SUPERUSER NE FONCTIONNE PAS
manray16
Bonjour à tous
j'ai une C93 SU est installé mais est vierge quand je l'oeuvre et dès que je veux le mettre à jour il me dit "obtention des droits root : échec"...
que faire?
comment l'activer?
sachant que Hongkonggrrk m'a dit que de leur coté elle n'est pas rootée.
je n'y comprend plus rien
Yeah, Zenithink stock Jelly Bean ROMs aren't properly prerooted...
On SlateDroid, I showed people how to use a system.patch.zt280.tar.bz file I made to root with SuperSU (you need to use 7-zip and alter the stock Zenithink system.zt280.tar.bz file, open it with 7zip, do not untar the file, just delete the Superuser.apk from the /app folder and the su binary in the /bin folder, then save the system.zt280.tar.bz file before you close 7zip, and add the altered system file and the patch file I made to your zt-update folder, and reflash the tablet - http://www.mediafire...ch.zt280.tar.bz )....
But most people using Jelly Bean are using Christian Troy's ROMs which are properly prerooted....
