[APP] Weather Station 1.3.1.5
Voici une application fort sympathique pour l'indication de la température, la pression atmosphérique ainsi que l'humidité :
Weather Station
v1.3.1.5:
-Fixed bug where Русский and Português translations were crashing on changing widget color
v1.3.1.4:
-Finished Русский translation
v1.3.1.3:
-Added partial Русский translation
-Other minor improvements
v1.3.1.2:
-Updated Português translation
v1.3.1.1:
-Added Português (Brasil) translation
-Screenshot sharing code improved and refactored
-Wake locks code refactored
-The default graph labels text size should finally be right (if you were changing the size in Preferences you may have to reset it)
v1.3.1:
-Updated AChartEngine to v1.1.0 to address crashes some people are getting when viewing graphs
-Added 24 Hour and 7 Day HI & LO markers on the graphs
v1.3.0.1:
-Fixed crash caused by Widgets Text Color Preference
v1.3.0 is a big update:
-24 Hour HI & LO values on main screen (and in Graph Details in addition to 7 Day HI & LO)
-Add widgets to lock screen (Android 4.2+)
-Calibrate raw sensor output
-Option to disable screen dimming and sleep while in the app
-Can change widget text color to anything your heart desires (those who inverted text color before will have to reset this)
v1.2.0.2 is another small update:
-Added option to change the graph labels size
-Fixed the numbering of the graphed readings and exported readings
-Other minor code improvements
v1.2.0.1 is a minor release:
-Fixed crash caused by Ringtone Preference
-Reversed order of readings in Graph Details
-Other optimizations
v1.2.0 is done and is a major release:
-Ability to issue notification alerts for temperature, pressure, rel. and abs. humidity, and dew point
-Share screenshots of main screen and graphs
-Fixed bug where graphing °C would show °F values
-Option to disable widget updates
-Option to decrease widget text size (previously you could only increase)
-Increased graph text sizes for device screens less than ~ 400 dpi
Weather Station.apk
Source : http://forum.xda-dev...d.php?t=2253884
