oeildefeu Posté(e) 8 juillet 2010 Share Posté(e) 8 juillet 2010 (modifié) Bon je ne suis pas l'auteur de la ROM mais on en parlait dans le sujet froyo + sense, je pense qu'un sujet dédié n'est pas inutile car je pense que dans quelques jours on verra apparaitre plein de rom froyo + sense! voici sa description http://forum.xda-developers.com/showthread.php?t=720294 ROM specs: * Android 2.2 Froyo (FRF-85B) * Kernel 2.6.32.15 * New Radio 32.41.00.32U_5.08.00.04 * New Base v2.04 * 720p Video recorder * Native APP2SD * App Sharing * Car Panel * Plurk * Torcia * Wi-Fi Hotspot * ..and much more! How to flash DJDroid v1.0-R1 BETA: The installation procedure of this Rom requires 2 steps: 1. Rom installation 2. Radio installation Prerequisites: * Rooted phone * Koush Fakeflash installed on SD (see http://android.modaco.com/content/htc-desire-desire-modaco-com/310794/fake-flash-by-koush-launching-recovery-on-your-device-without-a-pc/) Step 1 - Rom Installation * a. Enter recovery (press volume down then - keeping it pressed - press power button) and make all the WIPES available, with the procedure you like the most. * b. After WIPES have been done, use Fakeflash to install ROM file on your SD card. After installation procedure is over, reboot your phone (first reboot will take some time to complete, do nothing meanwhile). After first boot, complete first time phone configuration skipping all unnecessary steps (like network, accounts and the like - you will have time setup everything later on). * Shut down the phone. Step 2 - Radio Installation * Switch on the phone entering recovery (again, volume down + power) * Use fakeflash to make all wipes available, and when you are done, install file on sd card: RadioUpdate.zip. The install will be blazingly fast (less than 3 seconds). * Using back button, go to main menu and reboot your phone. At this point, slowly and gently lean your phone on a flat surface (an altar would be an excellent choice) and start praying (it always helps....), while imagining our grinning faces...... Your device will execute several operations, and reboot more than once. Do NEVER TOUCH it - NEVER. If you find yourself alone, riding in the green fields with the sun on your face, and you phone boots into Sense, do not be troubled. For you are in Elysium, and you're already done with the installation! On the other side, if you find yourself alone, and also twelve sexyually aroused virgins appear around you, do not be trubled. For you didn't follow the procedure and your phone is already dead.... At this point, you can follow the normal setup procedure as you wish. P.S.: A little gift: among the programs, you will find an app which can allow you to chose where to install your APKs!!! BIG thanks to JD82 for this APK! Know issue: * There are not wallpapers * Some times the geolocalization could not work well * It's possible that some times the device reboot for unknown reasons Liens: http://webftp.myppc.it/index.php?dir=Bravo/ROM/Custom/DJDroid/&file=DJDroid_v1r1.zip http://webftp.myppc.it/index.php?dir=Bravo/Radio/&file=32.41.00.32U_5.08.00.04.zip Donc avec ça vous aurez froyo + sense (COMPLET: radio FM, une app torche, des améliorations..) L'autonomie est rapportée comme étant très bonne par plusieurs testeurs/flasheurs de la première heure Le flash depuis un recovery custom est possible d'après pas mal de testeurs Recovery rom manager is okPut the 2 zips on the SD card. 2- Reboot into recovery. 3- Wipe. 4- Install the rom. After installing reboot, probably takes 3-5 minutes. 5- When the new rom loads, skip everything then when you see the wallpaper reboot again into recovery. 