[ROM] JB 4.3 STOCK ADVANCED DERNIERE UPDATE
bonjour voici la rom stock advanced avec son patch pour la dernière update en date google !!! ^_^y6u3yzad.jpg6e5esu2y.jpgy6uge9at.jpg6azy4usy.jpgevyhyjez.jpg
Advanced Stock Rom
:=) A collaboration between ivn888 and enricocid :=)
INSTALLATION
flasher la 4.3 stock+root&cw puis
ou
Si vous arrivez de la rom cataclysm c'est bon aussi car basée sur la stock :)
1) Wipe Dalvik+ Wipe Cache ( pas eu besoin de factory reset venant de la cataclysm/stock)
2) Flasher la rom : zip from sd card
3) Wipe Dalvik cache& cache
4) Flasher le fix
5) Pas besoin de flasher les gapps!!!!!GAPPS DANS LA ROM!!!!!
6) REBOOT
Features :
- Basé sur JWR66V JellyBean 4.3
- BusyBox 1.21.1 (/etc/init.d scripts support)
- Deodexed- Rooted (updated to latest SuperSu v1.51)
- Battery saving & performance (lot of) build.prop tweaks
- Light: removed lot of gapps bloatwares (110mb! Of Google's Jelly Bloats!)
- Zipaligned APKs
- !!NEW - Clear recents Button - NEW!!
- !!NEW - Precise Volume Control (30 Volume steps) - NEW!!-
!!NEW - 720p Video Recording by hillbeast (Recommended https://play.google.com/store/apps/details?id=com.netco.camera) -
NEW!!- Advanced Power Menu
- CM audio media- Nova Launcher inside
- CM calculatorStock 4.3 featuring Quick Settings MOD!!! Ported from AOSP to stock (Rewrited lot of codes to get it working good :P)* One-Click Wifi Tile!!* QSCP app to manage Quick Tiles, choose your tyles, click apply and done!:
- 14+ Tiles - 3 or 4 Columns
- Panel Auto Default
Some Design Restyling :
- Animation Framework by eng.stk (Hint: Set to 0.5X)- 32dpi Navbar
- !!NEW Center Clock NEW!!
- !!NEW Holo Circle battery mod w/ percent NEW!!
- !!NEW Holo K/Bs meter (don't worry, smali will show the meter appear when You have data or wifi connection) NEW!!
- Custom Wifi notification icon- Yes! We have also a customized PhaseBeam Livewallpaper :=)
- !!NEW Holo Xolo SoftKeys by ATMOSF3AR NEW!!
- !!NEW Navbar Holo highlight !!NEW
- !!NEW Custom Lockring & Glow Dots !!NEW
- !!NEW Custom ASR banner in "about phone" section - NEW!!
- !!NEW Visible Power Menu in status bar - NEW!!
- A custom Bootanimation made by enricocid
;)>>> TÉLÉCHARGER ICI
LIENS DE LA ROM :
http://d-h.st/cJu
FIX GROUPER TO Y UPDATE :
http://ahp.li/8d2fa25575f274795f3d.zip
XDA
http://forum.xda-developers.com/showthread.php?t=2400343
