[ROM][JB 4.1.2][Sony Xperia S/SL] MIUI V5 [3.9.13] + pack multi-language
KERNEL NOVA POUR MIUI
Télécharger et de-zipper le NOVA KERNEL MIUI dans le dossier Fasboo
Redémarrer votre XS en mode Fastboot et flasher le kernel avec la commande
fastboot flash boot nova_kernel_miui.elf
Question, je me suis aperçu que je le mettais jamais lol   Javais pas fais gaffe à vrai dire x)
Une personne pourrais me donner la marche à suivre? Ou le tuto pour faire ce qui est dit dans la citation?  Merci :)
EDIT:     c'est bon :)
Modifié par Wʎp
CHANGELOG   3.8.9
[system]
  • Optimization - System update package is preferentially downloaded to external SD card
  • Optimization - In “Do not disturb” mode, global notification is muted
  • Fix - In “Do not disturb” mode, SMS delivery report still rings
[Contacts]
  • Optimization - Style adjustment of no search results found page
  • Optimization - As for favorite contacts, a star mark will be displayed on the contact photo in the list page
  • Optimization - Improved smart grouping loading speed
  • Fix - In some cases, the searched numbers and results are not highlighted
  • Fix - While adding SMS recipients, the contact list search box flashed
  • Fix - A new group can be created successfully without filling in the name
  • Fix - Importing contacts via Bluetooth may cause FC
  • Fix - Removed theme causes program to crash when setting contact ringtone
  • Fix - Contact interface display error
[Messaging]
  • Fix - The "recipient" and “text” input box might flicker
  • Fix - Private messages can be viewed by clicking the notification of "Message not sent"
  • Fix - When sending slides after editing, pictures cannot be added
  • Fix - After turning on “guard” mode, clicking text messages in search results might cause FC
  • Fix - Favorite MMS containing images or videos cannot be added into messages
  • Fix - If you press the Home key to return to the desktop when composing an MMS message, the MMS will be saved now
  • Deletion - A reminder will not pop up on the desktop for timing private messages which are not sent successfully
[Lock screen, status bar, notification bar]
  • New - Added WIFI hotspot switch
  • New - Added “Do not disturb” mode switch
  • Optimization - Improved visual style of pattern unlock
  • Optimization - After turning off “Setting - Lock USIM card”, "Change USIM card PIN" option is not selectable
  • Optimization- Improved the visual effects of pattern lock screen
  • Deletion - Deleted the requirement of inserting the original SIM card in account unlock screen
[Launcher]
  • Fix - Apps in the folder on the dock cannot be dragged onto the dock
  • Fix - Dragging the icon on the dock to the home screen might lead to FC
  • Fix - When there is only one app in the folder, the app might disappear after failing to be removed
[Music]
  • New - Added new music landscape mode
  • Optimization - Improved the display mechanism of music download tasks in the notification bar
  • Fix - The soft keyboard does not automatically recover after renaming a playlist
[settings]
  • Fix - In some cases, wifi sharing feature might cause FC
[Anti-spam]
  • New - Added "Show blocked notification" switch
[Video]
  • Optimization - Fixed some interface display errors
  • Fix - In some cases, video player FC
CHANGELOG 3.8.16
Recommended this week
  • New - Added new notification center
  • Fix- When connecting to wifi with login authentication, the verification web page will be directly opened
Update log system
  • Fix disturbance mode, other party hangs up the call will result in brighter screen problem
  • Fix some cases, the disturbance pattern with no interceptions notification sound problems
  • Repair manual brightness mode, open the screen becomes brighter fetion problems
Phone
  • Fix set internet call account, does not show the SIP problem
  • Fix T9 set to "phonetic" mode, if the contact name of the "alphabet" project contains special characters, the contact can not be found to the problem
  • Add new Notification Center
  • Optimized flashlight vibration effects
  • Optimization screenshot prompt notification of success and failure
Gallery
  • Optimization millet Mito graffiti pen width
  • Fix in the wallpaper settings and select a picture gallery effect when different problems
  • Fix - Some GIF images cannot be zoomed out
  • Fix - Super long pictures cannot be viewed
Settings
  • Add allows you to set a single / dual microphone noise reduction mode (System Settings - Sound and Vibration - Noise Reduction)
  • Some require optimized connection wifi authentication login page when the page directly open authentication
  • Fix - notification bar to open and set...
