Arnova 10DG3 Apps vers SD vold.fstab
xxcourtry77xx
Bonjour, voilà je souhaite mettre mes applications sur la micro SD et on ma expliquer qu'il fallait changer un bout de texte par un autre mais malheureusement le texte que l'on me demande de changer n'est pas dans le fichier:
## Vold 2.0 Generic fstab
## - San Mehat (san@android.com)
## Regular device mount
## Format: dev_mount <label> <mount_point> <part> <sysfs_path1...>
## label - Label for the volume
## mount_point - Where the volume will be mounted
## part - Partition # (1 based), or 'auto' for first usable partition.
## <sysfs_path> - List of sysfs paths to source devices
#wmt sd
dev_mount sdcard /mnt/sdcard auto /devices/platform/sdmmc.0
#dev_mount sdcard /mnt/sdcard auto /devices/platform/sdmmc1.0
#dev_mount sdcard /mnt/sdcard auto /devices/platform/sdmmc2.0
#wmt usb
dev_mount udisk /mnt/udisk auto /devices/pci0000:00/0000:00
dev_mount udisk_boot_udisk /mnt/udisk auto /devices/pci0000:00/0000:00:04.0/usb1/1-1
dev_mount udisk_boot_udisk /mnt/udisk auto /devices/pci0000:00/0000:00:04.0/usb1/1-2
dev_mount udisk_boot_udisk /mnt/udisk auto /devices/pci0000:00/0000:00:04.0/usb1/1-3
#wmt localdisk
dev_mount localdisk /mnt/internal auto /devices/virtual/mtd/mtd13/mtdblock13
dev_mount udisk_boot_localdisk /mnt/local auto /devices/pci0000:00/0000:00:04.0/usb1/1-4
## Example of a standard sdcard mount for the emulator / Dream
# Mounts the first usable partition of the specified device
#dev_mount sdcard /mnt/sdcard auto /devices/platform/goldfish_mmc.0 /devices/platform/msm_sdcc.2/mmc_host/mmc1
## Example of a dual card setup
# dev_mount left_sdcard /sdcard1 auto /devices/platform/goldfish_mmc.0 /devices/platform/msm_sdcc.2/mmc_host/mmc1
# dev_mount right_sdcard /sdcard2 auto /devices/platform/goldfish_mmc.1 /devices/platform/msm_sdcc.3/mmc_host/mmc1
## Example of specifying a specific partition for mounts
# dev_mount sdcard /sdcard 2 /devices/platform/goldfish_mmc.0 /devices/platform/msm_sdcc.2/mmc_host/mmc1
S'avait ce que je doit changer et par quoi pour mettre mes applications dans la sd ?
Ce sujet ne concerne pas la personnalisation. Je vous invite donc à reposter votre question dans la section dédiée à votre appareil :
https://forum.frandroid.com/forum/4-androphones
https://forum.frandroid.com/forum/128-tablettes
https://forum.frandroid.com/forum/9-autres-terminaux-android
Merci.
Le topic est déplacé dans la corbeille.
