Posté(e) 21 mars 201313 a Jsevi83 propose une méthode très facile et efficace pour passer de Gingerbread (baseband 109808) à ICS (baseband 2030), ou l'inverse avec un simple fichier a flasher par le cwm recovery. Installer le zip par le cwm recovery puis flasher juste derrière la ROM désirée I made two zips which you can install in recovery, one to downgrade to GB and another to upgrade to ICS. This way you don't need to install UPDATE.APP or do imei hack. Just install the zip in recovery and then install any custom rom following its instructions (wipes, etc). DOWNGRADE TO GB: http://www.solidfile...m/d/e208f49ff9/ This will install GB baseband (B895), GB bootloader and CWM5 recovery. It doesn't include a rom. UPGRADE TO ICS: http://www.solidfile...m/d/7d1f753ecb/ This will install ICS baseband (B952), ICS "unlocked" bootloader and CWM5 recovery. It doesn't include a rom. Le lien du thread: http://www.modaco.co...-from-recovery/ Modifié 21 mars 201313 a par kuan