Changelog 3.8.23 en espérant une version nozomi.....
[system]
Optimisation - Improved the fluency of "toggles" functionality
Optimisation - No pop-up window for incoming messages when using “Do not disturb” mode
Optimisation - Adjusted the background color of prompt text
Fix - Cannot scroll to the bottom of Wi-Fi details page
Fix - Display error in some third-party applications using Android stock themes
Fix - "Facebook Live Chat' causes some apps to fail to load
Fix - In “Do not disturb” mode, physical Home button does not respond
[Contacts]
Optimisation - Text message prompt background adjustment
Fix - Occasional FC errors when viewing contact list
[Lock screen , status bar and notification bar]
New - Optimised notification bar hardware startup, smoother to pull down
Fix - In some cases, clicking the notification bar does not unfold the notification shade
Fix - “Wi-Fi only” was added in "Auto sync" toggle options
[Messaging]
Optimisation - Improved the settings page for timed messages
Optimisation - RTSP video can be played directly from a text message
Fix - Saved extension number cannot be added as a recipient
Fix - No prompt after successfully copying text messages
Fix - While replying to a message, deleting the MMS theme causes the cursor to disappear
Fix - If there is no SIM card in the phone, slideshow mode will appear when reading MMS
Fix - Deleting draft leads to failures in some cases
Fix - Message deleting operation on the phone does not sync to MiCloud
Fix - In some cases, saved contacts do not show the contact name
[Launcher]
Optimisation - Improved...
Enfin la version 3.8.30 dispo pour notre XS !!!!!!!!!
CHANGELOG 3.8.30
Update Highlights
  • 1. Added the option of “Limit mobile data usage” in Browser
  • 2. Added support for transfer of complete contact info (including contact photo) and notes (including images attached) in Transfer
[system]
  • Fix - In some cases, starting apps through the notification bar might lead to wrong page
[Contact]
  • Fix - Incoming call from contacts using deleted ringtones might be mute
  • Optimization - Wrong password input time will not be calculated in account unlock interface
  • Optimization - In some cases, lock screen wallpaper does not show
  • Fix - After restarting the phone, "Do not disturb" status bar icon disappears
[Launcher]
  • New - Updated facebook icon for 1080P devices
  • Optimization - Improved default desktop layout
  • Fix - Picture mix filter alpha error
  • Fix - Restoring wrong backup caused launcher start failure
[Music]
  • Fix - Back button in the upper left corner of online music disappears
  • Fix - After turning on / off "Display lyrics" setting, lyrics do not refresh
[settings]
  • Fix - FC caused OTA upgrade from some old MIUI versions to the latest version
[E-mail]
  • Fix - In "Notifications" settings, current ringtone name is shown
  • Fix - Setting notification ringtones does not...
D'après ce que j'ai lu sur XDA : Kernel 3.4 :)
MIUI ROM 3.9.6 Full Changelog
[system]
Optimization - After lighting up the screen, NFC can be used without unlocking
Optimization - Improved the vibration effect of long press on the screen buttons
Fix - In some third-party apps, long press on the input box causes restart
[Contact]
Optimization - Reduced memory occupied by loading large contact photo
Fix - After the designated contact ringtone file is deleted, the ringtone in the contact details interface is not updated
Fix - Batch deletion of contacts might cause the program to stop running
Fix - Contacts reserved on the phone while deleting Xiaomi account cannot be added to Favorites or set the ringtone
[Messaging]
Optimization - In private messaging, no failure notifications are sent for undownloaded MMS
Fix - When the slide is greater than 300KB, sending SMS might cause FC
Fix - No ringtones for "MMS undownloaded" notification in the notification shade
Fix - In some case, clicking the prompt of "Message undownloaded" might cause another dialogue page to appear
Fix - Clicking the prompt of "Message undownloaded" can go directly to the private messaging session
Fix - After adding SMS recipients, pressing the key physical desktop back to the desktop and starting Messaging app again, the program might FC
Fix - After selecting multiple recipients, adding more recipients might cause the already added recipients to disappear
Fix - When sending MMS, press the key physical Home button to back to the desktop, and start Messaging app again, Messaging app might FC
Fix - Quick click on message search or...
