[Rom] UnOfficial SlimLP (5.1.1) Build 0.8 Beta (STABLE)
Oui, j'ai eu le même problème, ça vient des Slim Gapps, faut installer la version BETA : http://slimroms.net/index.php/downloads/dlsearch/viewcategory/1251-addons/downloads
Pour pas avoir à tout réinstaller, flash rom, flash gapps, wipe cache et dalvik et roule ;)
salut ,
mise a jour des gapps béta
2014-10-01 02:58 dankoman
* [r480] structure/system/lib/libAppDataSearch.so,
structure/system/lib/libWhisper.so,
structure/system/priv-app/PrebuiltGmsCore.apk: PrebuiltGmsCore:
update to MULTI-DPI version 6.1.11, update libs
2014-09-24 14:46 dankoman
* [r477] structure/system/priv-app/Phonesky.apk: Phonesky: fix
action bar layout on app details page, add missing resources for
higher API versions, some other miscellaneous fixes.
2014-09-24 11:50 dankoman
* [r475] structure/system/app/YouTube.apk: YouTube: update to TRDS
version 5.10.3.5
2014-09-24 11:48 dankoman
* [r474] structure/system/lib/libAppDataSearch.so,
update to MULTI-DPI version 6.1.09, update libs
2014-09-23 23:51 dankoman
* [r471] structure/system/priv-app/Phonesky.apk: Phonesky: update
to TRDS version 4.9.13 (YAY!)
2014-09-23 14:59 dankoman
* [r468] structure/data/app/Chrome-TRDS-signed.apk: Chrome: fix
text color in bookmark widget tabs for TRDS=on
2014-09-23 13:04 dankoman
* [r465] structure/system/lib/libAppDataSearch.so,
structure/system/lib/libconscrypt_gmscore_jni.so,
structure/system/lib/libgames_rtmp_jni.so,
update to MULTI-DPI version 6.1.08, update libs.
2014-09-23 12:54 dankoman
* [r463] structure/system/app/YouTube.apk,
structure/system/lib/libcronet.so,
structure/system/lib/libm2ts_player.so: YouTube: update to TRDS
version 5.10.3.4, update libs.
2014-09-19 15:46 dankoman
* [r460] structure/system/app/Hangouts.apk,
structure/system/lib/libvideochat_jni.so,
structure/system/priv-app/PrebuiltGmsCore.apk: Hangouts and
PrebuiltGmsCore: back to multi-dpi "hdpi" versions for
compatibility
2014-09-19 13:28 dankoman
* [r457] extras/full/updater-script, extras/mini/updater-script,
extras/normal/updater-script: updater-script (all packages):
remove any updates to hangouts and play services that may exist
in the data partition to force use of system version (this is to
prevent the need, if dirty flashing, to uninstall updates before
flashing gapps)
2014-09-19 13:14 dankoman
* [r455] structure/system/app/Hangouts.apk: Hangouts: use xxhdpi
sub-version of 2.3.75731955 (version code 22037769)
2014-09-18 19:04 dankoman
* [r453] structure/system/priv-app/PrebuiltGmsCore.apk:
PrebuiltGmsCore: change dummy dpi value to 480 (instead of 240)
2014-09-18 16:08 dankoman
* [r450] structure/system/priv-app/PrebuiltGmsCore.apk:
PrebuiltGmsCore: add it multi-dpi smali hack for GMS check-in
activity ONLY
2014-09-18 13:24 dankoman
* [r448] structure/system/lib/libAppDataSearch.so,
update to version 6.1.07. update libs
apps...
2014-09-18 12:51 dankoman
* [r446] structure/system/app/Hangouts.apk,
structure/system/lib/libvideochat_jni.so: Hangouts: update to
TRDS version 2.3.75731955. update libs.
