[ROM] 4.2.2 Port for Fly 443/Wiko Cink Peax/Intex Aqua Wonder (Fully Working)
Unofficial 4.2.2
Features :
"Photo Sphere" panorama photos
Keyboard with gesture typing (this feature is also available for Android 4.0 and later via the Google Keyboard app)
Lock screen improvements, including widget support and the ability to swipe directly to camera
Notification power controls ("Quick Settings")
"Daydream" screensavers, showing information when idle or docked
Support for wireless display (Miracast)
Accessibility improvements: triple-tap to magnify the entire screen, pan and zoom with two fingers. Speech output and Gesture Mode navigation for blind users
New clock app with built-in world clock, stop watch and timer
All devices now use the same interface layout, previously adapted from phones on 4.1 for smaller tablets (with centered software buttons, the system bar at the top of the screen, and a home screen with a dock and centered application menu), regardless of screen size
Increased number of extended notifications and Actionable Notifications for more apps, allowing users to respond to certain notifications within the notification bar and without launching the app directly
SELinux
Always-on VPN
Premium SMS confirmation
Group Messaging
Long-pressing the Wi-Fi and Bluetooth icons in Quick Settings now toggles the on/off state
New download notifications, which now shows the percentage and estimated time remaining for active app downloads
New sounds for wireless charging and low battery
New Gallery app animation allows faster loading
USB debug whitelist
Bug fixes and performance enhancements
New kernel made by Qus1 but its not for MIUI V5 4.2.2 : http://www.mediafire.com/download/uuar93q9uwouz4b/QUS1_Kernel.zip
This is latest build made by our developer QUS1 4.2.2 Beta 4 : https://docs.google.com/file/d/0B9Xy2GDF0is9dEphNVBiMC1JVWM/edit?usp=sharing&pli=1
MIUI 3.10.11
**************************** ROM information ******************** ***************
ROM Name: MIUI 3.10.11 V5-Dual sim Dual standby
Android version: Android 4.2.2
Fit models: Fly 443/Wiko Cink peax / Intex Aqua Wonder
ROM Author: Pratikmore
ROM Size: 267 MB
Published: 2013/10/13
********** Note ************************ *****************************
Note:
1, please back up large files to AVOID operating errors lead to accidental deletion
2 mobile phone battery to be maintained at 50% more than
3 Brush risk, be careful, if any problems Caused by brush and I Forum unrelated, goal try to solve.
4, double Brush clear before
5 When you are willing to brush this package , you agree to the above On Behalf of the first 3
**************************** ROM features ******** ***************************
Changelog :
Press the bottom of the new browser toolbar "New" button Focus address bar
Added long press or on the browser toolbar at the bottom zoned "window" button to close the current window
New recorder handset mode
Add video full screen drama, automatically play the next set
Known BUG:
M sound FC
data automatic on after reboot
How to flash the rom
1) Boot into recovery
2) Wipe data, dalvik & Cache Cache
3) Flash the ROM
4) Reboot
Modifié par pratikmore
  • Réponses 1,7k
  • Vues 296,8k
  • Créé
  • Dernière réponse
Top forumeurs sur ce sujet
Most Popular Posts
  • yeap i am here, but i will work about porting android 4.4 i have result  re-build kernel with full support android 4.4 but i cant install 4.4 rom because some problems with mount memory...  works w
  • hi at github 3.4.67 one month without corrects    + beta 11 if u have blackscreen - patch module gps after build kernel, (in rom module 6589) - patch patch for all beta, comes to beta11-patch
  • hi, 4.4 is hard now for me, but ofc i will work about rom late i will work about 4.2 kernel, for more stability :) because now we have parts from kernel 3.4.67 (mediatek part) and yes here some new d
i start it at my fly 443 but have a problems with right sensor button(vibrate many time), wifi bluetooth cant connect , need a big work for adaptation :) have not expirience but may be :)
if u interested link for download http://pan.baidu.com/share/link?shareid=2688266989&uk=1462634504 its amoi version without adaptation dont install it without corrects or phone die :)
Modifié par qus1
  • Auteur
can you provide me your rom link not amoi n820 rom link,then i will try to solve that bug...
