilisé. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
micky51100 Posté(e) 30 novembre 2012 Auteur Share Posté(e) 30 novembre 2012 Post 1 à jour ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Grosb46 Posté(e) 28 décembre 2012 Share Posté(e) 28 décembre 2012 (modifié) Bonjour juste en complément, la Version 7 est disponible : http://forum.xda-dev...d.php?t=1567715 Stable et rapide, s'appuyant sur la même radio.... Modifié 28 décembre 2012 par Grosb46 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
micky51100 Posté(e) 29 décembre 2012 Auteur Share Posté(e) 29 décembre 2012 Je n'est pas mis le sujet à jour car la v7 est lagy et à un énorme drain de batterie ! V7 => 1.5 jours d'autonomie V6.5 => 3 à 4 jours avec mes modif perso J'ai d'ailleur posté sur XDA un correctif pour ses type de problème ici => http://forum.xda-developers.com/showpost.php?p=35856108&postcount=1428 Le Super charger peut être grandement en cause de tout les soucis rencontré sur la V7 principalement le drain et divers changement qui n'optimise absolument pas dans le Build ! Je suis le sujet sur XDA 5 fois par jours et je lit tout les posts ! La v7 trop de personne sans plaigne pour mettre le post à jour ici. Je préfère attendre que Ronk règle le problème avant toute chose ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
sebowling Posté(e) 19 janvier 2013 Share Posté(e) 19 janvier 2013 Salut à tous! J'aimerais Rooter mon HTC Desire S... Je m'intéresse à ce root-ci, mais je ne comprend vraiment pas comment m'y prendre, les explications sont vraiment peu détaillées pour moi... J'ai fouillé google pendant 1h (sûrement mal) et tous les autres topics ne correspondent vraiment pas à cette manière-ci... Ce serait extrêmement sympa de votre part de m'éclairer, je suis complètement perdu! Merci d'avance!! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
micky51100 Posté(e) 19 janvier 2013 Auteur Share Posté(e) 19 janvier 2013 Root Desire S ici => http://forum.xda-developers.com/showthread.php?t=1525100 Je peut pas faire mieux suis passé par se post qui est parfais à mes yeux !!! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
sebowling Posté(e) 19 janvier 2013 Share Posté(e) 19 janvier 2013 (modifié) Un tout grand merci, je vais essayer de me dépotter avec tout ça, j'y comprend pas grand chose! Par contre, comment as tu fais pour le "Unlocking Bootloader", le Desire S n'y est pas! Y'a bien le Dsire et le Desire Z pourtant Modifié 19 janvier 2013 par Seb. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
_bobichon Posté(e) 19 janvier 2013 Share Posté(e) 19 janvier 2013 Il faut choisir all other supported models pour débloquer le bootloader. Tapatalké depuis mon Desire S 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
brol Posté(e) 24 janvier 2013 Share Posté(e) 24 janvier 2013 Bonjour, La version 8 est sortie. Est-elle fonctionnelle à 100% ? Notamment la battery et le wifi ? Mon anglais est laborieux... Sinon, je ne pige pas un truc. Si je comprends bien il faut télécharger une appli (Full_wipe_DS.zip) qui va formater la mémoire interne du téléphone. 1/ Est-ce que ça va toucher à la sdcard ? 2/ Ce formatage est en ext4, c'est ça ? Si la ROM ou l'installation de cette foire, je fais comment pour retourner sur ma ROM actuelle ? 3/ Sinon, j'ai déjà 4ext recovery, est-ce que Full_wipe_DS.zip ne va pas faire double emploi ? 4/ Pas de contre indication avec mon HBOOT-6.98.1002 ? Je sais, beaucoup de questions... Merci. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Finiarel01 Posté(e) 24 janvier 2013 Share Posté(e) 24 janvier 2013 Pas de réponse pour la v8, il faut que je la flashe. pour le reste : 1/Non 2/Pour retourner sur ta ROM actuelle, via 4ext, tu fais un backup de ta rom, c'est une sauvegarde à un instant T, si tu la restaure tu retrouve ton tèl comme à cet instant. C'est utile pour tester une ROM et revenir rapidement à ton système. Par contre, si y'a une m**** dans un flashage, fais les wipe habituels avant de restaurer. 3/Si, l'interet de ce zip est de ne pas faire les wipe via ton recovery. Passer par l'un ou par l'autre revient au même, mais si tu débutes, le zip est plus simple. 4/je ne suis absolument pas un spécialiste du hboot, je laisse à plus connaisseur cette question Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
micky51100 Posté(e) 24 janvier 2013 Auteur Share Posté(e) 24 janvier 2013 (modifié) La v8 il y à quelques petites choses à corrigé que je fais actuellement et je vous la post elle sera parfaite et final ! La ronk à fais quelques petites bêtises et oublie dans le build, j'ai posté sur xda la correction tout à l'heure ! Donc sois vous modifié vous même ou attendez pour ceux qui ne veulent pas faire de bêtises ! Sinon pour ceux qui ont l'habitude passé par RootExplorer. lien => http://forum.xda-dev...&postcount=1526 Citation 1/ Est-ce que ça va toucher à la sdcard ?2/ Ce formatage est en ext4, c'est ça ? Si la ROM ou l'installation de cette foire, je fais comment pour retourner sur ma ROM actuelle ? 3/ Sinon, j'ai déjà 4ext recovery, est-ce que Full_wipe_DS.zip ne va pas faire double emploi ? 4/ Pas de contre indication avec mon HBOOT-6.98.1002 ? 1) Non sa netouche pas à la SD 2) Pour évité tout désagrément fais un backup via Recovery 3) Pas besoin de Full_wipe_DS.zip ( je ne l'est jamais utilisé ) 4) Par contre là sa coince je crois qu'il faut le H-boot 2.00.0002 regarde ici pour le changé => http://forum.xda-dev...d.php?t=1525100 Modifié 24 janvier 2013 par micky51100 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