2014-09-18 03:45 dankoman
* [r444] structure/system/priv-app/talkback.apk: talkback: update
2014-09-17 16:13 dankoman
* [r441] extras/full/82-full_gapps.sh, extras/mini/80-gapps.sh,
extras/normal/81-normal_gapps.sh: Fix up backup scripts for added
files
2014-09-17 15:58 dankoman
* [r439] structure/system/app/HangoutsDialer.apk: HangoutsDialer:
add to all packages
2014-09-17 12:55 dankoman
* [r437] structure/system/app/Hangouts.apk,
TRDS version 2.3.75589790
2014-09-16 23:23 dankoman
* [r434] structure/system/lib/libAppDataSearch.so,
structure/system/lib/libgcastv2_base.so,
structure/system/lib/libgcastv2_support.so,
structure/system/lib/libgms-ocrclient.so,
structure/system/lib/libgmscore.so,
structure/system/lib/libjgcastservice.so,
try updating to multi-dpi-hacked version 6.1.05(1438406-038)
2014-09-16 13:49 dankoman
* [r431] structure/data/app/Chrome-TRDS-signed.apk: Chrome: fix
linear gradient in URL bar
2014-09-16 02:29 dankoman
* [r428] structure/data/app/Chrome-TRDS-signed.apk: Chrome: fix
suggestion view dropdown box
2014-09-13 19:56 dankoman
* [r425] build.xml, extras/full/82-full_gapps.sh,
extras/full/updater-script, structure/system/app/PlusOne.apk,
structure/system/lib/libmoviemaker-jni.so,
structure/system/lib/libphotoeditor_native.so: PlusOne: remove
from all packages (same reason as Maps)
2014-09-13 19:05 dankoman
* [r423] extras/full/updater-script: full updater script: delete
maps from system partition
2014-09-13 18:25 dankoman
not mean to update plus
2014-09-13 18:19 dankoman
* [r419] build.properties, structure/system/app/PlusOne.apk:
build.properties: bump build to 8.x
2014-09-13 16:54 dankoman
* [r416] structure/system/app/Hangouts.apk: Hangouts: moar bugfixes
(think i'm done now...)
2014-09-13 12:47 dankoman
* [r414] structure/system/app/Hangouts.apk: Hangouts: more fixes
(bottom half of slide-out menu is white for TRDS=on for now, so
it wasn't transparent for TRDS=off... looking for a way to fix
this)
2014-09-12 21:29 dankoman
* [r412] structure/system/app/Hangouts.apk: Hangouts: more tweaks
and fixes
2014-09-12 18:49 dankoman
* [r409] structure/system/app/Hangouts.apk,
structure/system/lib/libcrashreporter.so,
TRDS version 2.3.75067996 (YAY!!!) and update libs
Nouveau google app stable (282 au lieu de 265 de mémoire).
EDIT: hum je ne sais pas si c'est la 8.2 ou les gapp 282 mais impossible de me connecter au store de google et tout merdoie... J'ai l'impression qu'il y a un soucis avec ce dernier ensemble...
EDIT: je viens de lire vos messages, faut les gapp beta ok...
Modifié par Burn2
mise a jour des gapps béta  http://slimroms.net/index.php/downloads/dlsearch/viewcategory/1251-addons/downloads/dlsearch
changelog :
2014-10-07 15:10 dankoman
    * [r486] structure/system/priv-app/GoogleSearch.apk: GoogleSearch:
     TRDS version 3.6.14.1337016
Slim-mako-4.4.4.build.8.4-WEEKLY-7352 du 10/07/2014 dispo
changelog :
2014-10-05 | rhine: Remove unnecessary hwcomposer flags [Ethan Chen]
2014-10-05 | rhine: Enable audio offload [Ethan Chen]
2014-10-05 | rhine: Add TCP delayed ACK settings [Giulio Cervera]
2014-10-05 | rhine: add MDP idle notifier permissions [Giulio Cervera]
2014-10-05 | remove duplicate blob [Giulio Cervera]
2014-10-05 | qcom-common: updqate qcom perf lib location [Giulio Cervera]
2014-10-05 | qcom-common: update adreno blob list (from 17.1.2.A.0.314) [Giulio Cervera]
2014-10-05 | JB-Update3: staging: logger: hold mutex while removing reader [Rabin Vincent]
2014-10-04 | video: sii9234: dynamically register and unregister input device [Ketut Putu Kumajaya]
2014-10-04 | usb: gadget: mass_storage: added sysfs entry for cdrom to LUNs [FrozenCow]
2014-10-04 | USB: f_mass_storage: 2048 block size for cdrom devices [FrozenCow]
2014-10-04 | Some formatting [andi34]
2014-10-04 | Revert "ASoC: wm8994: Ensure there are enough BCLKs for four channels" [Ketut P. Kumajaya]
2014-10-04 | Revert "ARM: OMAP2+: OPP: Fix to ensure check of right oppdef after bad one" [andi34]