6- Wipe everything again. Install the radio then reboot and leave the phone for 5-8 minutes. Quelques zip d'update sur le sujet XDA amènent en plus pour cette base - le wifi n - l'icone HSPDA (le H je présume..) Corrections pour ces 2 soucis: http://dl.free.fr/hM82qmzTX (update par recovery sans wipe) - une meilleure qualité en 720p: http://dl.free.fr/uDXZB2bgi - passer en "recovery mode"- décompresser le fichier media_profiles.xml (depuis le zip) dans un répertoire (C:\Votre_rep) - faire les commandes suivantes : adb shell remount /system adb push c:\Votre_rem\media_profiles.xml /system/etc/ adb reboot Soucis connus en plus de ceux cités ci-dessus: - Pas d'export vers Picasa des photos - Photos verte lros de l'utilisation du flash => solution mettre la balance des blanc en manuel - la recherche vocale fonctionne po je crois - Un téléphone sous orange risque de se retrouver locké.. - Pour avoir l'enregistrement en 720p il faut absolument flasher la radio - le market n'est pas complet: solution manuelle http://forum.xda-developers.com/showpost.php?p=7106627&postcount=727 OU solution update depuis recovery http://forum.xda-developers.com/showpost.php?p=7106776&postcount=739 PS: j'ai pas encore installé cette rom.. j'attends qu'elle murisse :) PPS: merci Minux Modifié 9 juillet 2010 par oeildefeu 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité Stephane8413 Posté(e) 8 juillet 2010 Share Posté(e) 8 juillet 2010 Moi je l'ai installé cette nuit, pour le moment pas de beug majeur, en effet je n'ai pas l'icone HSPDA, et là je viens juste de me rendre compte que j'ai un "!" sur le logo de ma batterie.... étrange. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
gregounech Posté(e) 8 juillet 2010 Share Posté(e) 8 juillet 2010 Pour les gens ayant un téléphone Orange (simlocké), la Radio marche bien ou il faut le desimlocker ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité Stephane8413 Posté(e) 8 juillet 2010 Share Posté(e) 8 juillet 2010 (modifié) Je sais que dans les premieres minutes après la publication de cette ROM, tous les possesseurs de téléphone Orange ont eu un problème de lock du téléphone... Je te conseillerai de patienter un peu... Edit : J'ai compris => il faut absolument que le téléphone soit désimlocké Edit 2 : Je viens d'avoir un reboot sans touché le téléphone... (ca fait parti des problèmes connus). Modifié 8 juillet 2010 par Stephane8413 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
kiflim Posté(e) 8 juillet 2010 Share Posté(e) 8 juillet 2010 Merci mais je vais attendre un peu les retours des utilisateurs de cette ROM et la confirmation d'HTC pour la sortie officielle de Froyo, si c'est pour Noel, je passe sur cette ROM. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
istreen Posté(e) 8 juillet 2010 Share Posté(e) 8 juillet 2010 j'attends que ce soit une rom faite depuis le AOSP et non porté depuis le nexus one, j'attends aussi qu'il passe à la FR91 la dernière build de froyo. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
oeildefeu Posté(e) 8 juillet 2010 Auteur Share Posté(e) 8 juillet 2010 depuis l'aosp ca ne sera jamais possible avec sense... il s'agit d'une fuite d'une version beta de chez HTC Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
gregounech Posté(e) 8 juillet 2010 Share Posté(e) 8 juillet 2010 Tiens j'ai trouvé un post d'un français sous Orange sur XDA avec qui apparemment tout baigne : http://forum.xda-developers.com/showpost.php?p=7102029&postcount=415 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Minux Posté(e) 8 juillet 2010 Share Posté(e) 8 juillet 2010 (modifié) Wifi N et icone HSDPA (le H) : http://dl.free.fr/hM82qmzTX Amélioration de la qualité vidéo en HD : http://dl.free.fr/uDXZB2bgi Enjoy ;) Rom pas encore installée, j'attend plus de retour d'utilisateurs pour ma lancer, y'a encore quelques reboot aléatoires qui me gênent (une personne a eu un reboot en pleine conversation d'ailleurs), donc wait and see, mais ça s'annonce plutot bien :) Edit : Pour installer le Wifi N et l'icone HSDPA, c'est un zip a appliquer comme une mise à jour de rom, sans wipe par contre Pour installer le profil média : - passer en "recovery mode" - décompresser le fichier media_profiles.xml (depuis le zip) dans un répertoire (C:\Votre_rep) - faire les commandes suivantes : adb shell remount /system adb push c:\Votre_rep\media_profiles.xml /system/etc/ adb reboot C'est tout ! Modifié 8 juillet 2010 par Minux Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité Stephane8413 Posté(e) 8 juillet 2010 Share Posté(e) 8 juillet 2010 Tu m'as devancé Minux, j'allais posté le Wifi N et l'icone HSPDA. Il est à noté que dans ce pack, nous retrouvons le cercle comme logo de la batterie mais sans le % quand on débranche. Les barres de réseaux sont colorées, ainsi que beaucoup de logo (tel que le téléphone en mode Debuggage. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