_bobichon Posté(e) 25 janvier 2013 Share Posté(e) 25 janvier 2013 Le 24/01/2013 à 16:59, micky51100 a dit : 4) Par contre là sa coince je crois qu'il faut le H-boot 2.00.0002 regarde ici pour le changé => http://forum.xda-dev...d.php?t=1525100 Ou ici. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Stilflip Posté(e) 26 janvier 2013 Share Posté(e) 26 janvier 2013 Bonjour à vous, Il y a peu, j'ai installé la V7 et en effet, elle lag énormément, à chaque fois que je quitte une application, j'ai l'écran HTC qui s'affiche et ensuite le rechargement du "bureau" (si je peux appeler ça comme ^^), et il y a bien un problème de batterie, la mienne ne tient pas une journée ! (j'arrive à perdre 6% en mode avion, pour une nuit de 7h !). Je crois avoir lu ici que la V8 réglait ces problèmes ? Si je fais une sauvegarde avec Titanium de mes données et applications personnelles, il ne va pas avoir un problème de compatibilité ? Sinon dernière question, full wipe, et installation de la V8, et cette manip suffit ? Un grand merci ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
micky51100 Posté(e) 26 janvier 2013 Auteur Share Posté(e) 26 janvier 2013 Si tu prend la V8 du post 1 ici oui, c'est la version que j'ai corrigé et est beaucoup mieux ! Je te conseille le kernel patched 3.0.57 experimental avec. Sinon oui sauvegarde avec titanium et restore après ! Full wipe obligatoire car la v8 repart sur un RUU de Desire S alors que depuis un moment la v6, v7, etc tournais sur un RUU de Incredible ! La base est corect et ma version tourne très correctement niveaux batterie j'attend les retours de ma version ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Stilflip Posté(e) 26 janvier 2013 Share Posté(e) 26 janvier 2013 (modifié) "Je te conseille le kernel patched 3.0.57 experimental avec." Qu'est ce que tu veux dire par cette phrase, c'est à dire, c'est quoi un Kernel ? ^^ EDIT : Ha, j'ai compris en cherchant un peu sur le net, donc ce noyau augmente les performances de la batterie ? Et comment l'installer ? Modifié 26 janvier 2013 par Stilflip Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
micky51100 Posté(e) 26 janvier 2013 Auteur Share Posté(e) 26 janvier 2013 Simplement le flashé via le recovery après la rom le lien ici => Download: 3057.zip md5sum: 7ab8567b554fbc1b31693249c460e830 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Stilflip Posté(e) 26 janvier 2013 Share Posté(e) 26 janvier 2013 (modifié) Si je veux revenir à une RUU officiel, elle reviendra au Kernel d'origine durant l'installation de cette RUU ? Et je dois flasher le Kernel avant d'installer la ROM ou l'inverse ? Modifié 26 janvier 2013 par Stilflip Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
micky51100 Posté(e) 26 janvier 2013 Auteur Share Posté(e) 26 janvier 2013 L'inverse tu flash le kernel après la Rom Et sinon oui un RUU remet le kernel d'origine stock 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Stilflip Posté(e) 26 janvier 2013 Share Posté(e) 26 janvier 2013 (modifié) Comment flasher le Kernel ? Car je met cette commande : fastboot flash 3057 3057.zip et j'ai ce message : EDIT : Haaa depuis le recovery... EDIT 2 : J'ai coché full wipe pendant l'installation de la ROM, ça a pas annulé la mise à jour du kernel que je venais d'opérer ? Modifié 26 janvier 2013 par Stilflip Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ppahv Posté(e) 20 mai 2013 Share Posté(e) 20 mai 2013 (modifié) Bonjour, je suis tenté par cette ROM, je suis actuellement avec la rom d'origine orange s-on avec un h boot 2.13.733 Cette rom convient-elle et puis-je me lancer sans crainte sachant que je suis totalement néophyte dans ce genre de chose ? Je ne voudrais pas transformer mon desire s en presse-papier ^_^ Modifié 20 mai 2013 par ppahv Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Finiarel01 Posté(e) 20 mai 2013 Share Posté(e) 20 mai 2013 Pas de risque, mais suis les Tutos avant pour rooter ton tèl. Le mieux n'est pas très loin : https://forum.frandroid.com/topic/80379-guide-du-s-off-root-recovery-hboot-radio-et-rom/ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ppahv Posté(e) 22 mai 2013 Share Posté(e) 22 mai 2013 (modifié) Merci de vos conseils, j'ai trouvé beaucoup plus simple, je suis passé par cette mise à jour via ruu, je n'ai rien modifié ni sur le PC ni sur le téléphone et cela fonctionne du tonnerre :) http://forum.frandro...ur-ics-par-ruu/ Modifié 22 mai 2013 par ppahv Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
droidT2U Posté(e) 21 août 2013 Share Posté(e) 21 août 2013 Bonjour je suis intéressé mais même après avoir lu toute la description et les commentaires je n'arrive pas a savoir si tout fonctionne ou pas. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