2014-10-04 | Revert "ARM: 7559/1: smp: switch away from the idmap before updating init_mm.mm_count" [andi34]
2014-10-04 | Remove leftover from Samsungs exFAT implementation [andi34]
2014-10-04 | futex-prevent-requeue-pi-on-same-futex.patch futex: Forbid uaddr == uaddr2 in futex_requeue(..., requeue_pi=1) [Thomas Gleixner]
2014-10-04 | Fix compileing [andi34]2014-09-30 | driver: kgsl: fix merge (HEAD, m/kk4.4, github/kk4.4) [Giulio Cervera]
2014-10-04 | espresso10: remove hardcoded toolchain from Makefile [andi34]
2014-10-04 | cpufreq: Bring smdk4x12's pegasusq governor to espresso10 [Ketut Putu Kumajaya]
2014-10-04 | configs: Enable pegasusq CPU governor [andi34]
2014-10-04 | config: enable RWSEM_XCHGADD_ALGORITHM [andi34]
2014-10-04 | Boeffla Sound: FM radio not available with LTE models [yank555-lu]
2014-10-04 | Boeffla-Sound: Engine 1.6.6 [andip71]
2014-10-04 | Boeffla-Sound: Engine 1.6.5 [andip71]
2014-10-04 | Boeffla-Sound: Engine 1.6.4 [andip71]
2014-10-04 | Boeffla-Sound: Engine 1.6.3 [andip71]
2014-10-04 | Boeffla-Sound: Engine 1.6.0 [andip71]
2014-10-04 | Add SlimRoms defconfig [andi34]
2014-10-04 | Added optimized ARM RWSEM algorithm. [Ezekeel]
2014-10-03 | qcom-common: use qcom powerhal [Giulio Cervera]
2014-10-02 | spn: add override for Korea [arter97]
2014-10-02 | Revert Localized Carrier SPN Changes. [Andrew Jiang]
2014-10-02 | Integrate duplicated NTT DOCOMO carrier labels [black]
2014-10-02 | i9500: remove useless sip voip permission [Alberto96]2014-09-30 | Add audio.r_submix.default for casting (HEAD, m/kk4.4, github/kk4.4) [ben Edmunds]2014-09-30 | sony-common: use fixed sort (HEAD, m/kk4.4, github/kk4.4) [Giulio Cervera]2014-10-05 | camera: add a workaround for slow camera startup [Androguide]
2014-10-02 | i9500: Remove duplicate permissions [NBruderman]
2014-10-02 | i9500: consumerir: Increase Buffer size (HEAD, m/kk4.4, github/kk4.4) [slayher]
2014-10-02 | i9500: consumerir: Convert transmit input from ms to pulses [Christopher R. Palmer]
2014-10-02 | i9500: Alphabetize permissions [Ethan Chen]
2014-10-02 | Don't show NTT docomo carrier label while roaming [black]
2014-10-02 | corrected Vodafone DE & Vodafone PT APNs [Merudo]
2014-10-02 | corrected Smarts RU APNs [Merudo]
2014-10-02 | added 13 Lycamobile APNs, combined TMI APN, added 48months APN [Merudo]
2014-10-01 | CameraWrapper: increase size of scene-mode buffer [Chirayu Desai]2014-10-05 | rhine: Use Sony camera workaround hack (HEAD, m/kk4.4, github/kk4.4) [Chirayu Desai]
Modifié par Orion7
mise a jour des gapps beta http://slimroms.net/index.php/downloads/dlsearch/viewcategory/1251-addons/downloads/dlsearch
changelog :
2014-10-09 02:40 dankoman
* [r492] structure/data/app/Chrome-TRDS-signed.apk: Chrome: fix
settings screen for TRDS=on
2014-10-09 00:35 dankoman
* [r488] structure/data/app/Chrome-TRDS-signed.apk: Chrome: update
to TRDS version 38.0.2125.102
2014-10-02 01:03 dankoman
* [r483] structure/system/app/YouTube.apk,
structure/system/lib/libcronet.so: YouTube: update to TRDS
version 5.11.4, update lib
mise a jour gapps béta http://slimroms.net/index.php/downloads/dlsearch/viewcategory/1251-addons/downloads/dlsearch
changelog :
2014-10-11 02:09 dankoman
    * [r497] structure/system/lib/libAppDataSearch.so,
     update to MULTI-DPI version 6.1.71
edit :
petit hs : SuperSU v2.13 ---> http://forum.xda-developers.com/showpost.php?s=90b5c52c87e8a9a720dd9b920de7fe8c&p=23427715&postcount=1
Modifié par Orion7
Mise à jour de ma Slimkat : https://s.basketbuild.com/filedl/devs?dev=Minux&dl=Minux/mako/Slimkat/Slim-mako-4.4.4.build.8.6-MinuxBuild-20141014-1348.zip
Comme d'hab, juste synchro avec les sources officielles en plus de mes modifs ;)
  • Like 2
Compil en cours ;)
Edit : Compil terminée : https://s.basketbuild.com/filedl/devs?dev=Minux&dl=Minux/mako/Slimkat/Slim-mako-4.4.4.build.8.6.1-MinuxBuild-20141015-0907.zip
Modifié par Minux
  • Like 3
