Makime Posté(e) 17 juin 2010 Share Posté(e) 17 juin 2010 (modifié) I - Le petit mot : Je regarde un peu le Forum FrAndroid mais beaucoup moins que avant . Et pour cause aucune infos n'aient relayer concernant le coté bidouille du Nexus One ( à part un sujet qui traite de la Rom Cyanogen, qui a toujours le nom de CM5.0.4 -_- ) brefs, je trouve ça dommage donc je fais un bref rappel de ce qui ce fait seulement ce que j'ai testé les sources sont du Forum XDA comme à chaque fois ^^ II - La ROM * stock froyo - android 2.2 * stock kernel 2.6.32.9 - froyo is already sOOO fast! (40+ Mflops) * rooted (su from Cyanogen + Superuser.apk from ChainDD) * busybox (from Cyanogen) * app2sd (from Google) * massive /system/etc/hosts (no more ads - from ?) * massive apn list (from Cyanogen) * adw launcher (from AndersWeb) * flash player 10.1 beta 2 (from Adobe) * removed com.amazon.mp3 * moved facebook and twitter apps so they are removable * updated lib/hw/lights.mahimahi.so for better trackball colors support (from chaindd) * tweaked internal auto-killer (thx to androcheck) - better battery life * unified font pack (from djmcnz) * modded SpareParts: -- App2sd -- UI sounds -- Fix permissions -- Remount /system -- Reboot/recovery -- Install keyboards (latest HTC_IME, latest Swype, Full Keyboard) -- Change bootanimation -- Enable stock headset volume control -- Switch to White-on-Black/Black-on-White notification bar -- Install myLock (TrackballWake replacement) -- Basic SpareParts in submenu * nano (from paulobrien) * zipaligned * custom bootanimation (bios-like, adapted from frysee's work) * controllable volume with stock headset (from t0ol) * deodex'ed /system (from JF & Jr33) * replaced stock calculator with handyCalc * TrackBall Alert FULL, NATIVE support! * HQ Video 800x480 (from Rodrigezstyle) * no usb problem! * no wifi problem! System Apps: - adw launcher 0.8.2 - handyCalc 0.43 Removable Apps: - modded spare parts v3 - stock Facebook - stock Twitter - battery notify 1.0 - colored - xda-developers 1.0.0 (from Tapaltak) - flash payer 10.1.72.4 BETA (from Adobe) - file explorer 1.2.0 - backup for root users 4.1.4 - barcode scanner 3.31 - fonts pack (from djmcnz) - tesla flashlight 1.7 - number saver 1.5.1 - trackball alert 1.0.5 updated! - terminal emulator 1.0.4 - stock apps updated Audio: - added Teleport.mp3 from old CyanogenMod 5.0.3-N1 Extra-binaries: - rwsystem, rosystem, nouisound, recovery, app2d, nano and others ramdisk: - custom init.rc to support clean shutdown and reboot Themes: - browser: chrome icon - talk: colorfull icon from esocid - camera: NexTHEME icon - adw launcher: re-themed NexusX from chronzz - camera: black background instead of that ugly gray... You can now apply you own theme cause LeoFroYo is deodex'ed since v0.3.0 ! **ScreenShot** III - Téléchargement/Installation : La Radio : http://www.myhangoutonline.com/jsmallfib_top/leonnib4/Radio_32.26.00.24U_4.04.00.03_2_PASSION.img pour l'installer : copier le fichier *.img dans le répertoire "Tools" de votre SDK démarré en mode FastBoot puis $ fastboot flash radio Radio_32.26.00.24U_4.04.00.03_2_PASSION.img La ROM : http://www.myhangoutonline.com/jsmallfib_top/leonnib4/LeoFroYo-0.4.0-noradio-signed.zip Pour l'installer : Perso je flash le recovery de Amon_Ra version 1.7.0.1 ( téléchargeable ici : http://files.androidspin.com/downloads.php?dir=amon_ra/RECOVERY/&file=recovery-RA-nexus-v1.7.0.1.img ) $ fastboot flash recovery recovery-RA-nexus-v1.7.0.1.img Puis faire un wipe de tout ! C'est mieux et flasher la ROM qu'il faut mettre a la racine de la carte SD Sources : Leo FroYo : http://forum.xda-developers.com/showthread.php?t=693595 recovery Amon_Ra : http://forum.xda-developers.com/showthread.php?t=611829 EDIT : Version finale 1.0.0 sortie!Quelques minimes bigs, corriges dans la journee. - mon app2sd perso (reecri) comme sous les Cyanogen - dalvik-cache sur la sdcard - auto zipalign au boot etc. tout cela reste bien sur optionnel. http://forum.xda-developers.com/showthread.php?t=693595 J'i aussi ouvert un petit site pour LeoFroYo: http://leofroyo.shk-desktop.com Je n'ai pas le temps de venir sur XDA, ici et d'autres forums, donc je tente de centraliser le tout (englais et francais). ++ PS: Pour les sceptiques, oui c'est bien moi (regardez le commentaire): http://leofroyo.shk-desktop.com/about-2 Modifié 29 juin 2010 par Makime Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Ganryu