bigor44 Posté(e) 14 décembre 2012 Share Posté(e) 14 décembre 2012 Cette magnifique rom n'ayant toujours pas de post ici, je me permets de lui rendre honneur. Avant de commencer: Ni le Forums, Ni moi, Ne serions tenus responsables pour les cas de Brick [rimg] http://dl.dropbox.com/u/44387235/JellyBeer5_600px.png[/rimg] 1. Description de la ROM : Choix du DPI: Par défaut en 213 dpi Choix du DPI par app Softkeys (barre de navigation à la nexus) Choix entre mode tablet/Phablet et Phone Dual Panel Possibilité de désactiver les boutons sensitifs Launcher: Standard ou Trebuchet Features In ROM settings: Set custom DPI (213 as default) Navigation bar Change navigation bar height 3 different UI modes @ any DPI (phone, phablet and tablet) Dual panel Custom carrier name Disable bootanimation Disable physical buttons Center clock in status bar Week day in the clock Custom bootanimation Extra changes: Suport for /data/local.prop Removed CM wallpapers, LiveWallpaper and LiveWallpapersPicker Removed some ringtones Removed videos Removed ROMManager Added ZipInstaller (Multi zip installer!!!) GooManager support Battery save tweaks Tweaks ui/launcher/performance (compiled by jmico) Recovery: removed some confirmation "No" CM tablet options activated when in TabletUI Remove all recent apps button 2. Capture écran ou vidéos : 3. Changelog : 3.34: - Fixed NPE when navbar is not present 3.33: - Option to block statusbar if navigation buttons are disabled - Restored livewallpapers and tones - DPI groups work @ any dpi - Auto backup dpi groups - Visual improvements - Statusbar transparency fix 3.32: - NavBar rings - Some bug fixes 3.31: - Change app layout depending on its DPI - App killed when added or removed from a DPI group - Alternate default app selector - Show wifi name when connected - Notification wallpaper fixed (hopefuly) 3.3: - DPI app Groups (based on PA's per app dpi) - Some visual fixes 3.23: - AOKP toggles - Some more info on startup - PropModder: add option to save in data/local.prop - DPI saved as qemu prop in data/local.prop 3.22: - Status and navigation bar color - Day and month in date - Battery percentage (text) - PropModder (by JBirdVegas). Borrowed from PA, authored by Daniel MM 3.21: - Various bug fixes - Added expanded desktop to n7000 - Back to stock CM10 kernel/recovery (n7000) 3.2: - Repo sync 25-10-2012 16:00 - Started builds for grouper - Remove all recent apps button - New design - New bootanimation - JellyBeer Wallpapers app - ZipInstaller 2.4.1 - No more AROMA installer - No more OC'd kernel 3.1: - Repo sync 18-10-2012 19:30 - Aroma: updated GApps to 20121011 - Aroma: TaskManager to /system/app - Removed CMStats - ZipInstaller 2.3 - Added 3 UIMode options working @ any DPI (phone, phablet and tablet) - Removed force TabletUI mode - Disable some phoneui options if we’re on tabletui - Added show week day option - Updated all default wallpapers - Activate ALL CM tablet options if we’re on tabletui 3.0: - Repo sync 10-10-2012 16:00 - Aroma: fixed Apex version - Aroma: added inverted apps (Contacts, Calendar and Email) - Aroma: GApps not default checked when not full install - Option to force tablet ui at any dpi - Option to force dual panel for apps dependant on framework-res - Option to change navigation bar height - Option to set a wallpaper for notification window - Added ZipInstaller v2.2 - goo manager support - Removed videos - Settings reorganized (again) 2.1: - Repo sync: 03-10-2012 06:30 - Aroma: removed HydraCore until it works on latest CM10 - Aroma: removed project LARD due to improvements in CM10 that makes it obsolete - Aroma: some more fixes - Added ZipInstaller v2.1 (Multi zip installer!!!) - Removed CMUpdater - Removed CMStats (partially) 2.0: - Repo sync 30-09-2012 12:30 - Aroma: Added Themes to Aroma - Aroma: Added Themes to ROM - Aroma: Added apps (Titanium Backup, Memo, Handrite, Root Explorer, TaskManager, ApexLauncher, Aldiko Book Reader, Moon Reader) - Aroma: Fixed HydraCore Root - Aroma: Fixed Chrome installation - Removed TaskManager from ROM - Removed ApexLauncher from ROM - Removed support for OTAUpdateCenter - Added ZipInstaller 1.3 - Reorganized JellyBeer Settings - DPI Changer (Settings): added more DPIs - Alert to reboot if needed in Settings 1.0: - Repo sync 25-09-2012 16:00 - Added AROMA!! (great work jmico) - Removed GApps from ROM (now in AROMA) - Removed ApexLauncher (now in AROMA) - Removed Project LARD (now in AROMA) - The system properties in /data/local.prop are loaded (disabled by default in JellyBean) - On-screen buttons property is saved in /data/local.prop (persists after a flash without wipe data) - In AROMA: 5 kernels, 6 DPIs, 3 launchers, GPS Locale, some apps, project LARD and more. 0.5: - Repo sync 20-09-2012 09:00 - Integrated Gapps - Added stock TaskManager - Added option: custom bootanimation 0.4: - Repo sync 17-09-2012 16:00 - Added Project LARD - Removed some tones 0.3: - Repo sync 13-09-2012 22:00 - Standard Kernel by default - Added support for OTAUpdater - Restored all languages - On-screen buttons disabled by default 0.2.1: - Fixed recovery bug 0.2: - Repo sync 05-09-2012 21:30 - Back to cyanogenmod repos - Added option: center clock in status bar - Removed some confirmation "No"s from recovery - Launcher/performance tweaks - Enable GPU Acceleration - Ui Tweaks 0.1.1: - Repo sync 02-09-2012 19:00 - Removed alert entering settings -> performance - UMS working (CM10) 0.1: - Initial release 4. Téléchargements : Lien vers le téléchargement: - Jelly Beer http://goo.im/devs/beerbong/n7000/JellyBeer - Gapps: http://goo.im/gapps/gapps-jb-20121011-signed.zip 5. Sources : Lien vers le post Xda: http://forum.xda-developers.com/showthread.php?t=1906396 6. Procédure d'installation : A n'installer que sur un kernel SAFE !!! Copier la ROM et les Gapps sur votre SD externe Wipe Data/Cache/Dalvik Format system Format preload (Si vous venez d'une rom basée sur un leak JB) Flasher la Rom puis les gapps Reboot system et c'est fini Envoyé depuis mon GT-N7000 avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
rsuinux Posté(e) 16 décembre 2012 Share Posté(e) 16 décembre 2012 Cette magnifique rom n'ayant toujours pas de post ici, je me permets de lui rendre honneur. .../... 6. Procédure d'installation : A n'installer que sur un kernel SAFE !!! Copier la ROM et les Gapps sur votre SD externe Wipe Data/Cache/Dalvik Format system Format preload (Si vous venez d'une rom basée sur un leak JB) Bonjour; Tu as essayé? Ily a un truc que je n'ai pas compris (je suis nouveau sous galaxy Note) Qu'entends tu par "kernel SAFE" ? Est-ce qu'il faut comprendre que la rom est une JB qui tournera pas avec un noyau plutôt récent? Désolé pour ces questions basic. Rémi. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Hypnoz Posté(e) 16 décembre 2012 Share Posté(e) 16 décembre 2012 Salut, regarde ici. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
bigor44 Posté(e) 18 décembre 2012 Auteur Share Posté(e) 18 décembre 2012 (modifié) Bonjour; Tu as essayé? Ily a un truc que je n'ai pas compris (je suis nouveau sous galaxy Note) Qu'entends tu par "kernel SAFE" ? Est-ce qu'il faut comprendre que la rom est une JB qui tournera pas avec un noyau plutôt récent? Désolé pour ces questions basic. Rémi. Si tu n'as pas compris, je te conseille d'éviter les roms custom Envoyé depuis mon GT-N7000 Modifié 18 décembre 2012 par bigor44 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
