kevin8622 Posté(e) 7 mai 2013 Share Posté(e) 7 mai 2013 Bonjour, En cherchant la cause des ralentissements sous JB je suis tombé sur ce log : W/System.err( 431): java.io.FileNotFoundException: /proc/driver/mtk_io_osd_config: open failed: ENOENT (No such file or directory)W/System.err( 431): at libcore.io.IoBridge.open(IoBridge.java:451) W/System.err( 431): at java.io.FileInputStream.<init>(FileInputStream.java:78) W/System.err( 431): at java.io.FileInputStream.<init>(FileInputStream.java:105) W/System.err( 431): at java.io.FileReader.<init>(FileReader.java:66) W/System.err( 431): at com.android.systemui.LoadAverageService$LoadView.getStorageIndicatorModeAndDelay(LoadAverageService.java:427) W/System.err( 431): at com.android.systemui.LoadAverageService$LoadView.updateThermalInfo(LoadAverageService.java:380) W/System.err( 431): at com.android.systemui.LoadAverageService$LoadView$1.handleMessage(LoadAverageService.java:75) W/System.err( 431): at android.os.Handler.dispatchMessage(Handler.java:99) W/System.err( 431): at android.os.Looper.loop(Looper.java:153) W/System.err( 431): at android.app.ActivityThread.main(ActivityThread.java:5086) W/System.err( 431): at java.lang.reflect.Method.invokeNative(Native Method) W/System.err( 431): at java.lang.reflect.Method.invoke(Method.java:511) W/System.err( 431): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:821) W/System.err( 431): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:584) W/System.err( 431): at de.robv.android.xposed.XposedBridge.main(XposedBridge.java:106) W/System.err( 431): at dalvik.system.NativeStart.main(Native Method) W/System.err( 431): Caused by: libcore.io.ErrnoException: open failed: ENOENT (No such file or directory) W/System.err( 431): at libcore.io.Posix.open(Native Method) W/System.err( 431): at libcore.io.BlockGuardOs.open(BlockGuardOs.java:110) W/System.err( 431): at libcore.io.IoBridge.open(IoBridge.java:435) W/System.err( 431): ... 15 more Est-ce que quelqu'un sait ce que c'est ce /proc/driver/mtk_io_osd_config ? Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité Posté(e) 8 mai 2013 Share Posté(e) 8 mai 2013 MTK = mediatek IO = Input (entrée) Output (sortie) OSD = On Screen Display (affichage à l'écran) CONFIG = configuration Lien vers le commentaire Partager sur d’autres sites More sharing options...
kevin8622 Posté(e) 8 mai 2013 Auteur Share Posté(e) 8 mai 2013 Jusqu'ici je savais... merci, malheureusement je cherchais plus d'informations sur ce driver en lui même qui est absent et provoque pas mal d'erreur dans les logs. Peut-être que ce n'est rien d'important mais vu les termes IO & OSD, cela pourrait expliquer certains lags je pense. Lien vers le commentaire Partager sur d’autres sites More sharing options...
