xxcourtry77xx Posted July 19, 2013 Share Posted July 19, 2013 Bonjour, voilà je souhaite mettre mes applications sur la micro SD et on ma expliquer qu'il fallait changer un bout de texte par un autre mais malheureusement le texte que l'on me demande de changer n'est pas dans le fichier:## Vold 2.0 Generic fstab## - San Mehat (san@android.com)## ######################### Regular device mount#### Format: dev_mount <label> <mount_point> <part> <sysfs_path1...> ## label - Label for the volume## mount_point - Where the volume will be mounted## part - Partition # (1 based), or 'auto' for first usable partition.## <sysfs_path> - List of sysfs paths to source devices#######################wmt sddev_mount sdcard /mnt/sdcard auto /devices/platform/sdmmc.0#dev_mount sdcard /mnt/sdcard auto /devices/platform/sdmmc1.0#dev_mount sdcard /mnt/sdcard auto /devices/platform/sdmmc2.0#wmt usbdev_mount udisk /mnt/udisk auto /devices/pci0000:00/0000:00dev_mount udisk_boot_udisk /mnt/udisk auto /devices/pci0000:00/0000:00:04.0/usb1/1-1dev_mount udisk_boot_udisk /mnt/udisk auto /devices/pci0000:00/0000:00:04.0/usb1/1-2dev_mount udisk_boot_udisk /mnt/udisk auto /devices/pci0000:00/0000:00:04.0/usb1/1-3#wmt localdiskdev_mount localdisk /mnt/internal auto /devices/virtual/mtd/mtd13/mtdblock13dev_mount udisk_boot_localdisk /mnt/local auto /devices/pci0000:00/0000:00:04.0/usb1/1-4## Example of a standard sdcard mount for the emulator / Dream# Mounts the first usable partition of the specified device#dev_mount sdcard /mnt/sdcard auto /devices/platform/goldfish_mmc.0 /devices/platform/msm_sdcc.2/mmc_host/mmc1## Example of a dual card setup# dev_mount left_sdcard /sdcard1 auto /devices/platform/goldfish_mmc.0 /devices/platform/msm_sdcc.2/mmc_host/mmc1# dev_mount right_sdcard /sdcard2 auto /devices/platform/goldfish_mmc.1 /devices/platform/msm_sdcc.3/mmc_host/mmc1## Example of specifying a specific partition for mounts# dev_mount sdcard /sdcard 2 /devices/platform/goldfish_mmc.0 /devices/platform/msm_sdcc.2/mmc_host/mmc1S'avait ce que je doit changer et par quoi pour mettre mes applications dans la sd ? Link to comment Share on other sites More sharing options...
Dragonn Posted July 21, 2013 Share Posted July 21, 2013 Bonjour, Ce sujet ne concerne pas la personnalisation. Je vous invite donc à reposter votre question dans la section dédiée à votre appareil : https://forum.frandroid.com/forum/4-androphones https://forum.frandroid.com/forum/128-tablettes https://forum.frandroid.com/forum/9-autres-terminaux-android Merci. Le topic est déplacé dans la corbeille. Link to comment Share on other sites More sharing options...
Archived
This topic is now archived and is closed to further replies.