okay i upload it but warning ur phone will working as vibrator :D
dont panic its big beta version, big lags, big vibration no working wifi and bluetooth but it start and calls work with big lags)) eng is not good because have not time to think as eng
i thought problem in kernel we have 3.4.0 but for 4.2 kernel 3.4.5
if u can more gl and if u to do it please upload
Modifié par qus1
  • Auteur
okay i upload it but warning ur phone as working as vibrator :D
Thanks friend,I will help you to solve bugs with my knowledge.I solved sound problem in Galaxy 3 Cm rom and also in vivo rom so I will try my best.We will solve as many bugs...Lets Tie up for Android 4.2.2...
link soon
I will try to take help from my friends also for 3.4.5 kernel but we can solve the problem of bluetooth and wifi with some modoification in our 3.4 kernel...
Its for Fly 443 or Amoi n820 rom??? because i have downloaded rom for Amoi n820;After some modification i cant boot it on my phone.I.E. Intex aqua wonder...
its rom for fly iq443 as always its working at wiko cink peax, do not correct, install now after download
if build.prop model amoin820 its nothing if u like another u can change
Modifié par qus1
  • Auteur
if build.prop model amoin820 its nothing like another u can change
I am Pratikmore from XDA,who ported so many roms for my Intex aqua wonder clone of Fly 443.I have seen on 4PDA,so many people want VIVO Rom,If you want then I will upload VIVO 2.7 ported but not uploaded on net.only issue is music player not working but you can use other player;other than this everything is fine.
cool :)
will try that ...
Good new's, I hope that it will work well on our phone =)
En gros, il y a une version d'android en 4.2.2 qui est sorti pour un autre tel en MT6577 (donc le même chipset que le Peax 1).
Il y a donc possibilité de la porter sur notre Peax mais pour le moment, il y a pas mal de bug :
- Téléphone qui vibre constamment
- Téléphone qui rame
- Problème avec le Wifi et le Bluetooth
- La fonction téléphone avec des lags
Donc plusieurs membres sont en train de voir ce qui est faisable ;)
Voilà en gros.
I really made it working on our device
but we have some bugs:
-still lags and wifi b/t cann't turn on
Camera working fine
anyone can fix this?
if u camera fixed upload ur version and late we can more work about this... my version without camera or stay here how can i fix it libs or init.rc corrects
Modifié par qus1
when i porting this rom, i don't have problem with camera
the best answer today gl
wait for a link
Salut Alex971,
Le probleme c'est que ns chers amis sont indiens, donc a part l'anglais il ne parle que l'indi voir le russe peut etre...
Ne eut on pas faire 1 exception?Surtout qu'ils sont plus calés que la grande majorité d'entre nous au niveau de la modif de kenel et compagnie... Le portage est toujours assez facile, mais il y a certains bugs que nous sommes dans l'incapacité de résoudre, alors qu'eux si...
Ce serait dommage de devoir dire "adieu" aux futurs possibilités d'évolution de nos chers smartphones à cause d'une regle qui manque un peu de tolérance... surtout qu'il nous est assez rare d'avoir 1 dev d'xda a notre dispo ici même !
Ceci étant dis je comprends tout a fait les regles du forum, ainsi que les membres anglophobes qui ont du mal a suivre, voir qui ne peuvent pas suivre du tout le fil de la discussion ne connaissant pas du tout cette langue...
PS: Je ne critique pas les regles mises en place, mais esperant cette evolution depuis le debut de l'année (comme bcp d'entre nous d'ailleurs), j'essaie juste d'intervenir en leur faveur car ils peuvent nous faire avancer plus vite... :P Et de ce fait combler les-dit membres de notre forum...
Modifié par Bnz25
D'accord avec toi BNZ.. ;)
Je partage ton point de vu sur la démarche...
Mais alors à quoi cela sert si la plupart ne comprennent pas ce qui se dit ici...
Pas d'exception...sinon cela ne le sera plus dans quelques temps.
En espérant que cela soit compréhensible, ils peuvent faire une traduction de leurs post...(éventuellement l'original en Spoiler)
Mais en tout cas pas de discutions en autre chose que le français :)
Merci de bien vouloir donné le niveau actuel de google traducteur à faire comme 2 doigts :o J'ai dit laissez-moi savoir