oeildefeu Posté(e) 8 juillet 2010 Auteur Share Posté(e) 8 juillet 2010 j'ai mis a jour le premier post :) Merci :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Minux Posté(e) 8 juillet 2010 Share Posté(e) 8 juillet 2010 Market fix : http://forum.xda-developers.com/showpost.php?p=7106627&postcount=727 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Minux Posté(e) 8 juillet 2010 Share Posté(e) 8 juillet 2010 Et pas de quoi ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
seia Posté(e) 8 juillet 2010 Share Posté(e) 8 juillet 2010 Si quelqu'un a déja testé, quid de l'autonomie? ^^ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
oeildefeu Posté(e) 8 juillet 2010 Auteur Share Posté(e) 8 juillet 2010 l'autonomie est rapportée comme étant très bonne par plusieurs testeurs/flasheurs de la première heure Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
seth Posté(e) 8 juillet 2010 Share Posté(e) 8 juillet 2010 Bonjour On est obligé de faire l'update radio? Merci P.S: D'après le forum, on peut utiliser rom manager pour l'update Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Minux Posté(e) 8 juillet 2010 Share Posté(e) 8 juillet 2010 Market fix : http://forum.xda-developers.com/showpost.php?p=7106776&postcount=739 Version update qui permet un flash depuis le recovery Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Gin Posté(e) 8 juillet 2010 Share Posté(e) 8 juillet 2010 Installation avec Rom manager possible ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
seth Posté(e) 8 juillet 2010 Share Posté(e) 8 juillet 2010 Installation avec Rom manager possible ? c'est ce que j'ai lu sur le site mais je m'en souviens plus où, c'était un Français qui l'avait dit, fais une recherche sur le forum Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
bgnt44 Posté(e) 8 juillet 2010 Share Posté(e) 8 juillet 2010 Si cela provient bien d'une beta d'htc et que selon les retours c'est déjà assez stable, on peut penser que la sortie de la maj ne devrait pas trop tarder ... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
seia Posté(e) 8 juillet 2010 Share Posté(e) 8 juillet 2010 J'espère uniquement que la version finale d'HTC ne nécéssitera pas des "fix" pour avoir une bonne qualité 720p par exemple et que la rom fera bien tout de suite ^^ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
seth Posté(e) 8 juillet 2010 Share Posté(e) 8 juillet 2010 certains(Adam G) avaient parlé d'une rom pour l'Evo Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
oeildefeu Posté(e) 8 juillet 2010 Auteur Share Posté(e) 8 juillet 2010 je considère ça comme étant non important et pipo.. Les téléphones sont tous différents! même si ils paraissent proches au niveau des drivers il y a des différences. Ce n'est pas cohérent avec le fait que tout marche aussi bien. De toute façon on s'en fout, tout marche!! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
seth Posté(e) 8 juillet 2010 Share Posté(e) 8 juillet 2010 Peut-être qu'il a réagi par jalousie AdamG AdamG is online now Senior Member Join Date: Jun 2007 Posts: 275 [united Kingdom - O2 (Cellnet)] [united Kingdom] Default this rom was originally made for the evo not the desire what a complete waste of time its no wonder its full of bugs Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Minux Posté(e) 8 juillet 2010 Share Posté(e) 8 juillet 2010 Quelqu'un a déjà flashé cette rom avec un tel simlocké chez BT ? Ça me fait flipper ces histoire de blocage pour les téléphone Orange UK ... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