Posté(e) 17 juin 2010 Share Posté(e) 17 juin 2010 Merci ca a l'air bien sympa. Bonne idée de présenter ici cette rom. Pour ma part j'attends un peu le stock froyo et je basculerai sans doute sur un mod une fois que celui ci sera sorti Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Makime Posté(e) 17 juin 2010 Auteur Share Posté(e) 17 juin 2010 (modifié) c'est vrai que le coté "béta" de ces version a base de froYo FRF50 sont déjà au TOP ! mais rien que le fais qu'il y est un carré blanc sur notre fiche dans les SMS, moi ça me ga_ve mais bon je fais avec en attendant :) Sinon pour avoir testé LéoFroYo je la trouve moins active que Kang O Rama mais sa se tien quand même :) Modifié 17 juin 2010 par Makime Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
leonnib4 Posté(e) 28 juin 2010 Share Posté(e) 28 juin 2010 Version finale 1.0.0 sortie! Quelques minimes bigs, corriges dans la journee. - mon app2sd perso (reecri) comme sous les Cyanogen - dalvik-cache sur la sdcard - auto zipalign au boot etc. tout cela reste bien sur optionnel. http://forum.xda-developers.com/showthread.php?t=693595 J'i aussi ouvert un petit site pour LeoFroYo: http://leofroyo.shk-desktop.com Je n'ai pas le temps de venir sur XDA, ici et d'autres forums, donc je tente de centraliser le tout (englais et francais). ++ PS: Pour les sceptiques, oui c'est bien moi (regardez le commentaire): http://leofroyo.shk-desktop.com/about-2 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
deephallow Posté(e) 29 juin 2010 Share Posté(e) 29 juin 2010 Salut Je l'ai installé hier soir et je l'a trouve vraiment superbe Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
funkyfr Posté(e) 30 juin 2010 Share Posté(e) 30 juin 2010 Merci Leo :) C'est sympa de voir un français aussi actif sur xda ^^ Je suis tres satisfait de ta rom. Juste, quand je sors du mode veille l'ecran n'est pas reactif tout de suite mais je pinaille :) j'attend avec impatience ta version basée sur la frf85 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
kartouche Posté(e) 30 juin 2010 Share Posté(e) 30 juin 2010 Pareil j'adore ta rom, cependant comme je l'ai spécifié sur XDA, j'ai perdu toute connexion DATA en 1.0.3 sous SFR malgé reboot, mode avion, APN, jeté un oeil a l'autorisation des connexions data dans les options. Un repassage en 1.0.2 par flash n'a rien arrangé, j'ai récupéré a coup de nand backup en 1.0.2. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
fildentaire Posté(e) 18 août 2010 Share Posté(e) 18 août 2010 Je viens d'installer la LeoFroyo 2.0.0 sur mon N1 SFR. C'est ma premiere ROM custom et je suis super content du résultat! Elle comble les lacunes de la 2.2 d'origine notamment avec le trackball wake. Par contre, j'ai quelques remarques: - au boot : j'ai en permanence les lignes de commandes comme si c'etait le premiere démarrage. est ce normal? - facebook : je ne peux pas ajouter mon compte pour la synchronisation des contacts voila, je test un peu et je refais un retour rapidement. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
kartouche Posté(e) 18 août 2010 Share Posté(e) 18 août 2010 pour le boot c'est normal :lol: C'est le bootimage qui a été changé Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
fildentaire Posté(e) 18 août 2010 Share Posté(e) 18 août 2010 Effectivement, pour le boot, j'ai changé l'animation et je n'obtient plus les premieres pages de lignes de commandes. Pour facebook, j'ai fais la MàJ en 1.3.2 proposé par le market. Je pense que le bug doit venir de cela. Ma grande question, cela va être sur l'autonomie du N1 avec LeoFroyo... Une question annexe, comment faire pour supprimer la ROM alternative et repasser en une version "sortie d'usine" officielle (FRF91 de SFR)? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
3rr0r404 Posté(e) 18 août 2010 Share Posté(e) 18 août 2010 Il te suffit de reflasher avec une ROM stock Froyo il me semble ... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
fildentaire Posté(e) 18 août 2010 Share Posté(e) 18 août 2010 (modifié) Je suis d'accord mais je n'ai pas trouvé la ROM stock Froyo version SFR (pas disponible?). Ce que j'aimerais c'est une procédure qui te remet ton N1 comme à la sortie de la boite depuis n'importe quelle version en étant sûr que tout est propre (wipe, recovery, kernel,...). Modifié 18 août 2010 par fildentaire Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
