Makime Posté(e) 17 juin 2010 Share Posté(e) 17 juin 2010 I - Le petit mot : Je regarde un peu le Forum FrAndroid mais beaucoup moins que avant . Et pour cause aucune infos n'aient relayer concernant le coté bidouille du Nexus One ( à part un sujet qui traite de la Rom Cyanogen, qui a toujours le nom de CM5.0.4 -_- ) brefs, je trouve ça dommage donc je fais un bref rappel de ce qui ce fait seulement ce que j'ai testé les sources sont du Forum XDA comme à chaque fois ^^ II - La ROM [***MAJ***] Froyo Android 2.2 (FRF72) QuickDesk - This is as awesome as HelixLauncher was when it first arrived on the scene! Pershoot's 2.6.34 XTRA Overclocking Kernel (20100616) Newest version of ADW.Launcher (v0.8.6) // customised for Kang-o-rama Updated Trackball Alert (v1.0.5) from lilHermit // with pre-patched framework Update Adobe Flash Player beta // should also now upgrade from the market Added Fancy Widget // because I'm sure it will be removed from the Market soon enough Reverted hosts file changes // 'hosts.huge' blocks lots of sites, 'hosts' is empty, rename them as you see fit Added transparent Power Control and News & Weather widgets from Kang-o-rama-0.8 Preview // if you don't like these, save a copy of /system/app/GenieWidget.apk and Settings.apk and push them back. Busybox from Cyanogen - now root access for all apps SpareParts - designed especially for Froyo by leonnib4 who's allowed us to use it, thank you. Froyo apps2sd - now in Spare Parts The Droid Collection Icon Pack Droidz Extended Icon Pack iQ Icons Icon Pack Unified Font Pack Extra Wallpapers // Embedded in ADW.Launcher Apps Organizer // Set custom application folders with your own icons MoreLocale // Use any language/location combination Quick Boot // Fast access to all reboot modes, including home screen shortcuts ShootMe // Shake or scream to capture screen shots Enabled 800x480 video recording ERE27 build fingerprint added to display all market apps Superuser permission from ChainsDD And most of your favourite Kang-o-rama apps, fonts, icon packs and wallpapers. **ScreenShot** III - Téléchargement/Installation : La Radio : http://www.myhangoutonline.com/jsmallfib_top/leonnib4/Radio_32.26.00.24U_4.04.00.03_2_PASSION.img pour l'installer : copier le fichier *.img dans le répertoire "Tools" de votre SDK démarré en mode FastBoot puis $ fastboot flash radio Radio_32.26.00.24U_4.04.00.03_2_PASSION.img La ROM : http://djmcnz.batteryboss.org/Kang-o-rama/0.9/Pre-Release/Kang-o-rama-0.9-b2.zip Pour l'installer : Perso je flash le recovery de Amon_Ra version 1.7.0.1 ( téléchargeable ici : http://files.androidspin.com/downloads.php?dir=amon_ra/RECOVERY/&file=recovery-RA-nexus-v1.7.0.1.img ) $ fastboot flash recovery recovery-RA-nexus-v1.7.0.1.img Puis faire un wipe de tout ! C'est mieux et flasher la ROM qu'il faut mettre a la racine de la carte SD Sources : Kang-O-Rama : http://forum.xda-developers.com/showpost.php?p=6781913&postcount=954 recovery Amon_Ra : http://forum.xda-developers.com/showthread.php?t=611829 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Mik51 Posté(e) 17 juin 2010 Share Posté(e) 17 juin 2010 Cette rom est excellente je suis dessus actuellement après avoir tester un bon nom de rom... Je la conseil fortement :) Edit pour la radio j'suis pas d'accord il faut mettre la radio froyo 12.7 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Makime Posté(e) 17 juin 2010 Auteur Share Posté(e) 17 juin 2010 Là je suis dessus je trouve que c'est la plus abouti sous FroYo :) Lien vers le commentaire Partager sur d’autres sites More sharing options...
Gils Posté(e) 17 juin 2010 Share Posté(e) 17 juin 2010 Si froyo l'officiel tarde... je me lance ;) Merci /Dérision On (aucune mention de la société dans laquelle je travail dans ce message) /Dérision Off Lien vers le commentaire Partager sur d’autres sites More sharing options...
Makime Posté(e) 17 juin 2010 Auteur Share Posté(e) 17 juin 2010 ça fais polémique sa ^^ il en faut pas beaucoup au gens pour crier ^^ ont ils des solutions ? non ^^ Lien vers le commentaire Partager sur d’autres sites More sharing options...
Gils Posté(e) 17 juin 2010 Share Posté(e) 17 juin 2010 d'après ce que je vois le kernel permet D'oc le processeur et uv c'est bien undervolt ? donc tu gagne en puissance et en autonomie ? ça se gère comment ? d'origine c'est activé ? Moi j'utilise setCPU pour mettre a 250 en veille mon CPU... c'est compatible ? Et la video c'est pas le mode 720p la ? Lien vers le commentaire Partager sur d’autres sites More sharing options...
Mik51 Posté(e) 18 juin 2010 Share Posté(e) 18 juin 2010 La 720p n'est pas encore dispo pour froyo. Update SP3 dispo : http://djmcnz.batteryboss.org/Kang-o-rama/alpha/Kang-o-rama-0.9a0-SP3.zip Lien vers le commentaire Partager sur d’autres sites More sharing options...
Makime Posté(e) 22 juin 2010 Auteur Share Posté(e) 22 juin 2010 Je viens de mettre à jour avec la nouvelle version, la BETA2 qui tourne sous la build FRF72 de FroYo. Lien vers le commentaire Partager sur d’autres sites More sharing options...
mephissto Posté(e) 25 juin 2010 Share Posté(e) 25 juin 2010 Hello, Tout d'abord merci pour le post, je ne connaissais pas du tout cette ROM. Du coups je l'ai installé à la place de Cyanogen 5.0.8, je dois dire que je la trouve vraiment bien. Le changement de font est déroutant au début et puis au fur et à mesure on s'habitue et elle devient sympa. Mais j'ai au moins un bug, du au changement de font dans l'appli Robo Defense Free. J'ai envoyé un mail au dev du jeu pour espérer qu'il puisse faire qq chose. Sinon je pense que je repasserai sur Cyanogen 6 à voir si Kang-o-rama est réactif sur le dev parce que je dois avouer que j'aime vraiment la bare de notification HTC Sense. Lien vers le commentaire Partager sur d’autres sites More sharing options...
funkyfr Posté(e) 26 juin 2010 Share Posté(e) 26 juin 2010 Assez content de cette rom aussi. Une nouvelle version basée sur la frf83 est deja dispo et pas besoin de wipe quand on vient de frf83 d origine :) Sinon savez vous comment remettre le font de base ? Je trouve que celle d origine est biien plus lisible Lien vers le commentaire Partager sur d’autres sites More sharing options...