Je pense y revenir bientôt moi aussi.
Il faut arrêter avec le kernel Nova: ça fait 6 mois qu'il n'est plus soutenu par son développeur!!
Ah bah écoute... je prends ce qu'on me met dans le premier poste. Reflex logique non?
Sinon il y aurait un kernel qui améliorerai un peu l'autonomie de cette miuiV5 ? :)  Merci
Changelog 3.9.13
[Contacts]
Fix - Slow loading problem of call recordings from the contact details page
Optimization - 1080P status bar size
Optimization - Lock screen sliding efficiency to improve user experience
[Desktop]
Optimization - updates impression notes, Xiaomi Shop and the kitchen is the perfect icon
Optimization - Allow the operator to delete a shortcut
[Gallery]
Optimization - Traditional translation corrections
Optimization - Gallery user interface improvements
[Music]
Optimization - New playlist name cannot be named the same as a system playlist and cannot contain illegal characters
Optimization - Add existing music...
Modifié par phil34410
Franchement, au début j'aimais bien cette ROM, mais maintenant j'ai plus de GPS, j'ai reflashé sans wipe mais pareil, si je dois faire un wipe je pense que je vais retourner sur la rom de Rayman-FX.
Sauf si quelqu'un a déjà rencontrer ce probleme
Bonjour à toutes et à tous,
Cela fait deux jours que je suis sur miui v5, j'aime beaucoup la ROM, mais je constate un gros problème, et je ne sais pas si il est récurrent pour d'autres utilisateurs.
Mon problème vient de l'application SMS, je ne reçois pas mes messages, je suis obligé de redémarrer pour les recevoir d'un coup, puis FC de com.android.phone. Et je suis encore obligé de redémarrer le bouzin pour recevoir la suite.
Je peux émettre des SMS mais le bug vient de la réception.
J'ai installé la 3.9.13, et la version iHackers sur XDA, mais je constate toujours le problème, même après avoir désinstallé le pare-feu.
Quelqu'un aurait-il une solution à mon problème???
En vous remerciant d'avance.
Cordialement.
J'avais constaté ce problème également mais je n'ai pas trouvé de solution (j'ai changé de rom depuis).
Cela-dit, tu parles de la 3.9.13 alors que la version courante est la 3.9.27 (une nouvelle version tous les vendredi il me semble). Le problème a peut-être été corrigé dans cette version.
  • 4 weeks later...
Hello a tous,
Voila ça fait un petit moment que je suis sous miui, mais la ça devient plus possible. J'ai les même problème de réception de SMS, mon tel ne détecte plus la carte sim de temps à autre ...
Bref, je voudrais changer de rom, mais problème, mon recovery à changé par le TWRP (ça à changé apres la 1er install de la MIUI), et en plus il est tous en chinois oO !
Je voudrais remettre le  CWM mais je n'y arrive pas, j'ai essayé avec RecoverX, rien a y faire toujours le TWRP.
Avez vous une autre méthode pour en installer un autre? (je précise que j'ai essaye diverse méthode trouver ici, notamment un .bat à lancer)
Installe un kernel qui fournir com direct. Pour le twrp faut aller sur le site de twrp il y a une manip pour flasher twrp en anglais avec l'emulateur de terminal
Envoyé depuis mon LT26i avec Tapatalk
Qui fournit le cwm il fallait lire. Le kernel de doomlord par exemple. Ou en flashé une rom qui le kernel comme cm9/10 ou openSEMC.
