[MOD] PHOTOS CONTACT PLEIN ECRAN
Voici le mod Full Screen Caller HD Photo
Description:
- Photos en plein écran
- Enregistrement des appels
- Disable increasing ringtone
- Removed delay after the call
- Removed debility translucent band
- Talk time shifted down
- Extras. volume is shifted down
- Fully transparent background
- HD-quality photos
- Removed the "My Profile" in contacts
- Vertical frame for cutting photos
- Normal vertical thumbnail lists
- Save the photo on the card in a higher resolution than 96 x 96 (not in HD)
P.S. photos to contacts will need to reassign
Rom:
- Check the rom deodex XXALJ7 4.1.1 and XXDLJ2 4.1.2, but may come up and for the next. If your rom is odex, you will need to delete the folder system/app SecPhone.odex, SecContacts.odex and SecContactsProvider.odex
Installation:
- Flash dans le recovery
TELECHARGEMENT:
Poppuri Mod Full Screen Caller HD Photo
Modifié par Alienex
